March 27th, 2017, 12:10 AM | #1 |
Join Date: Nov 2016 Motorcycle(s): 2005 ninja 250 Posts: 74
Oil question
Has anyone ever had their oil filter cover gasket leak (the one the covers the screen and has 5 bolts? When my bike warms up it leaks Andy starts burning off the motor. When i look under the bike all 5 bolts have oil looking like it is about to drip. Anyone else had this issue?
March 27th, 2017, 01:29 AM | #2 |
If you've taken off, and not replaced the gasket, this can happen.
It's not a big deal just order a new one, and change it out during your next oil change, and while your in the neighborhood, check that screen. Side note:.Kawasaki offers two types of gaskets, paper for the PreGen, and metal for NewGen, I personally use the NewGen one, it can be reused a few times, also suggest picking up a few spare O-rings for the filter, both sizes,,and crush walkers for the drain plugs. Nothing sucks more than doing an oil change and getting a leak, because you didn't replace a O-rings and crush washers. WARNING!!!! do not over tighten those bolts, they are small, and can break if you over tighten them, or strip.
March 27th, 2017, 07:53 AM | #3 |
This section has some tips and more info on oil changes and procedures - http://faq.ninja250.org/wiki/Engine_Oil
March 27th, 2017, 11:10 AM | #4 | |
I personally did the NewGen cover update to my PreGen, no reason bedside just cause I could. http://faq.ninja250.org/wiki/Changin...ver/drain_plug
Question regarding Oil and longevity... | Advincula | The Ex-Ninjetters Lair | 14 | October 2nd, 2015 02:12 PM |
Quick question on Oil | Daakuryu | 2008 - 2012 Ninja 250R Tech Talk | 16 | February 22nd, 2015 09:12 AM |
Fork oil question | sharky nrk | Ninjettes At Speed | 7 | September 13th, 2013 04:00 AM |
Oil question | Maielstrom | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 10th, 2012 11:24 AM |
Oil question | SpYd3r05 | 1986 - 2007 Ninja 250R Tech Talk | 4 | May 10th, 2010 05:14 PM |
