Old February 23rd, 2015, 10:38 AM   #1
omarcarbomb
Motorcycle(s): 2006 250ER
Kickstand Kill switch - Inert
I just replaced my engine over the holidays. (Threw rod at 65mph total bottom end loss on original engine)
Gave old engine to my scrap metal buddy.
Got used engine (also from 2006) on EBay for $350
Replacement was fun and easy for 35+ years’ experience motorcycle mechanic.
(Don't recommend you do yourself without proper tools and experience and patience)
New engine runs Boss!!!
Only issue with bike is the kick stand cut off circuit.
Here is why I'm posting:
When kick stand is up circuit is closed
When kick stand is down circuit is open.
This is proper operation for ground interrupt to ignition circuit.
Basically the kickstand circuit has been taken out of the path and does nothing to interrupt the ignition circuit.
Anyone come across this?
Omarcarbomb
2006 Ninja 250ER
omarcarbomb is offline   Reply With Quote
Old February 23rd, 2015, 01:15 PM   #2
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
The way I'm understanding your explanation... While in 1st gear with stand UP, the bike shuts off, but it doesn't while in 1st gear/stand down?
"That's what" -she
Roark is offline   Reply With Quote
Old February 23rd, 2015, 08:42 PM   #3
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Your kickstand switch probably isn't working? How many years did you say you had as a mechanic?
Mods: Offset clutch pressure plate
Old February 24th, 2015, 01:49 PM   #4
omarcarbomb
NO and I doubt it
the kickstand switch is nothing more than a SPST switch that is open when the stand is down.
I have voltmeter tested kickstand it is closed when up and open when down.
Test procedure is to isolate kickstand and open and close bullet connectors.
What I'm saying is the kickstand switch and kickstand circuit seem to be floating..
Floating as in - not in the ground interrupt path
no matter what the open or closed state of the two leads that go to kickstand are it does nothing to the ignition circuit.
thanks,
O
Omarcarbomb
2006 Ninja 250ER
Old February 24th, 2015, 05:11 PM   #5
agentbad
agentbad's Avatar
Probably just needs a good cleaning. You can bypass it pretty easily as a temp fix but I wouldn't leave it that way.
Old February 24th, 2015, 06:05 PM   #6
Ghostt
Ghostt's Avatar
I agree with all the statements above, here some additional information that may help you,
http://faq.ninja250.org/wiki/Underst...afety_switches
http://faq.ninja250.org/wiki/My_side...27t_work_right
http://faq.ninja250.org/wiki/Electrical_%26_Lighting
http://faq.ninja250.org/wiki/Main_Page
violente et ignorantia
ZX-2R BLOG
Old February 26th, 2015, 04:05 PM   #7
Roark
Roark's Avatar
Have you figured it out?
"That's what" -she
Old March 10th, 2015, 04:38 PM   #8
omarcarbomb
agentbad:
how/why would one go about "by-passing" a circuit that is NOT doing any thing?
Its already "bypassed" that's the issue.
Thanks Ghostt for the links.
From the first link
"The sidestand safety is a single pole, single throw (SPST) switch located at the sidestand pivot bracket on the left side of the motorcycle. When the sidestand is in the up (riding) position, the safety switch closes and completes a circuit to chassis ground. When the sidestand is down (parked) the safety switch opens and the circuit is not completed."
SO if you disconnect the kickstand from the bullet connectors in pic and just leave the 2 dangling wires the bike should NOT have ignition ground.
http://faq.ninja250.org/wiki/File:Ninja_250_054_cr.jpg
My bike runs no matter what you do with those two wires. OPEN/CLOSE no effect. They are already "bypassed"
Does anyone know where those two wires terminate?
Omarcarbomb
2006 Ninja 250ER
Old March 10th, 2015, 05:27 PM   #9
Ghostt
Ghostt's Avatar
Unfortunately I do not, I would advise to look very careful at the wiring diagrams
ZX-2R BLOG
Old March 11th, 2015, 08:30 AM   #10
agentbad
agentbad's Avatar
Originally Posted by omarcarbomb View Post
agentbad:
From the first link
Oh my bad, read it wrong, so it runs either way? Guess it'd be hard to trace without going through all that spaghetti.
Old March 13th, 2015, 12:45 PM   #11
FvnnyL3tt3r1ng
I'd tug on the wire (it's green right?) until you see where it is in the ignition module. You could pull it out and butt splice it or buy the right pins at radioshack and replace the wire altogether. Unless of course you didn't rule out the ignition module malfunctioning.
Frozen Kickstand Kill Switch? Brother Michigan 2013 - 2017 Ninja 300 Tech Talk 8 January 9th, 2014 12:59 PM
Kill Switch Countersteer General Motorcycling Discussion 6 May 6th, 2012 12:55 AM
hidden kill switch? petiteninja 2008 - 2012 Ninja 250R Tech Talk 4 May 26th, 2010 04:09 PM
Engine Kill Switch won't kill .KiT 2008 - 2012 Ninja 250R Tech Talk 53 November 15th, 2009 11:43 AM
Kickstand safety kill switch removal? paterick4o8 2008 - 2012 Ninja 250R Tech Talk 9 July 17th, 2009 12:05 PM
