Old October 29th, 2012, 10:22 AM   #81
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
I am watching this thread carefully - with the 5-8k distances I see for most tires I'm really going to run up costs on my weekend drives between LA and Vegas; I'm still on my OEM tires right now, but am looking for something that won't break my wallet. I'd love something sticky for the canyons but destroying those by going 600 miles every weekend in a straight line seems like a waste.
Old October 29th, 2012, 10:31 AM   #82
cuong-nutz
cuong-nutz's Avatar
I managed to squeeze out 7k with the BT-16 rear. and about 10k for the front. The new S20s seems to have a slightly softer compound as I'm getting about 6k out of it. my new BT-45s should be coming in soon so I'm hoping I can get more than 7k at least.
HalfFast Racing Team
Old October 29th, 2012, 10:34 AM   #83
thomason2wheels
thomason2wheels's Avatar
Motorcycle(s): dl650
Originally Posted by bob706 View Post
I have the Activs - 140 rear 110 front
How have the activs held up for you?
I was with Alex.S and Jiggles last night and they had sex....the video is on utube. :-)
thomason2wheels is offline   Reply With Quote
Old October 29th, 2012, 10:36 AM   #84
thomason2wheels
I agree, have you considered one of the long mileage tires like the metzeler marathon?
Old October 29th, 2012, 10:49 AM   #85
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
No, but I just pulled those up on superstore -- the closest size I see is 140x80 and IIRC my 250's rear is 130x70... will that work? (ignorance apologies, have barely looked at tires so far)
Old October 29th, 2012, 11:06 AM   #86
thomason2wheels
140 80s should fit the rear no prob, but it is a much taller tire than stock and will lower rpms on the highway. Id run it through gearing commander and see if you would be happy with the result.
Old October 29th, 2012, 11:09 AM   #87
Joshorilla
Bass Master General
Joshorilla's Avatar
I like the black rubber ones.
Seriously, the variance in tires is much less than the variance in rider perception & reaction, especially for commuters.
Old October 29th, 2012, 11:11 AM   #88
thomason2wheels
I think it will with no problem...but run it thru gearing commander to see if youll be happy with the rpm change. The taller tire will lower your rpms a bit at road speed.
Update....contacted metzeler directly and they do not recommend the 140/80 17 for the ninja, they also did not say why nor did he offer a better choice. Harumph! :-)
Last futzed with by thomason2wheels; November 16th, 2012 at 09:13 PM.
Old October 29th, 2012, 11:36 AM   #89
DaBlue1
DaBlue1's Avatar
Hi Blue, i cant see the advantage of going any wider as you have done, but taller makes good sense if enough clearance can be had between the fender and front tire. I would imagine slotting the bolts holes in the fender would give enough clearance. Any thoughts?
If you are referring to to maybe sliding the fender up by using slotted bolt holes on the fender, that may be possible, but there is the fork brace/ fender mount to contend with. You may need longer bolts to secure the fender at the top. I have about 1 cm of clearance between the tire and fender and about 2 cm between the tire and the brace.
On the profile side... the front may be a little narrower with some brands. Depending on the tire, the extra height may be just a tad taller than my 120 and it may not do much as far as correcting the speedo error. Maybe a .1 -.3 mph correction at the most
IRC Front Road Winner RX-01 110/80H-17 Blackwall Tire
Dimensions:
Inflated Width/Measuring Rim Width: 4.30 in./2.50 in.
Inflated Diameter: 24.2 in.
Acceptable Rim Width: 2.50 in.
Michelin Front Pilot Activ 110/80H-17 Blackwall Tire
DIMENSIONS:
Inflated Width/Measuring Rim Width: 4.72 in./ 2.50 in.
Inflated Diameter: 24.41 in.
Acceptable Rim Width(s): 2.15-3.00 in.
Dunlop Front GT501 110/80VB-17 Blackwall Tire 300469
DIMENSIONS:
Inflated Width/Measuring Rim Width: 4.3 in./2.5 in.
Inflated Diameter: 23.9 in.
Continental Front Conti Go 110/80V-17 Blackwall Tire
Dimensions:
Inflated Width/Measuring Rim Width: 4.72 in./2.50 in.
Inflated Diameter: 24.40 in.
Acceptable Rim Width: 2.15 in.-3.00 in.
Bridgestone Front BT45V 110/80V-17 Blackwall Tire 084948
Dimensions:
Inflated Width/Measuring Rim Width: 4.20 in./2.50 in.
Acceptable Rim Width: 2.50-3.00 in.
IRC Front Road Winner RX-01 110/70H-17 Blackwall Tire
Dimensions:
Inflated Width/Measuring Rim Width: 4.30 in./3.00 in.
Inflated Diameter: 23.3 in.
Acceptable Rim Width: 3.00 in.
Continental Front Conti Go 110/70H-17 Blackwall Tire
Dimensions:
Inflated Width/Measuring Rim Width: 4.76 in./3.00 in.
Inflated Diameter: 23.46 in.
Acceptable Rim Width: 2.75 in.-3.50 in.
Bridgestone Front BT45H 120/70H-17 Blackwall Tire 066109
Dimensions:
Inflated Width/Measuring Rim Width: 4.80 in./3.50 in.
Inflated Diameter: 23.8 in.
Acceptable Rim Width: 2.75-3.75 in.
Old April 10th, 2013, 04:23 PM   #90
LNasty
Daily Jap rider
LNasty's Avatar
Question commuter tires
Can you all suggest some decent cheap tires that are good for commuting, ones that are at least better than the stock irc? how are the Dunlop?
Old April 10th, 2013, 04:32 PM   #91
/merged
Old April 10th, 2013, 05:05 PM   #92
felo
Motorcycle(s): Ninja 300R
in terms of wear characteristics , grip and overall feel,
are bt016 = rosso 2?
felo is offline   Reply With Quote
Old April 10th, 2013, 06:11 PM   #93
LNasty
Daily Jap rider
LNasty's Avatar
Need something that will last many many miles, but don't suck like the irc's
Old April 10th, 2013, 06:31 PM   #94
xSean13
xSean13's Avatar
If you don't mind going up a size in the rear, the bt023 should be good..I think the rear is 140.
I just got a set on my CBR and they're amazing, I commute 100 miles round-trip to school and back.
Old April 10th, 2013, 07:12 PM   #95
LNasty
Daily Jap rider
LNasty's Avatar
Would love to have the bt-023's but they are out of my price range.
Old April 10th, 2013, 07:22 PM   #96
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Check out Shinko. Their tires get many good reviews. I'm more than happy with the 712 rear on my pre gen.
Tire recommendations for NYC rider? nliu314 2008 - 2012 Ninja 250R Tech Talk 2 June 11th, 2012 12:53 PM
Got a flat...now need a new tire. Need recommendations on an upgrade Hitman 2008 - 2012 Ninja 250R Tech Talk 4 July 25th, 2011 05:10 AM
To the commuters CThunder-blue General Motorcycling Discussion 66 July 15th, 2011 08:05 PM
Ideal Tire repair kit and portable air pump recommendations? setasai General Motorcycling Discussion 12 July 6th, 2011 08:44 AM
Tire Pressure recommendations 2up GeorgiaHooligan 1986 - 2007 Ninja 250R Tech Talk 9 April 14th, 2011 08:08 AM
