Old October 18th, 2014, 07:36 AM   #1
mattmid
Motorcycle(s): 2014 ninja 300 se abs
Ninja 300 Smog Delete
Well for the first time working on the bike, I must say it isn’t that bad. The fairings were easy to figure out without any instructions and everything else you can literally see everything you need to remove to access the area you want. So for my first Mod that I am installing on my Bike is the SSR Smog Block off Plate. If I knew it was only going to be a small piece of metal I probably would have just made it at work for much cheaper, but for 15$ it’s not that bad. While most of the pictures you will notice I have more taken off the bike, that’s because I am also installing a K&N pod filters.
First step is to make her naked don’t need to go as far as I did since I was also removing the intake and all that I removed a lot of extras. You can see my lowers dangling, that’s because whoever installed my exhaust striped out that bolt and it’s just a circle. No need to drill it out just yet
I would say Sides, Fronts; Gas tank (not needed just makes it easier).
Next would be to remove the 2 tubes off the Valve and off the engine plate and air box.
Remove the 2 bolts on the engine plate
mattmid is offline   Reply With Quote
Old October 18th, 2014, 07:37 AM   #2
mattmid
Reinstall SSR Block Off Plate with 2 washers (Not Included)
Plug the inlet and outlet of the valve
This image is showing you the valve is easy to pull of the connection on the bike. Just slides off makes it easier to maneuver around to replug it
Old October 18th, 2014, 07:37 AM   #3
mattmid
I’m not pulling the 2 sensors, small hose running to throttle body or the valve itself like on the 250s as it’s a Air Pressure sensor it needs to stay installed.
Plug the Intake inlet, Im not showing this as I removed my intake completely.
But thats for a separate write up on Pod Install
Bam your done, Start her up
Should remove all backfiring found with Aftermarket Exhaust systems
Old October 18th, 2014, 08:47 AM   #4
pratik06
Motorcycle(s): Yamaha R15, Kawasaki Ninja 300
.... Have been thinking about doing this. Very helpful. Thanks
pratik06 is offline   Reply With Quote
Old October 18th, 2014, 11:17 AM   #5
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Good looking anodized plate. And good pics!
All this work to get rid of popping on decel? Are power commanders or tuneboys available for the bike?
Old October 18th, 2014, 11:24 AM   #6
micoulisninja
modaholic junkie
it is also necessary to get correct AFR readings when tuning piggybacks such as the PC V, which are available for the 300 along with any other big-bike tuning stuff...
@mattmid you need to get rid of those secondary butterflies to gain some torque in the low-mid and some quicker revving...
Old October 18th, 2014, 11:29 AM   #7
mattmid
So what pull the throttle bodies and pull out the butterflies?
2014 Ninja 300 SE ABS
Yoshi FE, K&N Pod Filter, SSR Block Off, EJK Fuel Tuner
Old October 18th, 2014, 12:56 PM   #8
micoulisninja
modaholic junkie
you unbolt the bolt that holds the secondary butterflies on the axle and remove them....no pulling, be gentle and careful not to let the bolts go down the bodies...you need a very precise screwdriver because the bolt has been glued by the factory and needs a bit of pressure only at the first revolving... if you are new to engine mods, better have someone more experienced do it for you...
Old October 19th, 2014, 09:58 AM   #9
mattmid
Here is the Block off plate
http://www.slingshotracing.net/catal...ate-p-498.html
The other things that i used were Dorman Bypass Cap Assortment #02253 comes with 8 of them. 4 different sizes and i used the 1/2 caps.
Here are the final pics not so great. Ill do a write up for the Pod Filters as well with links for everything needed. I didnt take to many picture for that one though.
What did you guys do with the valve? same thing i did?
left 2 sensors, blocked off 2 ports, left hose going to throttle body?
Old October 29th, 2014, 07:05 AM   #10
garth285
KAWASAKI GURU
garth285's Avatar
Most of the time you can just remove the valve completely and leave the plug alone, if it does throw an FI light you can just make a jumper inside the plug and that will take care of it.
Just an FYI zx10r block off plates work as well and you can buy two for about $16 off flebay so if you and a buddy want a set thats a cheap option.
I used to take the cap off and JB weld the opening and be done with it but its nice to have a little more room above the valve cover.
Looking good!
P.S. if you ever want to mess with the ECU let me know I can flash it for ya ;-)
Old October 30th, 2014, 01:58 AM   #11
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@mattmid, I would recommend you to think about the offer from @garth285, since it is the fuel-mapping what at least makes the popping go away.
I did all those mods also, the popping didn't go away until I started to adjust my fuel-mapping with the Leovince FAST-Fuelsystem with at least some pops still coming sometimes.
Now with the knowledge of the fuel-mapping inside my ECU I'd change my FAST-Mapping according to the ECU and got - http://www.youtube.com/watch?v=fPo6v0KhBdw
Old October 30th, 2014, 05:53 AM   #12
garth285
KAWASAKI GURU
garth285's Avatar
Popping on decel yes is sometimes normal even if you do the block off plates but if you can tune the bike either threw ECU or piggy back (Power commander/Leo Vince) its not to hard.
What I normally do is on the dyno I will run the engine up to max RPM's and I will let the bike decel and watch the tach.... if the bike pops from say 7,000 rpm down to 4,000 rpm I will at the 0% Throttle position on the map I will subtract 10% fuel which is normally 0% and run the bike again and see if it goes away. Most of the time it works perfectly but sometimes you have to ADD 10% fuel... That popping is unburnt fuel firing off....
Quick and easy fix, hope that helps anyone here!
Old October 31st, 2014, 02:51 AM   #13
Somchai
Freedom for Germany
Some more informations about popping and mapping of fuel.
After I've started remapping my fuel again, this time according to the stock-map inside my ECU my first guess was to look for the richest values and then set all my values in case of rpm to this.
This made my setup really rich and after my test-ride (also while it) my first thoughts have been: Oh what a crap!
My Ninjette was running but with a little bit of feeling about how an engine should run I think everybody could feel that this is nothing good and not so powerful like it should be. It felt like the clutch grinding.
The second case with this setup what I saw was that the water temperature was around 10 degrees Celsius higher than before!?!
So I started my next trial (please remember we don't have a dyno here, I use my experience from long ago and my butt for this) and not only with the word from German tuners in mind, but with Fuel-Injection go to the leanest possible point since there's (in most cases) the highest and best power-output and this differs to the old-aged setup of carburettors with racing-cams.
While and after my test-ride I had a big grin all over my face and I can say: I'd find it...
By the way, the setup now means no great differences to the map inside the ECU and at least I only took the peaks away but now my 2-fiddy is running as smooth as she never did before, starts pulling powerful from 4000 rpm all the way up to 12500 rpm.
One word to remind about exhaust popping, please read what this member wrote, since it may give a better understanding about how to act: https://www.ninjette.org/forums/show...45&postcount=8
And my last word to this issue and this is a VERY important one: a good fuel-mapping also highly depends on the fuel you are using - ALWAYS keep this in mind!
Another guy I met here is using another brand of piggy-back for fuel-mapping with his Ninja 250 and his setup from the company doing it for him, with which one he is happy, is very rich compared to my map, but since he is using 91 RON E10 (Ethanol 10%) I believe him that it feels good, but since I am using the best quality brand of benzine one can get here, which is also used in small aircrafts, and also this in 95 RON so my setup must be more lean and not only about the environment with high temperatures (35 degrees Celsius nowadays).
If one asks about my map, please understand that it doesn't make no sense to show anything since my engine is special, my country-version and also the environment here is different.
Good luck for everybody in modifying his bike.
Old October 31st, 2014, 08:54 AM   #14
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
@mattmid
Might wanna put this in the wikki
Old November 3rd, 2014, 10:02 AM   #15
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
My ghetto MacGyver fix was just using the front brake line as a plug. I replaced it with a ss line so it was just laying around and I cut it down to size, it fits in the holes perfect. It used a screw to seal off the ends.
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound
LoneRonin is offline   Reply With Quote
Smog Block cbinker Ninjettes At Speed 5 January 26th, 2014 09:12 PM
Area P full race exhaust/jetting/airbox-delete/kleen-air delete.. corksil 2008 - 2012 Ninja 250R Tech Talk 24 January 21st, 2014 07:57 PM
How do I delete a thread and delete profile ojameyo Help 18 July 17th, 2012 10:48 AM
Smog Block Off Plate - $10 !!! road_warrior64 2008 - 2012 Ninja 250R Tech Talk 5 May 4th, 2012 10:05 AM
