December 13th, 2010, 01:58 PM | #1 |
Join Date: Aug 2010 Motorcycle(s): 2009 Ninja 250r Posts: 61
Air box removed, now....
Hey,
I was just wondering if anyone had any creative ways of supporting the carbs with the air box removed? I am assuming it is necessary to support the carbs right? A side from wire ties, what have you done to support the carbs? |
December 13th, 2010, 02:51 PM | #2 |
I think its all zip ties heh. Though I went a couple hundred miles with nothing and they held just fine. I was doing a lot of rejetting and didnt want to keep wasting them. But i put ties now just in case I hit some huge bump or crash or something, they wont pop out.
Posted via Mobile Device |
December 14th, 2010, 01:38 AM | #3 |
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
I had the same problem until I replaced both rubber boots (mine were torn, I believe the carbs hanging partly contributed to it) and then that problem went away.....so that's the expensive solution.
Something else I thought of was to take the rubber boot's off and boil them in hot water (it will shrink/stiffen them a little). The other solution (like people have suggested) is cable ties or some wire and cable ties Good luck ! |
December 14th, 2010, 06:19 AM | #4 |
What problem did you have, Gigs?
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
December 14th, 2010, 06:01 PM | #5 |
I did have the problem described here...carbs sort of hanging off the rubber boots not being properly supported.
December 14th, 2010, 07:39 PM | #6 |
Oh, I thought you meant there was a problem resulting from the hanging .
December 15th, 2010, 08:11 AM | #7 |
Has there been any issues with using cable ties and them cutting through a bit of the K&N filter boot, due to movement and/or vibration?
Please help, oil in air box. | gregoryl | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 19th, 2014 07:01 PM |
air box | John D | 1986 - 2007 Ninja 250R Tech Talk | 10 | September 4th, 2012 08:07 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Air box clamps | haze5736 | 1986 - 2007 Ninja 250R Tech Talk | 1 | July 9th, 2011 04:16 PM |
Gasoline in the Air Box?? | Buffalony | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 20th, 2010 05:40 PM |
