June 6th, 2009, 09:10 PM | #1 |
self wrencher
08 fuel cut out problem
hey guys,
my 2008 Ninja 250 with a full tank, it runs great. However, when it gets to about 1/2 a tank or so, on a freeway, it looses power after about 5 mins of riding and just dies. It happened to me several times. I had to full over to the feeder, turn everything off, let it sits for a couple of mins, and crank with full chock and it'll gradually comes to live again...then drive for 5 mins or so and it dies again. If I pull up to a gas station and full it up to full (from about 1/2 tank), then it runs fine. The only mod I did to the line to the carb is put in a big inline fuel filter and took out that little stock fuel filter (locates near the carb). Is it something wrong with the petcock? Is it the fuel filter? What do you guys suggest I would do?? drain the tank & take out the petcock and inspect??? The bike has about 1200 miles on it. Bought it brand new. Warranty expired a week ago |
June 6th, 2009, 09:12 PM | #2 |
Sounds to me like a venting problem. Way to confirm it is to ride with your second key right in the gas cap, and as the bike is dying, pop open the gas cap and see if it immediately restores your power. If that's the case, then it's probably nothing more than a vent tube that's kinked somewhere from one of the times you lifted the tank up.
If the venting isn't working properly, the fuel being drained out of the tank starts to pull quite a vacuum inside the tank, and eventually it will keep the fuel from flowing out of the tank properly. The other telltale sign is as you pop open the cap you hear a pretty noticeable "whoosh".
June 6th, 2009, 09:15 PM | #3 |
That's me!
Join Date: Nov 2008 Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR Posts: 454
I had a similar problem due to venting. Pull over and try opening the fuel cap and then start it. It it fires right up then you have a vent problem. The strainer on the petcock takes quite a while and a lot of neglect to clog up so I doubt after 1200 miles it is that.
How long ago did you put the filter on? I doubt it's that, but if you put the filter on and then had the problem... You know If opening the gas cap fixes it, then perhaps something is clogging the vent? The vent hose is the one hose (for you non California people) that exits the left side (when sitting on the bike) near the front of the gas tank and leads to the bottom of the bike. If that got pinched or clogged it will cause the condition you've described. |
June 6th, 2009, 09:16 PM | #4 |
That's me!
Dang! Alex is fast like a Neeeeeenja!
June 6th, 2009, 09:33 PM | #5 |
self wrencher
I thought it's vent too so I openned up the gas cap and drove and the engine still dies after 5 mine or so.
I'm thinking of replacing the fuel filter and see what happens. I replaced the fuel filter when the bike has 100 miles or so (did it when pull airbox to pods, rejet with factory pro kit and elim klean air system). Again if I drive slowwww then it's fine. If I'm on freeway accel fast and with half tank, this prob occurs. I'm thinking fuel is not filling up the carb fast enough? May be hindered by this stupid aftermarket filter? Posted via Mobile Device |
June 6th, 2009, 09:39 PM | #6 |
That's me!
Right. If you open the gas cap it relieves the vacuum. By riding and gas leaving the tank, you'll keep re-creating the vacuum. Opening the gas cap is a way of discovering the problem, not permanently fixing it As for filters, gas flows a lot slower then you think into the carburetors. There's no way a filter could cause that much of a restriction.
June 6th, 2009, 09:57 PM | #7 |
self wrencher
Okay so it's not vent prob and not filter prob, what's a possible problem then? Any idea?
June 6th, 2009, 11:24 PM | #8 |
That's me!
Well that's the damnedest thing. IMO I'd work backwards then and bypass the filter, and see if that helps. I've only had problems with small engines and fuel filters when the gas tank is rusted out (and the filter clogs almost instantly). That's why I'm doubting the filter being a prob.
I suppose you could pop the fuel line from the carbs and hold it over a little can or something and turn the petcock over to prime. If fuel pours out easily then that eliminates that. Hell you could even get a bigger container and see if the tank will easily drain a couple of quarts of gas. If a quart of two comes out without fault then that would eliminate anything from the fuel tank side of things. Silly question, but did you install the fuel filter so the arrow indicating flow is pointing down towards the carbs? |
June 7th, 2009, 05:39 AM | #9 | |
self wrencher
I'll swap out the filter with some bigger one (presumably better flow, less restrictive) and see if that would solve this issue. |
June 7th, 2009, 03:58 PM | #10 |
IC2(SW)
If the only thing you did was the filter, best check that.
Maybe there are different ones for free flowing, compared to under pressure(fuel pump) |
June 7th, 2009, 04:39 PM | #11 | |
self wrencher
June 7th, 2009, 05:36 PM | #12 |
IC2(SW)
^ Yeah, that one looks ok. But if you never had it happen before the mod....
June 7th, 2009, 06:58 PM | #13 |
longshot - but could a different sized/flow fuel filter mess with the vaccuum petcock??
June 7th, 2009, 08:01 PM | #14 |
That's me!
negative. The vacuum function of the petcock and the fuel flow are independent of each other. Good suggestion though That and he put it on prime and still had the problem.
June 7th, 2009, 10:03 PM | #15 |
self wrencher
no i didn't put it on prime and drive..i did open the gas cap and drove.
pulled the line and put on prime...fuel pours out...so looks like petcock is not restricted/hindered.. replaced the fuel filter with big a$$ fuel filter...tank is full from yesterday. start her up and drove for like 2 hours plus...took it down all the way to about half (1.7 gallons at fill up before going home)...no fuel cut out....yet...need more testing. one thing I notice though is first when start her up 70mph tach indicated 7K rpm. after about 30 mins drive, 70mph tach indicated 8K rpm (consistently from there on)....until cool down (next day) then it's 7:7 again. This is with 15 sprocket front and 43 rear. |
June 7th, 2009, 10:21 PM | #16 | |
June 7th, 2009, 10:37 PM | #17 |
self wrencher
Yup... And I scored an ignitor off eBay for cheap. Will swap it out and see
June 8th, 2009, 06:16 AM | #18 |
February 22nd, 2010, 09:57 PM | #19 |
Hmm... sound a bit like my issue.
http://www.ninjette.org/forums/showthread.php?t=38016 I have had the bike oddly die and refuse to start again a couple of other times long ago, but it always started working a few minutes later (after checking fluids and such). Did you ever get it solved, John? |
February 22nd, 2010, 10:35 PM | #20 |
self wrencher
Yeah. It was the aftermaket fuel filter. Replaced it with a bigger free flow one solved it.
February 23rd, 2010, 12:31 AM | #21 |
You are sleeping
Kinda o/t
With the RC helicopters I used to mess with they would omit the fuel filter for such reasons. Could be costly to have the gas cut out at the wrong time. I'd imagine could go the same way for a bike on the freeway when you need to pass or something. Maybe you can pre-filter the gas?
<Yeah, it's a 250. LMFAO! Weaksauce |
February 23rd, 2010, 09:48 AM | #22 |
Well, I haven't added one, so I hope mine is as simple as clogged vent holes. Come to think of it, I haven't heard the tank whistle in a while and it did happen when the tank was cooled suddenly by rain (causing a more rapid vacuum to develop).
[crash.net - MotoGP] - Ducati fuel cut â??makes no differenceâ?? | Ninjette Newsbot | Motorcycling News | 0 | April 9th, 2015 01:50 PM |
[crash.net - MotoGP] - Ducati fuel cut â??no differenceâ?? | Ninjette Newsbot | Motorcycling News | 0 | April 9th, 2015 01:40 PM |
[roadracingworld.com] - AMA: Introduction Of Problem-Causing E15 Fuel May Be Delayed | Ninjette Newsbot | Motorcycling News | 0 | November 15th, 2013 01:50 PM |
Fuel Overflow Problem | CWLESQ | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 26th, 2013 05:39 AM |
[visordown.com] - Budget latest: Fuel duty cut | Ninjette Newsbot | Motorcycling News | 0 | March 23rd, 2011 03:40 PM |
