Old January 28th, 2009, 10:55 PM   #1
DirtyBoy
DirtyBoy's Avatar
Strange sound at 70+ mph
Whenever I am going over 70 mph and let off the throttle, the front end makes a kind of grinding/clanking sound. Applying the brake makes no difference until it goes below 70. The bike has almost 11k miles on it. I am looking for suggestions on what to check for. TIA
49T sprkt/ EK gold chain/ Galfer pads and SS lines/120 frt 150 rr Pilot Powers/ GSX-R can/Desnorkled/ Raised needles/ Slider spools/ Cowl/ LED rear signals/ Fender eliminator/ Tinted lights / Emu seat
DirtyBoy is offline   Reply With Quote
Old January 28th, 2009, 11:21 PM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I would check out your front axle. Try greasing it a bit and see if it helps.
k-os is offline   Reply With Quote
Old January 29th, 2009, 12:16 AM   #3
at 70mph, pull in the clutch and see if it makes the noise. That would isolate it as an engine or drivetrain/wheel noise.
Old January 29th, 2009, 03:16 PM   #4
DirtyBoy
DirtyBoy's Avatar
Thank you for the suggestions. If I hold the clutch in it doesn't make any noise. Any ideas what it may be? It's still under warranty but I really don't want to have to leave it at the dealer and have to drive one of the cages. If it's something relatively easy, i would rather fix it myself.
Old January 29th, 2009, 03:23 PM   #5
So, could it be RPM dependant? What rpm are you turning at 70mph and above? Find that out, then try the same rpm and higher in 5th gear instead of 6th. Does it make the same noise?
Old January 29th, 2009, 03:48 PM   #6
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
when you go of the throttle is it a constant noise till your under 70mph? or is it just a single clonk when you go of the throttle?
find out what rpms your using when your going faster than 70mph, then try the same in a different gear. if its not rpm dependant, you can pretty much take engine of the list of possible faults.
im guessing drive-chain/sprocket problem. or wheel-bearings.
Guinss is offline   Reply With Quote
Old January 30th, 2009, 03:21 PM   #7
DirtyBoy
DirtyBoy's Avatar
I ended up finding the problem. It turned out to be WAY too much slack in the chain. The sound was from the chain slapping on the swingarm. Thank you all very much for the suggestions.
Old January 30th, 2009, 04:08 PM   #8
HKr1
IC2(SW)
HKr1's Avatar
Old January 31st, 2009, 01:37 PM   #9
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Mr. Dirty, a check of your tire pressure and chain should be done before each ride. Lube chain after ride while chain is still warm (hot if the ride was alittle more intense).
Old February 2nd, 2009, 12:33 AM   #10
DirtyBoy
DirtyBoy's Avatar
I lube my chain about twice a month (1k miles a month) which is why i am surprised i didnt noticed how much it had stretched. But you are right, I should check it everyday as I do with air pressure.
What is this sound? Is this what out-of-spec valves sound like? CZroe 2008 - 2012 Ninja 250R Tech Talk 24 November 15th, 2021 05:48 PM
Strange sound while riding on Ninja 250R caspermayne 2008 - 2012 Ninja 250R Tech Talk 21 February 9th, 2013 02:55 PM
Strange Noise please help Darkspy72 2008 - 2012 Ninja 250R Tech Talk 6 August 20th, 2012 06:18 AM
strange static sound after 5.5k rev? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 13 July 11th, 2012 01:07 PM
Strange sound Old Lemon 2008 - 2012 Ninja 250R Tech Talk 18 June 8th, 2012 01:51 PM
