October 18th, 2014, 02:18 PM | #1 |
No voltage at fuse box for two fuses
Hello,
I've searched the forum and cannot find anything for my particular problem. On my 2013 Ninja 300, I noticed my turn signals were not working. Odd... So when I got home I noticed that the small running lights up front were working but the actual headlights (hi- and low-beams) are not. When I checked the fuses they appeared fine, so I swapped with known good ones. Still no dice. Ran my multimeter across the fuse terminals and there is no voltage to these particular terminals. Any advice on where to go from here? The wires on the battery-side of the fuse box are all part of the harness and without a thorough wiring diagram I'm EXTREMELY hesitant to start cutting that guy open... Any suggestions would be much appreciated. Thank you, Jim |
October 18th, 2014, 05:14 PM | #2 |
Update - the blinkers were due to LED flasher relay... Voltage was fine at the fuse box, I was just measuring wrong. I can connect the fuse terminals to the light bulb connector and get light, as well. Still no dice on high OR low beam though. Something in the middle is jacked.
October 19th, 2014, 11:13 AM | #3 |
Are you checking power in the headlight connectors, or could it be the bulbs at this point?
October 19th, 2014, 11:17 AM | #4 |
No power at the connector for either headlight.
fuses and junction box | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 8th, 2014 05:23 AM |
No start, click from fuse box, batt is good | WAGESLAVEesc | 1986 - 2007 Ninja 250R Tech Talk | 17 | June 7th, 2014 04:09 PM |
bike wont start. fuse box is buzzing | rabies | 1986 - 2007 Ninja 250R Tech Talk | 13 | October 6th, 2012 03:40 PM |
