October 9th, 2012, 01:27 PM | #1 |
Join Date: Oct 2012 Motorcycle(s): Ninja 250 (2007) Posts: 2
Oil pressure light question...
Hi all,
Sorry for the silly question....but should the oil pressure light be turning on when I start my bike initially (it goes off after a few seconds)? Is that normal? |
October 9th, 2012, 01:31 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Yes, that is normal. Anything longer than a few seconds is bad and the bike should immediately be turned off
October 9th, 2012, 01:38 PM | #3 |
Awesome. Thank you so much. I thought I was seeing things....my bike recently got serviced...and go figure, the day after, it got knocked over on the street by some A-Hole. Everything was fine, aside from the left blinker. I just got concerned for a sec and couldn't remember what was "normal".
October 9th, 2012, 07:44 PM | #4 |
Join Date: Sep 2012 Motorcycle(s): 2005 250R Ninja Posts: 35
Yeah this happens cause all the oil rushes to the front because of the momentum of the breaking is throwing it foward.
oil pressure light | contact148 | 2008 - 2012 Ninja 250R Tech Talk | 28 | June 21st, 2018 06:54 AM |
Oil Pressure Light Staying on at Start Up | spacemonkey | 2008 - 2012 Ninja 250R Tech Talk | 50 | October 26th, 2016 10:05 AM |
Oil Pressure Light on Startup | quicklooker | 1986 - 2007 Ninja 250R Tech Talk | 28 | July 19th, 2013 07:16 AM |
Oil pressure switch | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 13 | February 23rd, 2011 06:58 PM |
Oil Pressure Indicator Question | minuslars | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 17th, 2009 10:41 AM |
