January 9th, 2013, 07:59 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): ninja 250 03 Posts: 13
Put on UNI pod filters now bike won't turn over
Any suggestions? Rejetting tomorrow
January 9th, 2013, 08:35 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Rejet
January 9th, 2013, 08:45 PM | #3 |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
Choke It.
Hard
It doesn't LOOK that steep. But you can go first... |
January 9th, 2013, 09:28 PM | #4 |
Did you ever fix your previous bogging problem after the re-jet?
January 10th, 2013, 12:15 AM | #5 |
We fixed the bog down no 're jet had a bad seal which led to a vacuum leak but tomorrow we are rejetting and possible shim for the needles any thoughts
Those with pod filters | Dark | 2013 - 2017 Ninja 300 Tech Talk | 9 | July 26th, 2013 08:03 PM |
Does anyone use the UNI foam filters? | Little Green Machine | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 24th, 2013 12:45 PM |
Pod Filters | coolbreeze | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 28th, 2011 07:28 PM |
Uni-pod questions | fivepin | 1986 - 2007 Ninja 250R Tech Talk | 2 | August 29th, 2010 10:58 AM |
Question about UNI pods\K&N air filters | cbass78 | 1986 - 2007 Ninja 250R Tech Talk | 6 | March 22nd, 2009 06:28 PM |
