Old April 26th, 2018, 05:27 AM   #1
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
Changing brake fluid
Happy riding season! The weather here in Illinois is finally ride worthy and I haven’t been off my bike in a week. When I’m asleep I’m thinking about it lol. Anyway, a good friend of mine and a fellow forumer here said “always change your break fluid every season”. So my question is what kind should I use and where can I get it? This will be my first time doing so. I’m somewhat handy with a wrench when it comes to these wonderful bikes but any tips or anything I need to know would be much appreciated. Happy to be back and see some familiar posters! Be safe happy riding in 2018!
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old April 26th, 2018, 06:04 AM   #2
This section should have what you need - https://faq.ninja250.org/wiki/Brakes
Old April 26th, 2018, 06:26 AM   #3
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I put this in my 250:
https://www.walmart.com/ip/Prestone-...12-oz/35764362
I even saw another guy I race with putting it in his R3.
TEAM ALFALFA
www.apexassassins.com
Old April 26th, 2018, 10:51 AM   #4
If you're changing it out yearly, pretty much any DOT-3 fluid will do.
Old April 26th, 2018, 11:11 AM   #5
1994Ninja250F
‘94 Rider
1994Ninja250F's Avatar
Motorcycle(s): 1994 Kawasaki Ninja EX250F
You definitely don’t need to change it every season, brake fluid doesn’t get subjected to same stresses and extreme temperatures like the engine oil does.
Water/moisture absorption is why brake fluid gets “dirty”, and why it changes color as it gets older. If it’s tan/Brown, dump it. If it’s clear, you’re definitely good for another year.
I change mine every 3 years. The manual officially calls for either 2 years or 4 years, can’t remember.
1994Ninja250F is offline   Reply With Quote
Old April 26th, 2018, 05:35 PM   #6
A.J.
A.J.'s Avatar
Hey guys thanks for all the tips. I went to O’Reilly since I too my moms bike battery in for a charge anyway and bought Prestone Dot 4. That’s pretty much what wiki said. Since I just bought the bike last summer I’m not sure when the fluid has been changed last although it was regularly serviced the expensive route before I got her. I changed the oil last season but used Mobile 1 synthetic 4T racing oil and it’s amazing stuff. As recommended by @ramjett. So I’ll go ahead and change it this summer (brake fluid). Probably do it this weekend and inspect the breaks very throughly. Appreciate the responses as always you guys are great!
Old April 26th, 2018, 07:14 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
you may want to double check, pretty sure the ninjette uses dot 3 brake fluid.
TEAM ALFALFA
Old April 26th, 2018, 08:17 PM   #8
Ram Jet
Ram Jet's Avatar
Kawasaki recommends DOT 4 for pregens.
Bill
Old April 27th, 2018, 06:38 AM   #9
Bill
Yeah, DOT-4 has more overhead and can absorb more water than DOT-3 before it reaches too-low a boiling point. Better for longer 2-yr change intervals.
Old April 27th, 2018, 10:47 AM   #10
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Also Dot-4 and Dot-3 do not mix.
TEAM ALFALFA
Old April 27th, 2018, 01:11 PM   #11
Lump
Motorcycle(s): 2002 Fire Breathing 250 Ninja
Dot 3, 4, and 5.1 are glycol ether based. They are compatible, but like motor oils, you should use the recommended or higher grade fluid. Dot 4 and 5.1 also have borate ester to handle higher temperatures. DOT 3, 4, and 5.1 fluids are found in most brake and clutch systems
It is important never to mistake DOT 5.1 (glycol-based) with DOT 5 which is silicone-based and should never be mixed with any other DOT fluid.
Lump is offline   Reply With Quote
Old April 27th, 2018, 01:41 PM   #12
Who's the genius that thought of making DOT 5 and DOT 5.1 not compatible with each other? Ya couldn't have just made it DOT 6 instead of 5.1?
DOT 5.1 is fine to use for most applications but DOT 5 is not.
Duh.
Old April 27th, 2018, 02:40 PM   #13
It has to do with boiling-point ratings:
DOT-3 = dry boiling 401F / wet 284F glycol-based
DOT-4 = dry boiling 446F / wet 311F glycol/ester-based
DOT-5 = dry boiling 500F / wet 356F silicone-based
DOT-5.1 = dry boiling 500F / wet 356F glycol/ester-based
Back in the '80s, I used DOT-5 in my Supra and it worked great! Can last for 5-years or more due to not absorbing water*. I was flying down moutain-roads with my brake-rotors glowing red-hot and there was absolutely zero fade or pedal depression. Only issue is that it's not compatible with ABS and you have completely to clean brake system with alcohol before switching. Making it a pain as upgrade and mainly of benefit in systems that use it from the start. Such as military vehicles which are the primary users of DOT-5 today.
So, a more compatible DOT-5.1 glycol-based fluid was developed that was backwards-compatible AND provided higher boiling-point than DOT-3 or DOT-4.
* rumours of DOT-5 causing water-pooling are mis-diagnosed. The fluid doesn't absorb water at all, so where does water come from? In all cases where this occurred, it was due to users not completely clearing brake-system of prior glycol fluid and water by flushing with alcohol. The issue isn't the fluid, but how it was used.
Old April 27th, 2018, 03:33 PM   #14
Ram Jet
Ram Jet's Avatar
Thanks, I didn't know that. Anyway, DOT4 is imprinted right on the front master cylinder cover on the pregen.
Bill
Old April 27th, 2018, 04:03 PM   #15
Bill
They actually do mix and function perfectly OK. Only difference is you end up with a BP in between the two; kinda a DOT-3.5 fluid. If adding DOT-3 to DOT-4 it will lower your BP in system. If adding DOT-4 to DOT-3, it'll raise BP in system.
I have, along with plenty of others have put DOT-3 in master-cylinder without any issues. Part of this has to do with being able to use whatever supplies are within easy reach of tracks in event raceflais rears its ugly head. Need to be able to run to local auto-parts stores for supplies.
Old May 6th, 2018, 12:13 PM   #16
A.J.
A.J.'s Avatar
I went with dot 4. Why? Because Kawasaki and my bike said so.
Old May 6th, 2018, 01:38 PM   #17
Ram Jet
Ram Jet's Avatar
Me too!
Bill
Brake fluid Islandmax 1986 - 2007 Ninja 250R Tech Talk 11 June 22nd, 2013 04:28 PM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
How much brake fluid ? GiGs 2008 - 2012 Ninja 250R Tech Talk 5 December 31st, 2010 06:06 PM
Brake Fluid? ASecretNinja 1986 - 2007 Ninja 250R Tech Talk 4 January 20th, 2010 03:02 PM
