July 2nd, 2014, 03:50 PM | #1 |
[motorcycle.com] - SCOOP: 2015 Harley-Davidson Road Glide Spied
Harley-Davidson’s 2014 model-range was comprehensively overhauled, as part of the company’s “Project Rushmore,” which endowed many of their bikes with upgraded engines, suspension, brakes and infotainment. *When the 2014 bikes were revealed, the shark-nosed Road Glide – previously a popular model – was a glaring omission from the line-up. According to a memo sent out to Harley-Davidson dealers, the Road Glide was taking a hiatus for 2014 as The Motor Company replaces the fairing tooling. But fear not as an overhauled Road Glide is heading back into the lineup – as we can see in these photos – and it will share many of the Project Rushmore technical updates given to its siblings 12 months ago. Powered by the firm’s air-cooled, 103cu-in High Output Twin Cam 103 engine rather than the partially-water-cooled “Twin-Cooled” motor used in some of the other Rushmore models, the Road Glide should deliver numbers almost identical to the Street Glide Special we tested late last year: 77 horsepower at 5000 rpm and 92 ft-lb of torque at 3800 rpm. Compared to the old, 2013-model Road Glide, the new version has upgraded brakes with ABS and the firm’s ‘Reflex’ linked braking system to connect the front and rear, an improved fork, and a 19-inch front wheel instead of an 18-incher. But*it’s the new nose that’s the main talking point. While carrying over the classic shark-nose shape, its twin headlights are now LED units behind a single Plexiglas front cover, with air intakes on either side. It’s likely that these intakes, as well as the new slot beneath the low-cut screen, are part of a pressure-equalizing system similar to the one that debuted on the 2014 Street Glide. This opens or closes the screen duct at the touch of a button to alter the airflow behind the fairing, reducing buffeting at speed. SCOOP: 2015 Harley-Davidson Road Glide Spied appeared first on Motorcycle.com. Click here for full story...
[motorcycle-usa.com] - 2015 Harley-Davidson Road Glide First Ride | Ninjette Newsbot | Motorcycling News | 0 | August 26th, 2014 12:41 AM |
[motorcycledaily.com] - First Look: 2015 Harley-Davidson Road Glide and Road Glide Sp | Ninjette Newsbot | Motorcycling News | 0 | August 1st, 2014 08:40 PM |
[motorcycle-usa.com] - 2015 Harley-Davidson Road Glide First Look | Ninjette Newsbot | Motorcycling News | 0 | August 1st, 2014 07:40 PM |
[motorcycle.com] - 2015 Harley-Davidson Road Glide Preview | Ninjette Newsbot | Motorcycling News | 0 | August 1st, 2014 07:50 AM |
[motorcycle.com] - SCOOP: 2015 Harley-Davidson Freewheeler Trike Spied | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2014 03:50 PM |
