Old October 24th, 2011, 08:41 AM   #1
ejlover
ejlover's Avatar
Motorcycle(s): Ninja 250R 2011
2011 Brake Calipers and Lines Modification
Greetings,
I want to change the stock calipers and brake lines with these items:
http://cgi.ebay.com/ws/eBayISAPI.dll...X%3AIT&vxp=mtr
Will they fith without modification?
For calipers the seller told me that my forks should be set to 84mm from bolt to bolt for mounting. Is it in our ninjas front and rear?
ejlover is offline   Reply With Quote
Old October 24th, 2011, 09:04 AM   #2
it looks like you need to make a plate to go inbetween
Old October 24th, 2011, 09:06 AM   #3
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Not sure about the caliper, but the lines are fine I did a DIY on them. Do they give you an option of colors on ebay?
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old October 24th, 2011, 10:08 AM   #4
almost all motorcycle brake line ends are the same fyi. the banjo bolts vary in length depending on if its 1 or more lines. the ends of the lines can sometimes be bent to accommodate a specific bike, but as long as the line is long enough and is not some weird exotic it should fit... that being said, 100 bucks is really overpaying for 2 steel braded lines
i am actually currently using the ninja brake line on my fzr temporarily
Old October 24th, 2011, 11:56 AM   #5
ejlover
ejlover's Avatar
I could find 1 DIY about it but it shows only front line montage. Couldn't find one for the rear.
Item name says it's for ninja250 so i think bolt ends will fit. But i don't know anything about the calipers. Didn't c anything here about the caliper modification
Old October 24th, 2011, 07:17 PM   #6
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
ejlover,
about the brake lines, you can go to their on-line store http://www.kyleusa.com/ and get them for $94.95. I don't know which has better shipping to Turkey, shipping from their store or their ebay link.
Alex.s,
is there somewhere that has Spiegler brake lines cheaper than $94.95 for both? Just wondered. It's on my to get list, sometime down the road.
kevheads is offline   Reply With Quote
Old October 24th, 2011, 07:19 PM   #7
00NissanNinja
I hate driving...
For the lines there aren't any necessary modifications, its plug and play. For that red caliper you posted there will probably be modifications required.
Probably a few of the reasons spiegler is more expensive is
1. There are many color options to choose from.
2. They build them on order (It doesn't take them long to do though).
3. The lines are DOT and something else certified which most ss lines don't care to worry about. Plus you get a lifetime warranty.
Old October 24th, 2011, 11:33 PM   #8
ejlover
ejlover's Avatar
Thanks for the information
Then I'll go with caliper caps instead of replacing them and change the lines later when the stock ones needed to be replaced Thanks to you all
By the way I also found this SS lines:
http://www.ebay.com/itm/110719426509...84.m1423.l2649
They are also DOT approved and comes in different colors. A little cheaper option for the ones who want to change their brake lines
Old October 24th, 2011, 11:54 PM   #9
cheapcycleparts.com
Old October 25th, 2011, 05:54 AM   #10
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
dude why you want an ugly ass fake Brembo caliper??? Stock is perfectly fine....
LoneRonin is offline   Reply With Quote
Old October 25th, 2011, 06:20 AM   #11
dubojr1
dubojr1's Avatar
This thread could have done without your opinion...
Old October 25th, 2011, 06:36 AM   #12
DaBlue1
DaBlue1's Avatar
Looking at the picture of the caliper, the brake pads look smaller than stock and the caliper most likely needs a mounting plate as well. Mounting bolt holes on the Ninja forks (center to center) is much smaller than 84mm. It's more like 4.8 cm (48 mm). I'd be a little cautious at buying a brake caliper for $25.00.
If you are wanting to improve braking performance, keep your stock calipers, change to SS lines and get some new pads.
http://japan.webike.es/products/9363732.html
Last futzed with by DaBlue1; October 25th, 2011 at 09:19 AM.
Old October 26th, 2011, 04:16 AM   #13
ejlover
ejlover's Avatar
Thanks That's helpful and I decided not to buy that cheap sh.t lol
Brake calipers fishdip 1986 - 2007 Ninja 250R Tech Talk 16 December 20th, 2013 11:42 AM
swapping brake calipers james250ninja 1986 - 2007 Ninja 250R Tech Talk 4 October 5th, 2013 08:08 PM
Brembo brake calipers for the 250??? Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 29 November 16th, 2011 03:21 PM
Gold Brake Calipers??? dubojr1 General Motorcycling Discussion 40 January 14th, 2011 07:55 AM
[roadracingworld.com] - More About The New Brembo Brake Calipers On Suzuki's Newest G Ninjette Newsbot Motorcycling News 0 October 12th, 2010 09:50 AM
