Old April 6th, 2009, 02:46 PM   #1
ahskeetz
ahskeetz's Avatar
Motorcycle(s): 2008 250r
7500 mile maintenance!
Hey everyone. Just wondering if anyone has done teh 7500 mile maintenence yet, and if you did, how much time did it take you, what was the degree of difficulty, and what special tools did you need?
I'm nearing 7500 so I'll probably try to do this myself once the semester is over. I called a Kawasaki dealership and they said it would cost about $290... thats alot
2008 250r: AP CF full exhaust, raised needles, 6000k HIDs, flush mounts turn signals, custom fender chop
ahskeetz is offline   Reply With Quote
Old April 6th, 2009, 02:56 PM   #2
actually, that's not too bad. The 7,500 mile service requires the valves to be checked/adjusted. If it included adjusting the valves as well as the other stuff needed at 7.5k, that's a bargain.
are you capable of checking/adjusting the valves yourself?
Old April 6th, 2009, 03:12 PM   #3
ahskeetz
ahskeetz's Avatar
well i have never done that, but im sure that if i have the right tools and then i can do it with some guidance. i dont have the manual with me right now, but would that show exactly how to do that?
Old April 6th, 2009, 03:16 PM   #4
here's a few better than a manual... you be the judge if you are capable of doing these.
http://www.ninjette.org/forums/showthread.php?t=9787
http://www.ninjette.org/forums/showthread.php?t=9924
Old April 6th, 2009, 03:32 PM   #5
ahskeetz
ahskeetz's Avatar
wow those DIYs are intense. they look so complicated... man i wish i knew more about motors.. i don't think i'll be able to do that myself, maybe i can get my mechanic friend to help albiet he's an auto mechanic. if not i guess i'll have to find $290. I think if i had more confidence that i wouldn't damage anything, i'd do it myself ..
Old April 6th, 2009, 03:40 PM   #6
while not that hard, you should know what you're doing and why, as screwing something up while you are in there could have some pretty far reaching negative consequences.
add to that the shims you need, if it does need adjusting, and removing the cams and retiming the bike, you better be absolutely sure what you are doing is correct.
when the time comes, I'm seriously thinking of having someone else adjust the valves if I need it, provided I can find a competent mechanic in my area.
Old April 6th, 2009, 06:26 PM   #7
ahskeetz
ahskeetz's Avatar
Yeah I guess it's better that i'm safe than sorry. I might be able to do some of the maintenence, like air filter, carb synch etc.. so maybe i'll save some money and leave the complicated part to kawasaki
Old April 8th, 2009, 08:44 AM   #8
g21-30
g21-30's Avatar
kkim, you can do this! Vex's DIY is superb and I'm sure you have the experience, so this shouldn't be a problem. Measure twice, cut once! Or, to put it another way...definitely take pictures from all angles, before you remove the cams and gears.
When it's time for you to do it, let me know and I will encourage you at that time...again!!
Old April 8th, 2009, 10:02 AM   #9
lol... thanks. I'll need to get to 7,500 miles first! At my present rate, it may take a few years.
Old April 8th, 2009, 10:30 AM   #10
islanderman7
The Sexy Filipino
islanderman7's Avatar
Motorcycle(s): Ninja 250R 2008 (da black one)
Are you still under 3k?
Area P CF Standard,Airbox Removed,K&N R-0990,Factory Pro Jet Kit 3.0, Zero Gravity DB
I'm not riding too fast... I'm flying too low.
islanderman7 is offline   Reply With Quote
Old April 8th, 2009, 10:32 AM   #11
Old April 11th, 2009, 05:21 PM   #12
08_250R
Motorcycle(s): 08 Green 250R
Considering Kauai is only about 200 miles for the entire loop, that is a lot of laps. haha
08_250R is offline   Reply With Quote
7500 mile inspection wardie 2008 - 2012 Ninja 250R Tech Talk 1 December 6th, 2014 11:34 AM
7500 Mile Service Driddle 2008 - 2012 Ninja 250R Tech Talk 6 July 19th, 2013 01:17 PM
7500 Maintenance Part 1 (image intensive) Cuongism 2008 - 2012 Ninja 250R Tech Talk 20 July 13th, 2011 03:35 PM
7500 Mile service Banzai The Ex-Ninjetters Lair 31 May 7th, 2010 06:52 AM
7500 mile Service. Anything else? camaroz1985 2008 - 2012 Ninja 250R Tech Talk 6 June 18th, 2009 06:02 AM
