July 3rd, 2011, 04:41 PM | #1 |
Bushmaster11B
Join Date: Mar 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R "Limited Edition" w/ Metallic, Pearl Essent, Candy Coat 3 Tone Paint Job Posts: 181
The Ninja Choke King/ God, Please HELP me
OK, so my dumbass brother didn't start my bike at all while I was gone for 12 months in Afghanistan. It has set in storage for about 15 months now. My fuel gelled up in the carbs and this is what I have done so far:
Replaced spark plugs with NGK Uridium plugs Removed carb Disassembled carbs without seperating them Cleaned carbs, floats, needles and jets (removed jets to clean, they had green corrosion on and inside the jets) with B-12 Carb Cleaner Spray Adjusted the choke cable to take out all extra slack (just like when you set your idle screw flush with the throttle arm) Reassembled in EXACT REVERSE ORDER after the carbs where completely cleaned to my trained eyes.... So this is what happened next: The little ninja (2009 250r) would only run with the choke on fully. I adjusted the idle screw to try to gain more rpms while the choke was on and only could get it up to about 3200 rpms. It sounded like it was fluxuating between 3200- 1500 back to 3200 rpms repetively. It does this gradually as the bike gets warmer. I only can back the choke off a 1/4 way before the engine dies when the engine is warmed for 20 minutes. If I pull the throttle any it bogs down and dies. Doesn't matter how slow I pull/ roll the throttle. I even tried to ride the bike in 1st gear by ONLY easing off the throttle. Again, any gas given by throttle and it dies while riding. Everything on my bike is OEM. I used premium unleaded with the right amount of Sea Foam for this attempted repair. Also, there was continuous LITE grey smoke comming out the exhaust muffler. But only visable for 2 inches from the end of the can. Please help me. I have no money and I'm trying to get this thing running so I can afford to go to work instead of driving my huge SUV. This sucks and I hate my Brother right now who can't pay me for his mistake. Guess I made the mistake in the end for trusting him while I was fighting for his Freedom.
http://r9.fodey.com/2166/7fddc3a7c75...978e4f3c.0.gif |
July 3rd, 2011, 05:11 PM | #2 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
You mean you forgot to drain the gas before you put it in storage?
July 3rd, 2011, 06:44 PM | #3 |
Join Date: Jun 2010 Motorcycle(s): Ninja 250R (2009), Special Edition Posts: 18
Remove and clean the carbs; the jets are gummed up. This must be the #1 problem with the 250 when it has been winterized improperly or sat for as little as a few weeks with gas in the carbs. See the wiki for very helpful DIY guides.
good luck! |
July 3rd, 2011, 06:46 PM | #4 |
Could you see through the main and pilot jets? If not, blow compressed air through them. Once you reinstall the carbs and connect all hoses with the tank, etc., adjust the idle screw when choke is on.
July 3rd, 2011, 06:55 PM | #5 | |
Opinionated individual :)
Join Date: May 2011 Motorcycle(s): 2010 Ninjette Special Edition (red/black) Posts: 342
And the "while I was fighting for his freedom" line... c'mon. Twas your choice to be the governments slave lol. The fuel could be gelled everywhere from the tank through the whole system.
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete 2010 SE 250R! Miles in the saddle: 1000 |
July 3rd, 2011, 07:22 PM | #6 | |
Bushmaster11B
As for the other appropriate post above, I did clean everything and the jets looked brand new when I put them back in. I had stabilizer in the left over gas. I know that stuff don't last forever and there was mistakes made one both parts. Either way, I listed what happened and what I did above. I appologize if I'm not the happiest person in here right now but riding my motorcycle means Freedom for me and it's one of the few things I looked forward to doing when I was overseas. Please, if anyone has any other suggestions, feel free. I'm thinking it has something to do with the air/fuel mixture. I know nothing about motorcycles as a mechanic however have worked on cars/ trucks for a very long time, so I am not all mechanically incline. I have the tools, just need the knowledge. Thanks for your suggestions and anymore help you can give.
July 3rd, 2011, 07:35 PM | #7 |
Kkim has put together the reference thread on this:
http://www.ninjette.org/forums/showthread.php?t=65198
July 3rd, 2011, 08:03 PM | #8 |
Jason,
clean the pilot jets again... they are still gunked up somewhere/somehow. also, drain and refill the tank w/ fresh gas if you have not done so yet. |
July 3rd, 2011, 08:09 PM | #9 |
July 3rd, 2011, 11:25 PM | #10 |
Join Date: Aug 2009 Motorcycle(s): '08 250R (sold), 2013 300SE Posts: 276
Sorry to say but it sounds like your will be tearing down your carbs again. In your OP you said you cleaned all your jets. Did you also clean the passages in the carb body? This is usually overlooked. There are small air bleed passages that also clog easily. Totally disassemble your carbs and use spray cleaner and compressed air to blow out all the passages where the jets and needles go. Make sure you remove the slide diaphrams before blowing through any passages to prevent damaging them. When you blow through passages,blow both ways until air flows freely. Then reassemble and with luck it will run and you can sync your carbs and your on the road. Carbs can be drag. Hope this helps, good luck.
July 3rd, 2011, 11:55 PM | #11 |
ratlab
Join Date: May 2011 Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100 Posts: 132
he's from northern cal-bred to be a mindless hater of the military-can't help himself
July 4th, 2011, 09:09 AM | #12 |
Something along these lines ^.
I dislike it when people come off like their better than everyone or did people a favor by signing up for the military. I mean good for you, im sure it was an empowering and bettering experience for you and all that. And Kim, it wasnt an insult... its true. You make the decision to sign a contract and do whatever they tell you whenever they tell you in exchange for cash. I see nothing extraordinarily respectable about that especially when it involves wrecking havok upon the lives and communities of people just like you and me in other parts of the world. And then to expect to be honored and praised for it? /facepalm Anyhoo's carry on, I'll keep outa this thread. Also, I would clean carbs and jets, replace the fuel filter and pull the fuel lines to run some solvent through to clean em out. Wouldnt want any chance of gunk further up in the system getting into the carbs right after you clean em.
July 4th, 2011, 09:17 AM | #13 |
Join Date: Jun 2010 Motorcycle(s): 2010 Ninja 250r Posts: 80
I can see this guy's ^ point, but what were you trying to accomplish with that comment? Needed a little attention?
Sorry to the OP for stepping into this thread with no insight on your issue. But that post about your service pissed me off. |
July 4th, 2011, 09:25 AM | #14 | |
If your asking me about my comment "Twas your choice to be the gov's slave", its explained above.
I've heard too many people who have thrown "while I was fighting for their freedom" line around, especially when it has no place. Quote:
I have no issues with people choosing to be in the military, its their choice. I do have issue siwth people expecting somehting from others because they chose to do so. You gonna give me free play because Im a Salesman at a car dealership? My brother didnt empty the fuel out of my bike... WHILE I WAS SELLING CARS. DEAR GOD. Hahah, sorry for the cheesy example but I think it gets my point across. One of my best friends is in the Marines and he never pulls stuff like that. Hope that answers your question, I dont want to start troubles on this board. P.s. Happy 4'th of July. Also, reviewing OP's post... Dont use Premium, these bikes take basic unleaded. The SeaFoam was a good idea and thats what produced the lite grey smoke.
July 4th, 2011, 09:32 AM | #15 |
Try to find some small diameter wire you can run through the orifices in the jets themselves. The carb cleaner may not have knocked out some gunk trapped in them.
July 4th, 2011, 10:07 AM | #16 | |
A bit of compressed air through them jets too. http://www.ninjette.org/forums/showthread.php?t=65198
July 4th, 2011, 10:53 AM | #17 | |
Bushmaster11B
Gonna take the carbs out tomorrow. Today is the 4th, so Happy 4th of July to everyone. Let's blow crap up. Will keep you posted for my 2nd try on the carbs.
July 4th, 2011, 11:01 AM | #18 | |
Bushmaster11B
July 4th, 2011, 11:25 AM | #19 |
July 4th, 2011, 11:47 AM | #20 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
I dont think anyone thinks they are better here i think if his brother agreed to do something and did not and caused a error its his brothers fault. Simple. Lets say jason had a dog idk maybe he does have one and his brother was taking care of it but forgot to feed it and it died. Same thing there.
VROOOM vrooom >.> |
July 4th, 2011, 12:03 PM | #21 |
Glad we got past that
I believe the slide diaphragms are the fragile black rubber piece you see when you take the cap off the carb. I could be wrong but those pieces tear easy so be careful with them. Typically carb tuning goes in the following order, and you may wish to do all of the following since you will be pulling the carbs. I would simply for the peace of mind and knowing she'll be running perfect when you straddle dat saddle. ;P Check the Valve Lash - http://www.ninjette.org/forums/showthread.php?t=9787 Valve Adjustment - http://www.ninjette.org/forums/showthread.php?t=9924 Carb Syncing - http://www.ninjette.org/forums/showthread.php?t=9754 Idle Adjust - http://www.ninjette.org/forums/showthread.php?t=10246 Hope this helps.
July 4th, 2011, 02:12 PM | #22 | |
Bushmaster11B
July 4th, 2011, 02:17 PM | #23 |
July 4th, 2011, 03:31 PM | #24 |
I don't see the valves being an issue if the bike ran when you parked it. I think alot of rides jump into valve adjustments to soon. Heck I've got 48000kms on mine and still haven't had to adjust them from factory, but then maybe I'm lucky.
Anyhoo back to the task at hand. The canned air should be sufficient, just blow the crap out of every hole you find. |
July 4th, 2011, 03:39 PM | #25 |
Make sure the prime/run petcock is set correctly. With taking everything apart and putting it back together, something small like that could get overlooked. Good luck to you.
July 4th, 2011, 05:33 PM | #26 |
By reset valves he probably means adjust them which is covered above.
July 9th, 2011, 10:18 AM | #27 |
Bushmaster11B
WOOOOHOOOO!!!! It runs... kind of. You know that passage way by the main jets and the pilot jets? ( brass insert passage)One was clogged. I had to use a piece of wire to un clog it and then blasted it with carb cleaner. I then put everything back together and the bike is running and idleing with no problem. However, when I roll my throttle back medium to fast speed, it blogs down and up a couple times before it starts running smoothly. When i'm in any of the ears while driving, it does this when I roll the throttle hard. I have to eaze on my throttle to prevent it from bogging down. What do you guys think the problem is? I have stock everything however, I have about 4 drilled holes on the end of my exhaust (previous owner drilled them out because he thought it would sound better I guess). It ran fine before the storage misshap with those same holes. Any suggestions?
http://r9.fodey.com/2166/7fddc3a7c75...978e4f3c.0.gif Last futzed with by Bushmaster11B; July 10th, 2011 at 01:21 AM. |
July 9th, 2011, 11:46 AM | #28 | |
Wartown, USA
To my fellow veterans... Thanks for serving. |
July 9th, 2011, 12:53 PM | #29 | |
Bushmaster11B
"We have it so good and easy and yet we still piss on one another.... WHY?"
http://r9.fodey.com/2166/7fddc3a7c75...978e4f3c.0.gif Last futzed with by Bushmaster11B; July 10th, 2011 at 10:31 AM. |
July 10th, 2011, 10:26 AM | #30 |
Bushmaster11B
Reposting again with aquired picture:
One thing I failed to mention and this may help diagnose my current problem is the bike was running at 3600 ft elevation before it was improperly stored and I'm currently at 700 ft elevation. Don't forget about the exhaust with 5 holes drilled in it right under the baffle cap (stock exhaust/ OEM). If you need me to post a pic of my exhaust, I can do so.
July 13th, 2011, 02:39 PM | #31 |
with regards to your running problem- did you drain out the old gas in the tank and refill with fresh gas? if not, do so and add some seafoam to the gas according to the instructions on the bottle. sounds like you still have carb issues.
try this... ride the bike and repeat the running problem. while riding the bike, turn the choke on and see if the problem improves or gets worse. also, when you were in the carbs, did you by chance remove the mixture screw plugs and shim the needles? That would have been an excellent time to do that. |
July 13th, 2011, 03:07 PM | #32 | |
Bushmaster11B
2. I rode my bike after letting it propperly warm up, though all gears. When I rolled the throttle back hard with the choke on, it still bogged but not as bad as without the choke on. When the choke is off and I roll on the throttle hard it almost kills the bike each time. 3. If the mixture screws you are referring to are under those caps you have to pop out with a wood screw, then no, I haven't even popped off those caps. And no on the shimming. I figgured I had to shim with those holes in the muffler. I just don't get why it's a problem now and never was before I stored the bike. I'm going to start with 2 washers on each needle. They are #2 washers right? For very near future reference, will I need to remove those washers later when I rejet the carbs after installing a full exhaust and pod filter? "This is why I hate buying used machines" Atleast I'm learning though...
July 13th, 2011, 03:57 PM | #33 |
1. the larger of the hoses is the fuel line. the smaller is the vacuum hose which operates the petcock. no hose to that sending unit under the tank.
2. okay, so that tells you you're not getting enough fuel, for some reason, if it runs better when the choke is on and worse when it's off. Definitely a lean condition in the carbs... most likely from jets still being plugged in the carbs somewhere. 3. next time you remove the carbs, (which will be soon, I expect) be sure to remove those caps. I would recommend you shim the needles also, but the bike should run fine even if they aren't shimmed, at this point. There is another issue causing your problem. I highly suggest you read the DIY on shimming if you intend on doing so. That will answer all your questions about shimming. get your bike running well, first, before even thinking of adding an exhaust and pods. You need to establish a well running machine before even thinking of introducing another level of possible problems/headaches. I also suggest you start reading a service manual to help you with working on the bike and to familiarize yourself of what components you are changing. The DIYs are here to supplement the service manual... not replace it. |
July 13th, 2011, 05:21 PM | #34 | |
Bushmaster11B
When I test drive it for about 10 minutes at low speed, will it mess anything up running lean while I'm fixing it? I'll remove those mixture screws and make sure they are clear too. Going to add shims useing "VIA" DIY so see if it helps any on my first attempt of cleaning the carbs this weekend. Thanks for your help again. Side note: have you ever had those passages clogged that I showed above in one of your pictures?
July 13th, 2011, 06:39 PM | #35 |
I've never checked those specifically, but when you get your carbs out, blow compressed air through every orifice you can find in the carbs. Take the slides/diaphragms out too just to prevent damage to them when you're using the compressed air in those passages. Keep track of left and right slides as the needles are different in each.
I use 100psi and a blower tip to clear out carb passages, but even then, sometimes even that's not enough to clear the clogs, depending on what they are. running lean for a short a period will not harm the bike. |
July 14th, 2011, 05:11 PM | #36 | |
Bushmaster11B
July 14th, 2011, 06:07 PM | #37 |
with regards to the floats... I wouldn't adjust them if the bike was running fine before, unless you think you might have screwed up the level when you were in there last. Won't hurt to check them, I guess, but adjusting/reading the level correctly takes some practice to get right.
July 16th, 2011, 11:13 AM | #38 | |
Bushmaster11B
Going to get the washers today along with the Chem Carm Bath in a can. Going to soak the carbs for 24 hrs after I remove all the plastics from it and I'm also going to check my new NGK Iridiums to see if they are black or white. That should tell me real quick if it's lean or rich. I will get this bike done soon. I swear. Just hard to do it with a Military schedule you know. Makes me a Weekend Warrior for my ninja Off subject: I was looking on your jetting pics and noticed some kind of silver power control module. Your pictures were dated 2008 so I doubt it was not on a newer EFI bike. What is that thing you zip tied to the frame.
July 16th, 2011, 11:15 AM | #39 |
in the front cowl??? if so, it's the HID ballasts.
July 16th, 2011, 03:07 PM | #40 |
Bushmaster11B
ok got it... LOL. Going to soak the carbs tomorrow. It's 117 F outside right now. Thanks for the help and patients.
[cyclenews.com] - King of the Motos: Cody Webb – King Again! | Ninjette Newsbot | Motorcycling News | 0 | February 4th, 2014 01:50 AM |
[topix.net] - One Sik King | 2002 Harley Davidson Road King Classic | Ninjette Newsbot | Motorcycling News | 0 | August 31st, 2010 10:21 PM |
09 Ninja 250 Choke and Throttle ? | ozuhas | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 19th, 2009 11:09 AM |
[sportrider - latest stories] - Velocity Racing's Suzuki B-King - Boosted King | Ninjette Newsbot | Motorcycling News | 0 | June 17th, 2009 03:10 PM |
[onewheeldrive.net] - 2008 Suzuki B-King – Manga’s Brute King in the Real World | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2008 01:06 PM |
