April 9th, 2012, 02:16 PM | #1 |
Join Date: Feb 2012 Motorcycle(s): '09 Ninja 250r (SOLD) - Black. 2011 ZX-6R Green/Black - 2001 Garbage Bag Green KLR650 Posts: 275
OEM Tool Kit - What's in it
Well....just like the title says. The used bike I bought didn't have the tool kit or owner's manual with it.
What is in the tool kit? I just want to know so I can either go and pick up the tools individually or if it's worth picking up the kit at the local dealer. Thanks! |
April 9th, 2012, 03:12 PM | #2 |
Join Date: Oct 2009 Motorcycle(s): 2008 Triumph Bonneville Black Posts: 627
Just a couple of cheap wrenches, pliers, allen keys and screwdrivers. The only worthwhile thing in there is the wrench used to adjust the rear spring preload.
A small socket set, allen key set, and #2 phillips screwdriver is probably all you need to strip the bike down as far as you'd ever want to go. http://www.mrcycles.com/fiche_sectio...008&fveh=38174
'08 Bonneville Black sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator |
April 9th, 2012, 04:33 PM | #3 |
So, where's the reverse?
There's also a tool in the kit that is used to remove the spark plugs. Makes life a lot easier if/when you need to get to them.
April 9th, 2012, 05:00 PM | #4 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
+1 for the spark plug tool.
April 9th, 2012, 08:12 PM | #5 |
I always wondered what that thing was!
April 9th, 2012, 08:19 PM | #6 |
2012 Ninja 250R Green
Join Date: Nov 2011 Motorcycle(s): 2012 Ninja 250R Green Posts: 76
Mine came with a cheap plastic tire pressure gauge.
Not related to your topic but I see you have a Lancer GTS from your avatar pic. I see you have blackened the front end what other mods you do? I got an 08 gts blue as well. |
April 10th, 2012, 06:19 AM | #8 |
Thanks for the reply guys, so I guess I'll be better off putting together a little kit myself with some spare tools from around the garage.
@Pudge Ate Me: Yeah, it's an 09 GTS. Nothing much, mostly cosmetic things. I did a Bi-Xenon projector retrofit, a set of dark bronze wheels for the summer and a takeda SRI. I take possession of my bike on May 5th, so until then I needed something for an avatar pic. |
April 13th, 2012, 11:12 PM | #9 |
I've used the included pipe handle and spanner or axel-nut wrench to get leverage with allen keys at an angle. I like the kit, thought the screwdrivers are completely useless (can't even remove the side covers).
WTB 2008+ OEM tool kit | evidens83 | Items Wanted | 0 | February 13th, 2014 07:13 PM |
Oem tool kit and rear tire huger | Yaozer | Motorcycle-related | 7 | December 3rd, 2013 12:22 PM |
WTB: Ninja 250 OEM tool kit | tfkrocks | Items Wanted | 7 | September 24th, 2013 12:34 PM |
