Old April 2nd, 2013, 09:34 PM   #1
cuong-nutz
cuong-nutz's Avatar
Loose cam chain wear?
Anyone have this issue? The chain has worn down the oil galley pickup thinger. This is my 2010 250 with 21k miles. Haven't checked the chain for stretch yet.
HalfFast Racing Team
Old April 6th, 2013, 07:37 AM   #2
Old April 6th, 2013, 08:17 AM   #3
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I looked at a first gen engine I have apart. It has a small scratch.. MY guess is the chain slings out on down shifting. But that tab is there to keep the chain from going to far, looks like it works. no worries, maybe shine it up a little.
Worlds fastest 250 ninja
Old May 6th, 2013, 10:47 AM   #4
cuong-nutz
cuong-nutz's Avatar
Would I see any issues if I cut that piece away to replace the chain? I'm trying to avoid splitting the case.
Old May 6th, 2013, 11:23 AM   #5
its not from the chain, the case is cast and then machined. those are machine marks. if it was caused by the chain it wouldn't look so clean like it was cut with a real tool. it would simply break that little piece off.
Old May 6th, 2013, 12:39 PM   #6
Racer x
Racer x's Avatar
The mark is from the side of the chain rubbing on the tab. It does not hit it hard.
The tab is there to make sure the cam chain does not jump on the crank gear.
I would not recommend removing it.
Old May 6th, 2013, 12:58 PM   #7
lgk
i wouldn't remove it....
just split the case, and install a new chain.
Old May 6th, 2013, 01:19 PM   #8
Jesse8931
Jesse8931's Avatar
Motorcycle(s): 2007 ninja 250r
If you need a new chain at 21k you might as well stop riding.
my xl350 had 44k and the chain was replaced but it wasnt super bad.
Jesse8931 is offline   Reply With Quote
0 out of 2 members found this post helpful.
Old May 6th, 2013, 01:21 PM   #9
mgentz
Board Member
Your chain most likely did this when u did not install the guide. There are no machining marks. Mine was spotless.
Old May 6th, 2013, 02:55 PM   #10
could you explain your reasoning
Old May 6th, 2013, 03:10 PM   #11
Jesse8931
Jesse8931's Avatar
lets see the chain should last atleast 50k unless you are revving the piss out of the bike all the time.
Old May 6th, 2013, 03:12 PM   #12
lots of things *should* do a lot of things. are you saying running at high revs damages the cam chain? you are being extremely vague here. "ur bike broke, quit life bro"
Old May 6th, 2013, 03:28 PM   #13
Jesse8931
Jesse8931's Avatar
Yes high rev's all the time will stretch the chain over time.
If it where me I would pull the cct and make sure it is working as it should.
On my cb750 I replaced the cam chain with 40k on it rode the bike for about 5k and had a stretched chain again. So I thought let me replace the cct while i'm at it rode another 15k and sold the bike.
Old May 6th, 2013, 03:33 PM   #14
Racer x
Racer x's Avatar
I just looked at my 2008 engine. I definitly rev the piss out of it all the time. Really.
I never ride on the street and I race it any chance I get. The 2008 engine has a tiny little mark. My 2009 engine gets the same treatment. No mark. But I have had a mechanical cam chain tensioner on that engine since it had 21 miles on it.
Most of the first gen engines I have are over 40000 miles. They all show a little mark.
I would say the when decelerating the chain slings around some . And with the stock cam chain tensioner there is play in the chain sometimes.
I would just split the case. It's not hard to do. And if you replace the chain replace the tensioner. Maybe look into the mechanical type.
Old May 6th, 2013, 04:36 PM   #15
I replaced the cam chain ... rode the bike for about 5k and had a stretched chain again.
how come you didn't stop riding?
Old May 6th, 2013, 05:43 PM   #16
cuong-nutz
cuong-nutz's Avatar
Good to know. I'll switch to motor B for the time being and just put up this motor up until I can get around to splitting the case and examine everything.
This was prior to me forgetting the exhaust cam chain guide.
Chain adjuster came loose backinthesaddleagain 2008 - 2012 Ninja 250R Tech Talk 13 December 22nd, 2014 08:21 PM
Loose chain remedy The_big_dill 1986 - 2007 Ninja 250R Tech Talk 11 October 31st, 2013 07:18 PM
Loose chain adjuster Slick_Stevo 2008 - 2012 Ninja 250R Tech Talk 4 July 8th, 2013 05:06 PM
Loose chain - really that bad? headshrink 2008 - 2012 Ninja 250R Tech Talk 42 February 11th, 2010 01:06 PM
Chain loose question frogandalien 2008 - 2012 Ninja 250R Tech Talk 11 June 23rd, 2009 02:00 PM
