April 19th, 2016, 11:56 AM | #1 |
Join Date: Sep 2015 Motorcycle(s): 2009 Ninja 250R Posts: 56
throttle cable adjustment
My throttle has too much play, but I can't seem to adjust it at the lever end. I can't really make sense of the adjuster there. It's really hard to turn, and doesn't seem to have any effect. I could just adjust it down at the other end, but I was wondering if there is some trick to using the adjuster at the lever?
April 19th, 2016, 01:37 PM | #2 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 478
If the EX250 is the same as the ZZR250, then there is an outer locking wheel, which you loosen, then turn the inner adjuster counter clockwise to take up slack innthe pull cable. When you have it as required, then use the outer wheel to lock it in place.
The carb end has a rough adjuster, if you go there, make sure the throttle end is full in, then adjust at the carb end & finish the fine adjustment at the twist grip. |
April 19th, 2016, 02:21 PM | #3 | |
EDIT: got it. The adjusting nut was just very hard to turn, and also springy - every time I let go it wants to rotate back again. I eventually got it with the pliers, though it looks bit rough now lol. |
April 19th, 2016, 05:44 PM | #4 | |
It will be better if you avoid using pliers for adjustments and maintenance work. All the nuts and bolts of your bike are metric. A set of metric wrenches is not expensive and can be used on the same nut over and over again without causing any damage. http://www.harborfreight.com/hand-to...set-42305.html
April 19th, 2016, 06:11 PM | #5 | |
April 19th, 2016, 06:15 PM | #6 | |
April 19th, 2016, 06:17 PM | #7 |
I believe that is what racingninja is talking about. You can actually turn them with a wrench. My argument is that its not any easier.
April 19th, 2016, 06:33 PM | #8 |
Vintage Screwball
MOTM - Mar '16
Goin' fast on slow bikes! |
April 19th, 2016, 06:45 PM | #9 |
Its not like a standard nut its a circle with like 50 edges you can use a wrench or a pair of pliers. Or maybe not and I'm thinking if a different type of nut. Either way, its late and I'm not thinking straight.
April 19th, 2016, 06:50 PM | #10 | |
The reason RacinNinja is confused is because he didn't post on this thread, it was Motofool |
April 19th, 2016, 07:04 PM | #11 |
Vintage Screwball
MOTM - Mar '16
April 19th, 2016, 07:07 PM | #12 |
If you are talking about the throttle cables, please, read these:
http://faq.ninja250.org/wiki/Adjusti...hrottle_cables http://faq.ninja250.org/wiki/Throttl...is/re-assembly http://faq.ninja250.org/wiki/Lubing_the_cables Keep all the cables clean and lubed. Often, when the regulator of any cable is not sufficient to eliminate the slack, the cable is in its way out, with some broken strands of wire and it has elongated beyond adjustment. Yes, for the round counter-nut of the clutch cable, you can use pliers, but you can protect its surface using a piece of leather or sandpaper between the jaws and the nut.
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; April 20th, 2016 at 10:34 AM. |
April 20th, 2016, 05:49 AM | #13 |
Well, in that case I would like to apologize to motofool and racingninja.
April 20th, 2016, 10:34 AM | #14 | |
Here is additional info about Bowden cables, just in case @divil is interested: https://en.wikipedia.org/wiki/Bowden_cable
Cable adjustment perch hole stripping | indr | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 1st, 2013 05:25 PM |
Fine throttle cable adjustment assembly broken. | setasai | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 18th, 2011 09:10 PM |
Help. Idle Adjustment Knob cable came off. | RyanJames | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 2nd, 2010 11:22 AM |
Throttle & Throttle Cable Smoothness | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 1st, 2009 01:50 PM |
Clutch cable adjustment | SteveL | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 17th, 2009 12:39 AM |
