Old April 4th, 2014, 11:50 AM   #1
mr2peak
Motorcycle(s): Hyper 821
Clutch issues. Won't disengage, searched, tried, help
So. I bought the bike with a broken clutch cable. Just replaced it, and it seems like it is way too long. I just put new oils in the bike so I'm hesitant to pull the clutch cover and see it it's actually engaged. The PO messed with the bike a little bit, but I don't think he ever pulled the cover off, seal looks original and the bolts don't look like they have been touched. What's the best corse of action?
The lever has freedom of movement from the 9-11 o'clock position. Is this correct? There's no spring force at all :/
mr2peak is offline   Reply With Quote
Old April 4th, 2014, 11:54 AM   #2
Pictures might help to diagnose. The part of the cable that attaches right down near the clutch cover on the right side of the bike is sometimes wonky when reattaching, and you need to rotate it a certain way to get it in the appropriate position where it catches. I think @alex.s has some instructions on here about how to confirm that.
Old April 4th, 2014, 12:03 PM   #3
mr2peak
It's definitely in the correct position. I'm just wondering what the "resting state" of the clutch lever is.
Old April 4th, 2014, 12:04 PM   #4
When adjusted correctly, the lever should have just a few mm of play.
Old April 4th, 2014, 12:05 PM   #5
points to 8:30 at rest
Old April 4th, 2014, 12:07 PM   #6
DaBlue1
DaBlue1's Avatar
Did you measure the two cables up against each other to see of the were the same length?
Did you lift up on or remove the clutch shift rod (end with the clevis) and spin it either direction? If so, read this....http://www.ninjette.org/forums/showp...0&postcount=12
There are two place to adjust the clutch. Try loosening it at the lever first then adjust it properly at the clutch (on the engine).
Loosen the adjuster bolts a little, then fine tune the adjustment at the lever.
Pull the clutch lever just enough to take up the free play
Measure the gap between the lever and the lever holder.
If the gap is too wide, the clutch may not release fully.
If the gap is too narrow, the clutch may not engage fully.
In either case, adjust it. Clutch Lever Free Play Standard is: 2 ~ 3 mm
Old April 4th, 2014, 12:12 PM   #7
mr2peak
Ah. This is most likely the problem. I can move it with my finger with no resistance all the way to the 11 o'clock position.
I've tried tightening the cable all the way on both ends, no difference, just hits a wall at 11 o'clock.
Eating lunch right now, I'll throw up some pics after. I don't have a clutch cover gasket so I'm trying to avoid taking the cover off. All I can think is that it's not engaging?
Old April 4th, 2014, 12:17 PM   #8
mr2peak
Haven't messed with the shifting at all. Shifted into first, 2nd, etc on the stand no problem, just won't disengage. Took it off the stand and shifted back into neutral. Tried rocking the bike back and forth in gear with a friend to see if the plates are stuck, no changes.
Old April 4th, 2014, 12:37 PM   #9
it sounds like the little metal dowel that pulls on the throw bearing to disengage the clutch is broken in half or missing
Old April 4th, 2014, 12:41 PM   #10
mr2peak
Damn. Well I'm about to pull it apart, let's find out.
Old April 4th, 2014, 12:47 PM   #11
order a new gasket. they always break.
Old April 4th, 2014, 01:20 PM   #12
mr2peak
So the clutch springs were stuck. 2 of them were fully compressed and require some fiddling to remove.... And then boiiiing! Still searching for one of the alloy washers.
So it's looking good so far. Thanks for the prompt responses, super helpful forum.
I ordered a new gasket earlier this week but it hasn't shown up yet. The old one is fine, so I'll test ride it then re-do it along with a few other things next week.
Classic car races at Infineon this weekend, no time to work in the bike :/
Old April 4th, 2014, 01:42 PM   #13
i bet a "fonz" kick would have set her straight. lol
Old April 4th, 2014, 02:06 PM   #14
mr2peak
Haha.
This gets even better. F***ing PO.
The springs were way beyond their service life, so instead of ordering new ones the PO put an extra washer between the spring and the normal washer/bolt. These washers got stuck on the end of the spring posts (not sure what to call them?) and held the clutch tight.
Solution? New EBC springs from the local shop. $10 to do it right.
PO needs a nads kick.
Old April 4th, 2014, 06:44 PM   #15
mr2peak
Got it back together, then dissasembed the carbs. Got her running and I was about to ride when....
The clutch slipped. Like, I can't even go forwards. Everything seems to be in great shape on the inside, so I'm kinda lost at this point. The springs are fully tightened down so I'm not sure what the problem is.
Old April 4th, 2014, 06:49 PM   #16
mr2peak
What is the wear limit for the clutch plates?
Old April 4th, 2014, 08:08 PM   #17
Evidently just past where yours are.
(Sorry, couldn't resist. I hope you get it sorted. )
Old April 4th, 2014, 08:28 PM   #18
mr2peak
Ha
I wish my service manual was here already :/
Anybody have a service limit for the plates?
Old April 4th, 2014, 09:58 PM   #19
according to google
standard 2.9-3.1mm
service limit is 2.8
but i would be concerned about the previous problem. the springs and hub getting stuck. you might want to disassemble and look for damage just because taking things apart is fun.
Old April 4th, 2014, 10:33 PM   #20
mr2peak
Already did, thanks again
I have a few replacement clutch baskets in the mail headed my way. Planning on rebuilding one for myself and fixing up the other two. So it's all coming apart again anyway. Clutch is pretty loud right now.
Old April 5th, 2014, 03:02 AM   #21
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
You have lined up the marks, haven't you?
baxtc1 is offline   Reply With Quote
Old May 5th, 2014, 04:32 PM   #22
Joshua763
Motorcycle(s): five honda's one harley one ninja most have sold all where fun.(one honda was a moped)
helpful adjustment tips or facts.
Joshua763 is offline   Reply With Quote
Clutch Won't Disengage Gmon 1986 - 2007 Ninja 250R Tech Talk 21 September 23rd, 2019 09:31 PM
Clutch basket q's *searched* iceman.kcmo 1986 - 2007 Ninja 250R Tech Talk 11 February 10th, 2012 09:10 PM
Clutch doesn't fully disengage power when pulled in. reaubideux 2008 - 2012 Ninja 250R Tech Talk 11 November 3rd, 2011 10:11 AM
Another Clutch Issue...Cannot Disengage! Littlefreak 1986 - 2007 Ninja 250R Tech Talk 8 March 13th, 2011 09:15 PM
Improperly disengage clutch ~ revs high, lower speed. Ntotot 2008 - 2012 Ninja 250R Tech Talk 12 August 26th, 2009 10:48 PM
