Old July 26th, 2012, 08:01 AM   #1
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
Bad Diode
One of my diode packs is bad (the ones on top of the battery box). OEM replacement is on order but for now I have bypassed the 3 pairs of wires and it works fine.
Is there any problem with riding this way for a week?
I have read that the diodes are there to protect other components if you were to connect the battery or jumper cables in reverse (which I will not) but I don't want to fry some more expensive part in the system if this is not the case.
Thanks
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old July 26th, 2012, 10:19 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
Thanks
Thats not why they are there.
There for some of the safety lock out circuits. So they dont back feed on each other.
The one set of diodes protects the CDI from 12 volts back feeding on it... you know the wire thats looking for a ground, so you get a spark.
Why dont you jump it with some didoes from rad shack?
Old July 26th, 2012, 10:45 AM   #3
red5
red5's Avatar
Thanks for the info HK; I certainly don't want to kill the CDI.
I actually have a few in hand from our bin here at work. I will put them in tonight.
Old July 26th, 2012, 04:27 PM   #4
red5
red5's Avatar
FYI, part number 1N4001 works fine. Unless it craps out in the next few days, I will just return the OEM module when it arrives next week.
Wiring a DIODE for 4 L.E.D turn signals AnarchoMoltov 2008 - 2012 Ninja 250R Tech Talk 126 November 9th, 2021 12:13 PM
Does my pre-gen need the diode mod? mayonaise_invasion 1986 - 2007 Ninja 250R Tech Talk 16 August 22nd, 2014 11:31 AM
No-cut Diode kit CThunder-blue Motorcycle-related 16 July 24th, 2012 09:37 PM
Diode Mod. RedRider715 2008 - 2012 Ninja 250R Tech Talk 4 March 12th, 2011 08:40 AM
LED/DIODE question. Seattle_Chris 2008 - 2012 Ninja 250R Tech Talk 8 June 23rd, 2010 08:48 AM
