Old May 25th, 2022, 01:11 AM   #1
[webbikeworld.com] - 2022 Ducati Streetfighter V4 SP [Specs, Features, Photos]
Click here for full story...
2022 Ducati Streetfighter V4 SP: The Apex Naked Predator
Contents
New to Ducati’s 2022 motorcycle lineup is the Streetfighter V4 SP; an attempt at engineering the perfect hyper-naked motorcycle. The formula is simple; take what works with the already existing Streetfighter V4 and dial everything up to a further degree of luxury and performance.
The Ducati Streetfighter V4 SP retains the same MotoGP derived 1103cc Desmosedici Stradale 90° V4 (producing a whopping 208 hp and 90.4 lb-ft of torque) and chassis but refines some key components for potential buyers with some extra money to spend on a true ‘end-game’ hyper naked.
Beyond the special livery specifically tailored to this motorcycle taking inspiration from* pre-season MotoGP test bikes; carbon rims provide a 3-pound weight reduction, exclusive Stylema R Brembo calipers are found in the front, and Öhlins Smart EC 2.0 suspension brings a further layer of performance to top it all off.
This motorcycle gives riders a track-centric Italian performance machine they can rely on for rigorous track days, and some other key components reinforce that ethos like an open carbon clutch cover and STM-EVO SBK dry clutch system.
The 2022 Ducati Streetfighter V4 SP starts at $35,500 USD / $40,000 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Ducati Streetfighter V4 SP in one place.
Model Overview
</p>General Info
  • Price: Starting at $35,500 USD / $40,000 CAD.
  • Key Features:
    • Carbon rims
    • STM-EVO SBK dry clutch system
    • Öhlins Smart EC 2.0 suspension
    • Legendary Desmosedici Stradale V4 engine
Main Specs
  • Engine: 1,103 cc Desmosedici Stradale V4 engine engine
  • Power: 208 HP
  • Torque: 90.4 lbs-ft
  • Dry Weight: 390 lb (177 kg)
  • Seat Height: 33.3 in (845 mm) at lowest point
Competitors
2022 Ducati Streetfighter V4 SP Specifications
ENGINE
Engine1103cc, Desmosedici Stradale 90° V4, rearward-rotating crankshaft, 4 Desmodromically actuated valves per cylinder, liquid cooledPower208 HPBore x Stroke81 x 53.5 mmCompression Ratio14.0:1Fuel InjectionElectronic fuel injection system. Twin injectors per cylinder. Full ride-by-wire elliptical throttle bodies.StarterElectricExhaust4-2-1-2 system, with 2 catalytic converters and 2 lambda probes. 4-2-1-2 system, with 2 catalytic converters and 4 lambda probes*Torque123 Nm (90.4 lb-ft) @ 11,500 rpm 123 Nm (90.4 lb-ft) @ 9,500 rpm*DRIVETRAIN
Clutch*Hydraulically controlled slipper dry clutch. Self bleeding master cylinderTransmission6 speed with Ducati Quick Shift (DQS) up/down EVO 2Final DriveChain 525; Front sprocket 15; Rear sprocket 42CHASSIS
Suspension FrontÖhlins NIX30 43 mm fully adjustable fork with TiN treatment. Electronic compression and rebound damping adjustment with Öhlins Smart EC 2.0 event-based modeSuspension RearFully adjustable Ohlins TTX36 unit. Electronic compression and rebound damping adjustment with Öhlins Smart EC 2.0 event-based mode. Aluminium single-sided swingarmBrakes Front2 x 330 mm semi-floating discs, radially mounted Brembo Monobloc Stylema® R 4-piston callipers with Bosch Cornering ABS EVO. Self bleeding master cylinderBrakes Rear245 mm disc, 2-piston calliper with Bosch Cornering ABS EVOTires Front*Pirelli Diablo Rosso Corsa II 120/70 ZR17Tires RearPirelli Diablo Rosso Corsa II 200/60 ZR17Fuel Tank Capacity16 l – 4.23 gallon (US)ColorELECTRICAL
IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS
Max LengthMax WidthMax heightWheelbase1.488 mm (58.6 in)Rake24,5°Trail100 mm (4 in)Seat Height845 mm (33.3 in)Dry Weight196 kg (432 lb)WARRANTY
Warranty24 months, Unlimited mileageExtension
2022 Ducati Streetfighter V4 SP Features
Livery
The essential and captivating “Winter Test” livery has been conceived by the Ducati Centro Stile taking inspiration from the Ducati Corse motorcycles ridden in MotoGP and SBK Championships pre-season tests. The Matte Black of the fairings combined with the Matte Carbon finish of rims and wings, superbly contrasts with the bright Red accents and the sparkling brushed aluminum tank. The new born from Borgo Panigale is also enriched with some beautiful details, such as the progressive number printed on the handlebar and the Italian flag colour scheme on the carbon wings.
Engine
The beating heart is the 1,103 cc Desmosedici Stradale with 208 hp capable of delivering a torque of 123 Nm at 9,500 rpm. On the Streetfighter V4 SP the Desmosedici Stradale is fitted with the STM-EVO SBK dry clutch, which guarantees a better anti-hopping function, even in the most aggressive downshifts, and greater fluidity during all “off-throttle” stages, a crucial aspect to be truly effective on the track when pushing to the limit.
Chassis
Chassis compartment of the exclusive Streetfighter V4 SP is equipped with state-of-the-art technical contents shared with the Ducati Superleggera V4, such as carbon rims and Brembo Stylema R® front brake callipers. High-quality anodized aluminium footpegs, carbon fibre heel guards and brake and shift pedals to minimise the risk of breakage in the event of a slip and designed to quickly switch between traditional and reverse shifting configurations. The SP model shares with the Streetfighter V4 S Öhlins NIX-30 fork, Öhlins TTX36 rear shock absorber and Öhlins steering damper controlled by the second generation Öhlins Smart EC 2.0 system. Unlike the S version, it has the same Panigale V4 springs and hydraulic. The only difference is a fork spring preload reduced from 11mm to 6mm.
Performance
The Streetfighter V4 SP is the ideal companion for the amateur who wants to rule the track riding a naked bike and get an instant response. Braking capacity results in fact out of the ordinary, the bike is easier to lay into the corner and gets to the apex faster, not to mention the great stability at high speeds.
The new bike is equipped with the Öhlins Smart EC 2.0 with the event-based system that can vary the damping according to the rider’s riding style, and together with biplane wings they increase confidence and ensure the best performance in sporty use.
The STM-EVO SBK dry clutch guarantees a better anti-hopping function.
2022 Ducati Streetfighter V4 SP Photos
2022 Ducati Streetfighter V4 SP Videos
New 2022 Ducati Streetfighter V2 AND V4 SP Announced: Everything You Need To Know!
Ducati World Première 2022 Episode 4 | Streetfighter V2 & V4SP | A New Fighter in Town
Links
Ducati Motorcycle Official Websites
Social Media Links
The post 2022 Ducati Streetfighter V4 SP [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Ducati Streetfighter V2 [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 12:54 AM
[webbikeworld.com] - 2022 Ducati Monster 1200 / 1200S [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 12:43 AM
[webbikeworld.com] - 2022 Ducati XDiavel Dark / S / Nera [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 12:27 AM
[webbikeworld.com] - 2022 Ducati Monster & Monster Plus [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 25th, 2022 12:13 AM
[webbikeworld.com] - 2022 Ducati DesertX [Specs, Features, Photos] Ninjette Newsbot Motorcycling News 0 May 19th, 2022 02:12 PM
