Old October 27th, 2013, 02:45 PM   #1
parox91
Name: Not Applicable
Motorcycle(s): 2007 Blue Ninja 250
Issue with K&N pods
So i got the K&N R-0990 and installed it on my bike and after installation, the bike would only run with full choke and when given any throttle it would die.
I have a dynojet kit so I replaced the jets with 114's and turned the idle mixture screws out to 4 turns, still have the same issue... not sure if it's running too rich or too lean.
I know my bike is a PITA but come on!
Edit: using stock exhaust.
parox91 is offline   Reply With Quote
Old October 27th, 2013, 02:48 PM   #2
quarterliter
Motorcycle(s): 2004 Ninja 250
Um arent the dynojet jets larger than the keihins for the same number? Think your main is way to big.
Old October 27th, 2013, 04:19 PM   #3
infinitewhiskey
meh
Motorcycle(s): 2002 EX250F Cafe/Streetfighter Project
114 and idle out 4 turns is way rich for just pods.
I'm running Keihin 110 (or 108, forgot, probably 110 though) main jets, idle at 3.5 turns, and 2 shims on each needle, at an 860 ft elevation with a ****** 2-1 exhaust and slip on.
The FAQ guide if you haven't seen it yet.
SoCal 626/951
instagram | youtube | modifications
infinitewhiskey is offline   Reply With Quote
Old October 27th, 2013, 05:26 PM   #4
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Wouldn't touch the idle screws until you get the mains dialed in.
I have factory pro jets but just for reference I went to 110 mains from the stock 105s when I threw pods on at sea level....
Mods: Offset clutch pressure plate
Old October 27th, 2013, 06:06 PM   #5
parox91
Alright, so i dropped in 110 jets like you guys said, and my baby fired right up. oh boy does it sound a lot meaner than before... managed to bunny hop it on the on-ramp getting on the highway lol.
You're right about 4 turns out being too much, the mixture is rich but im happy it's working now, I'm gonna tinker with that the next chance i get.
Thanks guys for all your help. Now to find a place with a cheap front tire to get rid of wobbles...
Old October 27th, 2013, 06:13 PM   #6
rebalance your front tire and adjust the slop out of your stem
Old October 27th, 2013, 06:21 PM   #7
parox91
i dont think that's going to help, they repaved my road and the bump to one of my driveways got really sharp... i've hit it hard a few times on my ninja so i think my tire might be getting warped
Old October 27th, 2013, 06:28 PM   #8
pick the front end off the ground and spin the front tire to check for irregular shape. I've never heard of a warped tire, but it's worth checking for I guess.
Old October 28th, 2013, 06:41 AM   #9
parox91
I ordered a perelli sport demon to replace my bt 45 in the front, thanks for your suggestions but this tire really has to go, cornering is getting epic scary.
Free: K&n 0990 pods Trailerboy531 Free stuff! 10 September 11th, 2013 01:45 PM
Added lights to the rear pods - now having issue iplante 1986 - 2007 Ninja 250R Farkles 5 July 24th, 2012 12:47 PM
Jetting for K&N Pods 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 10 January 25th, 2011 11:44 AM
Chopped fender & Installed lights in pods Snake 1986 - 2007 Ninja 250R Farkles 22 January 19th, 2010 12:48 AM
k&n drop in vs pods Digiadaamore 2008 - 2012 Ninja 250R Tech Talk 24 October 1st, 2009 08:09 PM
