Old July 13th, 2012, 06:14 PM   #1
arnoldc6
arnoldc6's Avatar
Motorcycle(s): 09 ninja 250r
Downshifting- release clutch or not?
There's already copious number of other threads out there discussing about this same topic, but i just want some opinion from other ninja riders.
When you are slowing down at a redlight and downshifting, do you release your clutch (and prehaps roll your throttle) everytime you shift to a lower gear?
"trust me, I am not a lawyer."
arnoldc6 is offline   Reply With Quote
Old July 13th, 2012, 06:18 PM   #2
xSean13
xSean13's Avatar
I throttle blip down to about 2nd as i'm slowing down, then shift to 1st with the clutch still in while coming to a stop.
Old July 13th, 2012, 06:28 PM   #3
depends on the situation, i do both.
Old July 13th, 2012, 11:32 PM   #4
arnoldc6
arnoldc6's Avatar
do you guys mean to just use engine braking instead of actual brake?
Isn't that bad for the gear box?
And how high do you pull you engine rev up to before ferther downshifting?
Old July 14th, 2012, 12:39 AM   #5
bad for your piston rings maybe. your gear box isnt going to have any issue with it. you can still use brake while the engine is engaged.
Old July 14th, 2012, 12:43 AM   #6
Zombiphone
CVMA/AFM #72
Zombiphone's Avatar
Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike)
I engine brake the **** out of all my bikes and none have exploded yet. Seems legit
Zombiphone is offline   Reply With Quote
Old July 25th, 2012, 05:57 PM   #7
RyderRider15
Ate his own face. Twice.
RyderRider15's Avatar
Motorcycle(s): 2009 Ninja 250r, 2009 KLR650
I do all three ways, depends on the situation. I'll generally use both engine breaking and normal breaking, however I also only do normal breaking or only use engine breaking. If I'm only using engine breaking its most likely because I was moving slowly and didn't want to completely stop, and if I'm only using normal breaking its because I want to stop quickly and don't want to waste time.
http://www.youtube.com/user/RyderRider15?feature=mhee
Gear whore score: 74
RyderRider15 is offline   Reply With Quote
Old July 25th, 2012, 06:19 PM   #8
RiderOnTheStorm
Motorcycle(s): Blue 08 250 - Blue Magic
I double clutch down - clutch in, blip, clutch out - while I brake unless I need to stop fast at which point my focus is smooth, firm braking.
I would recommend it. Just because you think you will be coming to a stop, doesn't mean you will. Imagine if you're slowing down and someone all of a sudden pulls some bonehead maneuver in front of you, I would want to be in a gear with the ability to roll on the throttle so I could respond and avoid the situation.
And over time, my goal is to develop where I can cover the brake and throttle allowing me to downshift while applying the brake.
RiderOnTheStorm is offline   Reply With Quote
Old July 25th, 2012, 06:45 PM   #9
Yes for slow deceleration.
For quicker stop or slow down, I skip the clutch out every second shift and blip.
For emergency braking, I skip all the clutch outs', but still shift and blip.
Old July 25th, 2012, 07:54 PM   #10
offrdjeep87
offrdjeep87's Avatar
My MSF instructor told us to never slow down using engine braking because 1) the brake light won't come on to let the cagers behind you know that you are slowing and 2) if you get into that habit and need to stop quickly all of a sudden, you're first instinct will be to downshift instead of applying the brakes. I'm not sure how true this is, but it's what I was told so i thought I'd add my input.
offrdjeep87 is offline   Reply With Quote
Old July 25th, 2012, 09:20 PM   #11
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
You can blip downshift while still on the brakes. I do this on the street because I do this on the track
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old July 26th, 2012, 04:18 AM   #12
double clutching is what truckers do. Clutch in, clutch out, shift gears, clutch in, clutch out. Motorcycles and most cars do not require the drivers to double clutch.
Anyhow, you'll get there with braking and blipping to downshift. Just do them separately and then put them together. As for the msf people suggesting not engine braking, pfft. I use the brakes to slow and blip/shift to match gears in case I need to take off again, its not like I rely on my engine to slow down. I'm 110% positive that when people pull out on front of me, I brake, not engine brake.
Posted via Mobile Device
Old July 26th, 2012, 04:00 PM   #13
Lychee
sail away
Lychee's Avatar
Won't your bike slow down faster if you are downshifting but do not blip the throttle?
Brake on, clutch in, click down, (no blip), clutch out, etc.
Related- will this method damage your bike's internals?
Edit: I suppose this method is what is meant by "engine braking."
Last futzed with by Lychee; July 26th, 2012 at 04:09 PM. Reason: light bulb in head
Old July 26th, 2012, 04:03 PM   #14
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
This
I used to take my 650 from 80mph to 5mph without brakes
That bitch engine brakered like a mofo
AFM #676
Supersports are for n00bs
Old July 26th, 2012, 04:09 PM   #15
Originally Posted by Lychee View Post
Will your bike slow down faster if you are downshifting but do not blip the throttle?
maybe, but it won't be smooth and you'll look like an idiot with your head swaying back and forth with the lack of braking followed by the braking.
Also, clutch wear from not blipping at all. Blip and be done its smoother, faster, and once you get that muscle memory, it is automatic and requires no thought at all, which can them be directed at the road in front of you
Old July 26th, 2012, 05:40 PM   #16
Lychee
sail away
Lychee's Avatar
I meant a combination of brake and downshifting, and in an emergency. Looks don't matter when survival is at stake.
True for a normal stop. In an emergency, I'd sooner replace my clutch than my front end.
Last futzed with by Lychee; July 26th, 2012 at 05:42 PM. Reason: forgot multi quote
Old July 26th, 2012, 06:31 PM   #17
Maybe a clarification is pertinent:
Downshifting, blipping, engine-braking and breaking the engine are not the same thing.
Old July 26th, 2012, 07:20 PM   #18
RiderOnTheStorm
Double clutching involves the throttle; you're trying to matching RPMs to input shaft speeds for a smooth shift. I suppose on a motorcycle it's technically not "double clutching" because you only use the clutch once.
We can discuss more when we have our NE Ohio ride!
To the OP, as several have highlighted, it makes the downshifting much smoother and I believe would lead to less clutch wear, so it's something to put in your riding toolbox.
Old July 27th, 2012, 02:05 PM   #19
dcx4610
Motorcycle(s): Ninja 250R
Stop sign, no. Just hold in the clutch and kick down at a good pace while braking until I'm fully stopped and in first gear. Red light, downshift and blip just in cause you need to accelerate again on a light change.
dcx4610 is offline   Reply With Quote
Old July 27th, 2012, 02:34 PM   #20
seanshawnS
Motorcycle(s): Ninja250r(2012PR)
Same. Initially I just held the clutch in and dropped down, which I guess is ok if you're coming to a complete stop. Anyway working your way down through the gears feels slightly more.. proper?
Either way I brake as I'm slowing down to smooth the shifts out.
seanshawnS is offline   Reply With Quote
Old August 10th, 2012, 10:01 PM   #21
the_saint
the_saint's Avatar
Motorcycle(s): K2 GSXR 1000 and When it is released a 2013 Ninja 250r
Here is a good video explain downshifting.
the_saint is offline   Reply With Quote
Ninja 250r release comp clutch issues sixstring 2008 - 2012 Ninja 250R Tech Talk 28 September 9th, 2017 07:16 PM
Downshifting Probs indr 2008 - 2012 Ninja 250R Tech Talk 15 June 30th, 2013 09:43 AM
Downshifting akshay11 Riding Skills 17 March 18th, 2012 02:52 PM
clutch release problems big duke 1986 - 2007 Ninja 250R Tech Talk 3 November 17th, 2011 01:11 AM
[topix.net] - Harley-Davidson scheduled to release first quarter results - www.Clutch Ninjette Newsbot Motorcycling News 0 March 20th, 2009 11:00 AM
