August 16th, 2014, 07:56 AM | #1 |
Flasher issue
Hi Guys,
I have LED front and rear turn signals install with a new grounded flasher relay. Now all 4 of my lights are flashing when I turn the switch on to left or right. Any one have any ideas about this? |
August 16th, 2014, 08:24 AM | #2 |
Maybe this will help.
http://faq.ninja250.org/wiki/My_LED_...9;t_work_right Good morning and welcome! Do tell us about yourself and your shop in an intro post
August 16th, 2014, 05:52 PM | #3 | |
Certified looney toon
MOTM Jul '13, Jul '14
Sounds like you'll need the diode mod.
If you have a newgen ('08+) model, a member here designed a plug and play version that is carried on CustomLED http://www.customled.com/products/20...-cut-diode-kit And Tri's write up on his gizmo: https://www.ninjette.org/forums/showthread.php?t=79621 Quote:
Electronic Flasher Issue | 95XL | 1986 - 2007 Ninja 250R Farkles | 11 | August 1st, 2012 07:10 PM |
led flasher help | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 26th, 2011 04:33 PM |
Flasher relay question!!!!! | danjaho | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 8th, 2011 03:03 PM |
what kind of flasher relay? | DEXSPEED | 2008 - 2012 Ninja 250R Farkles | 6 | January 24th, 2011 08:02 PM |
Brake Light Flasher? | lux | 2008 - 2012 Ninja 250R Farkles | 2 | October 28th, 2010 06:34 AM |
