Old June 17th, 2014, 09:42 AM   #1
momoru
momoru's Avatar
Motorcycle(s): 2005 Ninja 250R
Bike Won't Start
I just bought my Ninja this spring, and it's always started like a champ. Tried to start it today and it cranks but won't start. Every now and then I'd hear a combustion or two.
I drained my float bowls, and there appeared to be the tiniest amount of water (like air bubbles?).
I'm guessing next step is to check the spark plugs, but I worry I've flooded it at this point, is there anything to do to fix the flooding besides closing the choke, opening the throttle, and draining the bowls? I saw other people saying they drained the oil too? Any way to know if that's necessary, or what else to look for in my starting issue?
momoru is offline   Reply With Quote
Old June 17th, 2014, 11:25 AM   #2
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
I'm familiar with two ways to overcome or correct an over choked condition. the first is to give it full throttle while attempting to start. The other is to remove the spark plugs and turn the engine over several times to clear the over rich fuel/air combination in the cylinders. Don't give it any throttle while doing this. Then replace the plugs and start normally.
If you've potentially drained the battery while getting it to crank, jump it from a car battery, but be sure the car engine is off. Jumping from a running car can damage the bike's electronics.
flitecontrol is offline   Reply With Quote
Old June 17th, 2014, 11:47 AM   #3
momoru
momoru's Avatar
Thanks, I did finally get it started. My follow up is trying to diagnose why this happened. I'm going to change the spark plugs, oil, etc... because it's around the 6k mile point anyway. But I suspect the reason for the not starting is my garage is not 100% sealed, and moisture gets in, which in turn gets into the bike. I notice it's usually a little harder to start after it's been raining, and there did seem to be moisture on the ground today. Is there anything I can do to keep the bike from getting moisture in the engine when it's in the garage?
Old June 17th, 2014, 11:54 AM   #4
Temps and time yo. Is your garage a controlled temp? If not, the swings in temp can/will cause condensation to form in various places. And yea, stabil will negate most of the negatives of water in gas when just sitting for longer periods of time.
Edit: Ensure you gas tank overflow drain is clear, it can drain off water that enters around the gas cap too.
Old June 17th, 2014, 12:58 PM   #5
momoru
momoru's Avatar
Garage is detached and not temperature controlled. I ride the bike at least 3 times a week, should I still use Stabil? Was definitely planning on that for winterizing.
Old June 17th, 2014, 01:01 PM   #6
Use stabil and you're riding 3 times per week? Naw... Maybe just a tank of bad gas, try another station next time.
Old June 18th, 2014, 08:34 AM   #7
If you thought you had water in the floatbowls when you drained them, you need to remove the tank and drain it - there's probably more in there.
Run ethanol-free 87, or the lowest grade of fuel without ethanol (that may be Premium) and keep the tank as full as possible. That will cut down on the chances of condensation forming.
Bike won't start !HELP! carterdenny 2008 - 2012 Ninja 250R Tech Talk 7 June 5th, 2014 08:40 AM
bike won't start. tried everything rabies 1986 - 2007 Ninja 250R Tech Talk 17 September 22nd, 2013 04:46 AM
Bike won't start chowbray 2008 - 2012 Ninja 250R Tech Talk 20 March 21st, 2011 07:51 PM
Bike won't start. Need help please. mychelle 2008 - 2012 Ninja 250R Tech Talk 29 November 5th, 2010 10:36 AM
