Old June 20th, 2012, 07:22 PM   #1
jman511115
Motorcycle(s): Ninja
Unknown hose
For the record, it's not the fuel overflow hose. I took the tank off for the first time tonight. There's a hose that starts between the carb diaphragm covers plugged into a rotating T fitting, and goes... nowhere. I did not disconnect it from anything when I took the bike apart, it did not suck vacuum when I started the bike, and went for a ride with it not connected to anything and the bike ran fine. There is a hose fitting on the fuel sender that was also connected to nothing, but I thought that was only for cali bikes? Any ideas? Thanks.
jman511115 is offline   Reply With Quote
Old June 20th, 2012, 07:24 PM   #2
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
hmm...perhaps one of the many tubes involved in making the kleen air system work? I've been planning on gutting mine out, but never got around to it. (search for 'kleen air delete' and you'll know what I mean).
EthioKnight is offline   Reply With Quote
Old June 20th, 2012, 07:25 PM   #3
jman511115
It's not the kleen air system, that's still fully intact. For now.
Edit: Btw, the unknown hose terminates beneath the seat.
Old June 20th, 2012, 07:36 PM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Vent hose for carb bowls.
Old June 20th, 2012, 07:39 PM   #5
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
crankcase breather hose and oil overfill hose maybe... someone else had this question already plus some others
http://www.ninjette.org/forums/showthread.php?t=106500
PsHYk is offline   Reply With Quote
Old June 20th, 2012, 07:44 PM   #6
jman511115
That sounds right. Hooked it up to a vac line to see what would happen, and the bike died almost instantly. Thanks.
Old June 20th, 2012, 07:47 PM   #7
jman511115
Thought the crank breather ran to the airbox?
Old June 20th, 2012, 07:49 PM   #8
PsHYk
PsHYk's Avatar
do you have pictures?
Old June 21st, 2012, 09:54 AM   #9
jman511115
I do not.
Old June 21st, 2012, 10:41 AM   #10
crank breather goes to airbox, carb vents and topend breather go to kleen air recovery system if i remember right which is basically a charcoal filter with a vacuum recovery system to stick the caught gas back in the gas tank. on my 92 fzr 600, they have the carb breathers open with a U shaped hose pointing up and curving down
Old July 7th, 2012, 03:09 PM   #11
wakawaka
Motorcycle(s): '06 ninja250
I have a similar question. 06 ninja with s-shaped tube. the other end is not connected to anything. should i leave it or connect it to the other end? thanks.
https://www.dropbox.com/s/vfewvzk0vs2qayw/IMG_0672.jpg
https://www.dropbox.com/s/df4o8nu99x7esgm/IMG_0669.jpg
https://www.dropbox.com/s/oqum2b0rlcxg525/IMG_0671.jpg
wakawaka is offline   Reply With Quote
Old July 8th, 2012, 01:21 PM   #12
its the crank case breather hose going to the airbox. you're also missing the clip that holds it on. with it open its letting fun crap get inside your crank case which i'm sure is really good for it.
yes, reconnect the disconnected hose.
Old July 8th, 2012, 05:08 PM   #13
wakawaka
thanks for your help.
Unknown road to unknown road Milsparro Ride Reports 7 August 31st, 2014 08:55 PM
Unknown carb part dosfiddy 1986 - 2007 Ninja 250R Tech Talk 15 June 12th, 2012 10:10 PM
Unknown Bolt 08ninja250 2008 - 2012 Ninja 250R Tech Talk 4 August 19th, 2010 12:54 PM
Ninja '08 Unknown & dangerous problem. bogdanb 2008 - 2012 Ninja 250R Tech Talk 28 March 31st, 2010 12:52 PM
[superbikeplanet.com] - Author Unknown Ninjette Newsbot Motorcycling News 0 September 16th, 2008 08:49 AM
