Old April 23rd, 2011, 10:58 AM   #1
ladyrocket
ladyrocket
ladyrocket's Avatar
Motorcycle(s): 09 Ninja 250R
Gasket?
Getting ready to tear my bike apart to re-jet the carbs. I havent seen anything about replacing gaskets on the carbs. Does anyone know if there are gaskets on the carbs??? Thanks guys!
Never ride faster than your angel can fly
ladyrocket is offline   Reply With Quote
Old April 23rd, 2011, 11:42 AM   #2
you should be okay with whatever is in there now, if your bike is a newgen.
Old April 25th, 2011, 08:40 PM   #3
ladyrocket
ladyrocket
ladyrocket's Avatar
Thanks
Old April 26th, 2011, 06:35 AM   #4
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
To clarify, the carbs are for the most part assembled with reusable O-rings which rarely go bad and even then it's typically due to extreme age and poor quality work by previous mechanics/owners. The one thing to be very careful about are the diaphragms for the slides, they're under the two covers on top of the carbs held in place with 4 screws each. Do not tear these, be very careful how you pull them loose from the carb body. Also, do not allow any cleaner to come in contact the rubber; I've seen more than one ruined by this.
Old April 26th, 2011, 04:01 PM   #5
ladyrocket
ladyrocket
ladyrocket's Avatar
Finished up everything this weekend and the bike is running GREAT! thank you for your help
Old April 26th, 2011, 04:15 PM   #6
what exactly did you do?
Blown gasket? Christofini 2008 - 2012 Ninja 250R Tech Talk 6 November 8th, 2013 10:48 AM
oversize gasket... micoulisninja 2008 - 2012 Ninja 250R Tech Talk 7 November 3rd, 2012 09:46 AM
head gasket? NorthKoast 2008 - 2012 Ninja 250R Tech Talk 14 March 10th, 2012 04:01 PM
Re-use old head gasket ? Tony B 1986 - 2007 Ninja 250R Tech Talk 10 June 1st, 2011 06:27 AM
exhaust gasket? 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 3 June 25th, 2010 03:17 PM
