March 9th, 2014, 04:50 PM | #1 |
Join Date: Feb 2014 Motorcycle(s): 2014 Ninja 300 Posts: 22
06 Ninja250 to 00 EX250 exhaust compatibility?
Hey guys I have a 2000 EX250 Ninja. The bike is pretty set but needed a few minor items. I had found a wrecked 2006 Ninja 250 at a amazing price. So far all the parts I needed for my 00 havent had any problems working on my 2000. My first issue Ive run in is my exhaust. The 00 exhaust uses a one side large muffler set up. The muffler though is extremely loud for my liking(un-necessarily loud in my opinion) but it does work. The 06 Ninja 250 uses a split exhaust set up splitting the exhaust on either side. When I set the 06 exhaust in place it appears as it'll work and allow the exhaust on either side to attach. This issue I am running in is when I bolt in the 06 exhaust into the 250 engine and bolt down the bolts the exhaust still has way to much wobble as if it werent bolted down at all. At this point I feel like Im either missing something or it is possible this 06 Ninja 250 exhaust isnt compatible on my 00 EX250 engine?
Thanks for any responses and answers to this question |
March 9th, 2014, 05:46 PM | #2 |
I believe that all the years previous to 2008 have the same double exhaust and that they are all compatible.
Any 2-in-1 exhaust is an after market and dimensions may vary from original.
March 9th, 2014, 05:57 PM | #3 |
Thanks a lot when I get back home I'll recheck everything. Based on the diagram I believe I just forgot one of the 2 inserts.
March 9th, 2014, 10:38 PM | #4 |
Well I added the flat discs(part 11009A). Only thing different then I did before. Still having issues with it having too much wobble. Been trying to look up a step by step instillation video or guide but no luck.
March 9th, 2014, 11:33 PM | #5 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
should post pics. but make sure you are putting the header in firmly. it will slid in a bit
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
March 10th, 2014, 12:32 AM | #6 |
March 10th, 2014, 08:20 AM | #7 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
Yep, your 92143's are in backwards.
March 10th, 2014, 08:33 AM | #8 |
Private Joker
MOTM - Mar '14
^ ya those little rascals can be a pain as it isn't inherently obvious how they should go in at a glance in real life or in the diagram. After flipping them around if the problem persists then I'd double check that you're getting the 18069's tightened correctly as they can rattle a bit when they get loose and if they're loose it's the same as if the headers aren't connected.
March 10th, 2014, 12:02 PM | #9 | |
March 11th, 2014, 12:51 AM | #10 |
Ok got the muffler attached on correctly thanks guys.
March 11th, 2014, 12:57 AM | #11 |
[IMG][/IMG]
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Ok since you guys were able to answer my last question I have another question regarding my mufflers now. When I use the brackets to attach the muffler to the frame the only way I can do it is to pull the muffler back so its no longer all the way forward. As the picture shows one side is worse then the other. If I tighten down the all the bolts as best I can should this be fine or should I just tighten down the muffler all the way forward and not attach them to the passenger bracket? Thanks for all responses and information. |
March 11th, 2014, 08:53 AM | #12 |
If you tighten down all the bolts as best you can it should be fine.
The weight of the mufflers must be supported or it will load the connections to the cylinders (bad). Verify that the three long bolts that anchor the engine to the frame are in place and properly torqued. If those are OK, remove the seat and tank and look for cracks in your frame in the area between the head bearing and the air filter, .......... just in case that is producing some squat of the center of the bike and messing up the geometry of the tubes-mufflers. Please, see related thread that explains the potential problem: http://www.ninjette.org/forums/showthread.php?t=147037
March 11th, 2014, 03:37 PM | #13 | |
March 11th, 2014, 03:40 PM | #14 |
passanger pegs are on wrong also
March 11th, 2014, 03:42 PM | #15 |
Growler Exhaust Review '08 ninja250! | blink | 2008 - 2012 Ninja 250R Tech Talk | 20 | March 12th, 2014 03:49 PM |
