November 2nd, 2011, 12:56 PM | #1 |
Join Date: Sep 2011 Motorcycle(s): 2009 SE Ninja 250 Posts: 83
The awesomeness that is Seafoam
So I've had a realization that the previous owner didn't treat the bike as well as I thought he did and have been doing a fair bit of maintenance on it. Yesterday I added 4-5oz of Seafoam to a full tank and have ridden maybe 40 miles.
Wow. Just Wow. My bike is soo much smoother and sounds much better. I don't think there is too much time left this year that I'll ride for pleasure but I expect to do a real job of cleaning up my bike for next spring when I pull it out of the garage. If you haven't cleaned your carbs recently or have doubts about the previous owner a can of Seafoam costs 6-10$ at a local store, cheaper online. If you knew a bike had been sitting for a good while, what all would you do for a checklist to get the bike ready again. I currently don't have a garage to tear apart the bike, but plan on it next spring. |
November 2nd, 2011, 01:15 PM | #2 | |
Yup, that stuff's great! I add some to every tank of gas. It stabilizes your gasoline as well, so if you park the bike for a while the gas won't go bad.
- Change all fluids - Check brake function and pads - Check/replace tires - Clean & lube chain, or replace if it's in really bad shape - Check fork seals - Clean & sync the carbs (An overnight soak in Pine Sol will amaze you with the results) |
November 2nd, 2011, 02:55 PM | #3 | |
never enough
Join Date: Sep 2011 Motorcycle(s): Blue 2010 ninja 250R Posts: 277
what does that do?
custom graphics, zero gravity DB |
November 2nd, 2011, 03:05 PM | #4 |
never enough
i was planning on taking the carbs out this winter when i rejet and cleaning them because my bike is breaking up when im just cruising at a slower speed. thanks for the tip!
anything else that would help?
November 2nd, 2011, 03:05 PM | #5 |
Join Date: Sep 2011 Motorcycle(s): 2009 Triumph Street Triple, 2009 KLX250SF, 2003 Suzuki SV650S (Sold), 2006 Ninja 250 (Sold) Posts: A lot.
That's the power of Pine Sol, baby!
November 2nd, 2011, 05:22 PM | #6 |
Winging It In Life
Join Date: Aug 2011 Motorcycle(s): 2010 250R; 2011 250R (sold) Posts: A lot.
Seafoam is definitely awesome. I bought a bottle to use in my car. As for my bike, I don't think I've put enough miles on it yet to use Seafoam.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015) 2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current) |
November 2nd, 2011, 06:15 PM | #7 |
Join Date: Nov 2008 Motorcycle(s): 2007 Ninja 250 Posts: 469
Seafoam is incredible stuff. HOWEVER, be very careful when pouring it directly in your engine. It can cause serious damage in the engine if not used only as a flush.
When adding it to your gas, it's like a miraculous cure. Most of the rough idle problems seem to stem from stale gas with ethanol.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008) |
November 2nd, 2011, 09:06 PM | #8 |
Join Date: Sep 2011 Motorcycle(s): 2011 Kawasaki Ninja 250r Posts: 169
I see here in Canada at Canadian Tire there are a few different Seafoam products, which one do you use as a fuel stabilizer/treatment?
Here is the link. http://www.canadiantire.ca/search/se...08474396672077 |
November 2nd, 2011, 09:07 PM | #9 |
November 2nd, 2011, 10:12 PM | #10 |
Thank you sir, that is what I thought it was...no do you all suggest to use Seafoam instead of Stabil??? For winter storage?
November 2nd, 2011, 10:44 PM | #11 | |
However, carbs are a different animal and those needles clog up quick. Some have suggested Seafoam for storage. Personally, I would drain the tank after running some Seafoam if you are up to the task (not difficult). That's the textbook way to store a bike. You can also do a bit of searching on the forums and decide which one will work better for storage.
November 3rd, 2011, 05:39 AM | #12 | |
November 3rd, 2011, 07:51 AM | #13 |
Join Date: Jan 2009 Motorcycle(s): 2008 Ninja 250 1998 HD Road King Posts: A lot.
http://www.seafoamsales.com/componen...2/view,folder/
I have used seafoam and it may "work" but I wouldn't store a bike with it in the tank. 10-20% ipa is a bit much
http://sandollarmotorcycleclub.com/ |
November 3rd, 2011, 08:34 AM | #14 |
ahhh, I got ya, thanks for the tip, so I will just use Stabil. Or would a no name stabilizer work also? AS in the Canadian tire brand one?
November 3rd, 2011, 09:42 AM | #15 |
Seafoam has placebo affect. Your bike thinks it's getting good fuel treatment and so is tricked into running better. In reality, you still need to remove and clean your carbs
November 3rd, 2011, 09:55 AM | #16 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
you have a riding season in texas?
blink-182 |
November 3rd, 2011, 11:20 AM | #17 |
Winging It In Life
Some parts of Texas have wild, unpredictable weather. It can be hot and humid one day to suddenly being cold as hell & snowing the next.
November 3rd, 2011, 11:21 AM | #18 |
So, where's the reverse?
Join Date: Nov 2010 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: A lot.
November 3rd, 2011, 06:05 PM | #19 |
Texas has plenty of frozen weather, especially around February. As I still drive my SUV for most outings especially if any alcohol is involved, the bike is purely for joy riding and errands. I don't fancy the idea of freezing weather + 50mph winds on the bike. It's just not the reason I own one.
November 3rd, 2011, 06:10 PM | #20 |
November 4th, 2011, 11:26 AM | #21 | |
Always.
I guess maybe the North East part more?
blink-182 |
Seafoam help please | Jay72 | 2008 - 2012 Ninja 250R Tech Talk | 15 | August 3rd, 2012 09:37 PM |
seafoam.. | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 16 | June 18th, 2012 07:28 PM |
SoCal Tech Day awesomeness!! | GeneJunkie | Pictures | 55 | June 11th, 2012 07:46 AM |
How to use Seafoam? | drdriftking007 | 1986 - 2007 Ninja 250R Tech Talk | 22 | April 17th, 2012 12:36 PM |
seafoam? | ReDnEcK | 1986 - 2007 Ninja 250R Tech Talk | 3 | September 1st, 2010 09:00 AM |
