Old April 28th, 2021, 03:38 PM   #1
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
Questions: Pilot jets and fan switch ...
Hi guys,
I'm in the process of bringing a Y2K Ninjette back to life. I got it started a few days ago (Yay!). It's running, but it seems really lean at idle. Slow coming off idle, and it hangs on the way back down. The carbs are clean, it has a new stock air filter, the F-A screws are about 3 3/4 turns out, so I don't have much more room there. It occurs to me that I may need to simply go to the next size pilot jet. Is that done on these bikes? I've had other bikes where it was done as a matter of course because they're set lean from the factory. If yes, what is the next size and where do you typically buy them?
On to the fan switch. The engine got pretty hot today in the garage, but the fan never came on. I was able to jump the switch to get the fan working. The fan itself is OK. I noticed that the temperature barely came off the left stop, even though it was pretty hot. Do I have a bad fan switch? Does the temperature gauge take its data from the fan switch, or from somewhere else?
Thanks in advance,
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Old April 28th, 2021, 04:53 PM   #2
I'll comment on jetting (only)....
an otherwise stock EX should not require up-jetting. Provided carbs are, in fact, truly clean. I'd dissuade compensating for other (transition and pilot) circuit related issues as the bike, at one time, ran awesome with OEM #38 pilot jets.
Old April 28th, 2021, 06:14 PM   #3
SibSerge
The temp gauge and fan switch are totally independent. The gauge is in the thermostat housing , the fan switch is in the radiator on the left side. My fan comes on when the needle is around the middle of the gauge face.
Old April 29th, 2021, 02:46 AM   #4
Jim Moore
Jim Moore's Avatar
Thanks fellas.
Jim Moore
Jax, FL
I Think My Pilot Jets Are Plugged Robb235 1986 - 2007 Ninja 250R Tech Talk 55 March 23rd, 2020 05:55 AM
Pilot jets KaTyStew 2008 - 2012 Ninja 250R Tech Talk 5 October 15th, 2016 04:09 PM
FS: Genuine Keihin 42 Pilot Jets GlassAnkles Motorcycle-related 0 March 27th, 2013 10:19 AM
Changing pilot jets on a stock 250 shadowman 2008 - 2012 Ninja 250R Tech Talk 4 March 15th, 2012 08:49 AM
WTB #40 Pilot Jets tjkamper Items Wanted 1 August 29th, 2010 05:32 PM
