July 5th, 2016, 03:48 AM | #1 |
Join Date: May 2016 Motorcycle(s): GPX250-RII Posts: 296
Need help with some paint
What is the best way to remove urethane paint , from the mag wheels and the footpeg sets without sanding ? Is it okay to just use bare aluminum on them for a 1987 bike , or it is dangerous? i had some experience with an old zzr400 where i was bleeding the rear brake then the brake lever just broke off from the whole footpeg set, it doesn't have any paint it was bare aluminum.
July 5th, 2016, 06:43 AM | #2 |
Chemical stripper would be the way to do it, but you would need to disassemble as much as possible and make sure no stripper gets anywhere else.
Bare aluminum will corrode. Most of the parts that look like bare aluminum are clear anodized to keep them from corroding. Bare parts aren't going to be fragile though, so I don't think it had anything to do with the lever braking. Most likely it had developed a crack. |
July 6th, 2016, 03:59 AM | #3 | |
July 19th, 2016, 05:44 PM | #4 |
Chemical strippers like methylene chloride will destroy plastics and most rubbers, but will not harm any metals including aluminum. In fact, methylene chloride was developed to strip paint from aluminum airplane bodies, hence the common nickname of "airplane stripper". Citrus-based strippers aren't anywhere near as effective, but they are safer. MC will kill you if you use it in an enclosed space.
A recommendation is to use a specific brand called Talstrip. It has microspheres and a formulation that makes it into a gel that doesn't run off nearly as bad as regular varieties, and it dries to a flaky consistency that's easy to scrape off with a plastic scraper and is suitable for plain trash disposal. It's pricey, but a little goes a long way. |
July 19th, 2016, 06:14 PM | #5 |
Keep anything containing methylene chloride off your skin and don't breathe the fumes. I know this firsthand. Luckily the damage wasn't permanent, or at least most of it wasn't.
July 20th, 2016, 07:05 AM | #6 | |
I use it daily, and always wear full hazmat gear. MC is bad, but other common additives in chemical stripper like hydrofluoric acid are even more dangerous. |
July 20th, 2016, 08:44 AM | #7 |
I had experience with a paint stripper but im not sure what is the chemical in it , i got it in a hardware store cheap , when it hits any part of my skin , it feels very hot and itchy like an ant bite but far worst . I used that on my aluminum mag wheels , it did hit the tires there was a brown stain that i cant remove eversince but no cracks or whatsoever.
Although my goal was to strip the paint and expose clean shiny aluminum mags instead i got aluminum with white strips , and ended up sanding it buffing it even after the paint stripper , which was triple work, i should had just sanded it down by hand |
July 20th, 2016, 08:59 AM | #8 | |
I assume I don't have any lasting effects, but I guess I can't be sure. My liver function has been normal since then, so that's a good sign. I rarely use MC, and when I do, I make sure I don't breathe it, and I don't get it on my skin. |
July 20th, 2016, 09:26 AM | #9 |
Glad to hear you have recovered completely.
The stuff I use (MC and hydrofluoric acid ) will take your skin right off. I've seen photos of people that have scars from over a year after being exposed. The MC bubbles the skin (just like it does paint or powder) but the hydrofluoric acid continues to leach into your bones even after you think it's washed off, causing all sorts of nasty medical issues. I try to be super careful, but the combination is one of the best coating stripper out there and there are times where nothing else will do what I need. |
July 20th, 2016, 10:39 AM | #10 |
I guess MC has to be on your skin for a long time to do much damage, because back in those days I didn't bother keeping it off, and the worst symptom I ever had after a few minutes of exposure was some redness and a little burning. No matter though, it's bad stuff and needs to be used only with proper precautions like you use, and I use now.
July 20th, 2016, 05:38 PM | #11 | |
July 21st, 2016, 07:19 AM | #12 | |
I'm really careful when working with it. |
Paint, at last | liquidnine | 1986 - 2007 Ninja 250R Farkles | 7 | March 5th, 2016 06:44 PM |
I want to paint my bike - how much paint would I need? | iplante | 1986 - 2007 Ninja 250R Farkles | 40 | October 15th, 2012 03:29 PM |
Can i paint over this? | 2003ninja | 1986 - 2007 Ninja 250R Farkles | 12 | May 21st, 2012 06:17 AM |
PAINT. Yes or No? | massacremasses | General Motorcycling Discussion | 91 | November 16th, 2011 01:05 PM |
Going to paint my race body over the winter! NEED IDEAS FOR A PAINT SCHEME! | 08ninja250 | Ninjettes At Speed | 1 | August 21st, 2010 08:14 PM |
