Old July 19th, 2016, 08:48 AM   #1
divil
Bedding in new brake pads
I'm planning to do a track event soon but my brake pads are kind of low. I'd prefer to have new pads, and I was thinking of getting EBC pads, but their bedding in period is 200 miles and I probably won't get anywhere close to that in time. If I can only do around 50 miles or so before the track event, would that be enough, or would I be better off sticking with the pads I have?
divil is offline   Reply With Quote
Old July 19th, 2016, 09:02 AM   #2
No, because you might fail tech with worn out pads. Some of us that work tech do check such things.
Here is what I do "at the track".
Ride a novice session and go slow enough to use only very light braking to no braking at all. This first session is used to scuff the pad, to get it hot and then cool back off, rinse and repeat as the session time permits.
Next session is harder braking to test the feel and begin matting the pad to the rotor. If things feel fine, then I will finish the session riding as I normally would.
I will then keep an eye on the rotor and pad for glazing for the next two days worth of riding.
I have been riding for 20yrs+ and have NEVER rode 100/200 miles on pads to break them in. But there is no reason this can't be done on the street at slower paces before you track day. In fact, that is what I would do. So when you get to the track, you are focusing on YOU vs your bike's parts.
Old July 19th, 2016, 10:02 AM   #3
divil
Thanks. I'll get it done on the street.
Bedding in track bike pads adouglas Ninjettes At Speed 12 December 14th, 2015 09:04 AM
Cant find brake bolt connecting brake pads. Trubin General Motorcycling Discussion 6 June 3rd, 2014 05:35 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
Brake pads jack_bm 2008 - 2012 Ninja 250R Tech Talk 10 May 29th, 2012 12:34 PM
brake pads bedding-in Skippii General Motorcycling Discussion 10 February 11th, 2012 05:56 PM
