November 8th, 2013, 11:57 AM | #1 |
Join Date: Mar 2013 Motorcycle(s): '08 Ninja 250R Posts: 69
Shock replacement - VTR1000?
Hey all,
I’m looking to replace my rear shock as I’ll be doing a lot of 2-up and it bottoms out on these roads. I’ve scoured the forums and wiki and saw that GSXR600 or Ninja 500 shocks are the usual replacements. The lowest I can get one around here is about 140 dollars shipped though - slightly on the high side for me. I have access to a VTR10000 SHOWA shock for cheap - will it fit, without too much hassle, and will it raise the rear too much? I’ve looked around but it seems every website gives me different information - total height, mounting sizes etc. Does anyone have experience with a VTR? Do you think it’d fit? Apparently the average height is 37cm...it’s fully adjustable. Thanks in advance! :-) |
November 8th, 2013, 02:04 PM | #2 |
i took a google and it looks like it might work out. you need to find out the inside width of the bottom fork on the shock and the size of the eyelet as well as the outside diameter of the case around the eyelet. don't forget about spring rates on the new compression ratio that the ninja triangle knuckle provides. i believe its 0.65
it sounds like its about 2 inches longer than the stock shock so you will need longer dogbones to accomodate it. be careful because this will rotate the shock knuckle down further and it might create clearance problems. worst case you'll have to use a different triangle knuckle. i have an r1 shock with r1 knuckle on one of my 250s and a gsxr shock with stock knuckle on the other.
November 10th, 2013, 07:07 AM | #3 |
Thanks Alex, looks like the VTR would just barely fit...the spring rate is way too high though. My brother found a very cheap GSXR shock for $9...he'll be bringing it over during his Xmas break
1996 ZX600C shock or 2010 300 shock | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 9 | April 30th, 2014 05:35 AM |
replacement parts | reabo | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 4th, 2013 08:22 AM |
Speedometer replacement | siebadn | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 18th, 2012 08:44 PM |
[faster and faster] - Face-off: Honda NR750 vs VTR1000 SP2 | Ninjette Newsbot | Motorcycling News | 0 | July 22nd, 2011 01:50 AM |
Replacing my rear shock with a newgen rear shock... | ReDnEcK | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 10th, 2010 12:38 PM |
