June 11th, 2016, 08:43 PM | #1 |
Buying an 06 that's been sitting for almost a decade?
So I was wandering around craigslist when I found a 2006 with 800 (eight hundred!) miles that's evidently been sitting for some time now.
I've got a bit of experience with getting old pregens road-worthy but nothing like this. Questions: What kind of degradation happens on this timescale? Are we just looking at rust on the outside, or is the engine probably toast? Obviously the fluids all need to be replaced but is it likely that all the insides are gummed up? I'll happily do carbs but replacing engine bits is a little more than I'm comfortable with. Think it's worth the time?
You have the right to remain silent. Anything you say can and will be misquoted and used against you in an internet fight |
June 11th, 2016, 08:59 PM | #2 |
Join Date: Feb 2009 Motorcycle(s): 2009 250r SE, 2015 FJ-09 Posts: 171
If it was outside odds are good that the forks are shot. Shock may be as well. engine wise you might just be talking about fluids and a carb/tank cleaning. Chain and tires will need replacement. Check the brake rotors for deep rust. For 800 it might be worth looking at but I would spend some time looking it over before committing to anything.
June 11th, 2016, 09:07 PM | #3 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Our 2001 sat for 9 years in a carport.
It needed the tank cleaned, the carbs cleaned, fluids changed, and is now a great runner.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
June 11th, 2016, 10:54 PM | #4 |
All rubbers replaced, tires, hoses, brake lines, caliper seals. New chain, all fluids of course.
Pulls the plugs, put some light oil in the cylinders, rotate by hand to make sure the rings aren't frozen, the crank it a few times with starter motor, put plugs back in. Other than that have fun.
June 13th, 2016, 06:12 AM | #5 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 460
I recently purchased a parts bike that sat for 8 years. I could not turn the throttle, or get the key into the fuel door lock, for a while. The tank is all gummed up, and I know that the carbs are. It was outside, but covered. Surprisingly, it was not all rusted out.
As others have stated, tires, fluids, etc. will need replacing. The sum of replacing all the "little" things might outweigh the bargain. I purchased mine strictly for parts - not to return to the road. If the price is right, go for it!
... can't stop updating the bike! Last futzed with by spent_too_much; June 24th, 2016 at 12:21 PM. Reason: spelling correction |
June 13th, 2016, 06:42 AM | #6 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
If the bike was located in the desert area of CA, with drier air, it might not be too bad..
Inspect the bike through and through before you commit, check ALL moving parts still move... Check the inside of the fuel tank for rust, if rust present, might be cheaper just get a used tank from salvage instead of reseal it. |
June 23rd, 2016, 07:49 PM | #7 |
What did you decide? Did you purchase it?
... can't stop updating the bike! |
June 23rd, 2016, 09:00 PM | #8 |
I decided against it. I figure that even if I make a profit it won't be worth the time.
[visordown.com] - The best decade for motorcycling is This one | Ninjette Newsbot | Motorcycling News | 0 | February 4th, 2014 08:20 AM |
look at what I got just sitting here :| | reaperw | 2008 - 2012 Ninja 250R Tech Talk | 9 | January 8th, 2012 08:47 PM |
If you could only own one bike for the next decade... | Lil_Green_Demon | General Motorcycling Discussion | 38 | November 18th, 2011 09:40 PM |
[motorcyclistonline] - 'The Find of the Decade' - One of the First Ever Motorbikes up | Ninjette Newsbot | Motorcycling News | 0 | January 14th, 2010 06:10 PM |
[motorcycledaily.com] - A New Decade . . . And New Ideas | Ninjette Newsbot | Motorcycling News | 0 | January 3rd, 2010 10:50 PM |
