Old April 27th, 2016, 07:04 AM   #1
Omarel
Omarel's Avatar
Exclamation My odometer is off!
So I just discovered my odometer is off. I got the bike and it said 3800 miles. Now it says 7300. I know for sure I haven't put more than 1k on it.
It's off by like 3 thousand miles.
What does this mean now?
UPDATE:
It's a mistake I had the mileage wrong. So sorry guys.
I discovered that I'm only getting 24 miles per gallon is the real issue.
Omarel is offline   Reply With Quote
Old April 27th, 2016, 07:08 AM   #2
allanoue
allanoue's Avatar
MOTM - Sep '14
someone knows where you keep the spare key.
Old April 27th, 2016, 07:20 AM   #3
Omarel
Omarel's Avatar
Old April 27th, 2016, 07:22 AM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
If the speed on your speedo is close to accurate, then something else is going on.
Odo is driven by speedo.
Goin' fast on slow bikes!
Old April 27th, 2016, 07:25 AM   #5
allanoue
allanoue's Avatar
MOTM - Sep '14
I would hop on a freeway and test it out against the mile markers.
Old April 27th, 2016, 07:40 AM   #6
Omarel
Omarel's Avatar
I'm so sorry guys. I was wrong. I had the wrong mileage. Mods you can delete. [embarassed]
I discovered that I'm getting only 24 miles per gallon is the real issue.
Old April 27th, 2016, 07:50 AM   #7
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
No need to delete, LOL!
It's OK to make mistakes. No one is laughing at you....
24 MPG....checked your air filter, spark plugs and valves lately?
Old April 27th, 2016, 07:53 AM   #8
VaFish
VaFish's Avatar
MOTM - Jan '16
Yeah, 24 MPG is way off. You should be getting 50-60 mpg quite easily.
Old April 27th, 2016, 09:43 AM   #9
asdfman
٩(͡๏̯͡๏)۶
asdfman's Avatar
Motorcycle(s): 09 Ninja 250 held together by duct tape and zip ties
Do you have stock gearing? 24 MPG is terrible for a Ninja.
asdfman is offline   Reply With Quote
Old April 27th, 2016, 11:31 AM   #10
Omarel
Omarel's Avatar
Thanks @RacinNinja and everyone.
I'm gonna check these things hopefully this weekend.
Old April 27th, 2016, 12:48 PM   #11
How exactly are you calculating your mpg?
Old April 27th, 2016, 01:30 PM   #12
Omarel
Omarel's Avatar
I did it this way:
-Filled up tank and reset Trip Miles on bike to 0.
-Rode until near empty.
-Fill up again. Noted that there was 82 miles since last fill up.
-Noted 3.4 gallons of gas was added to fill up tank.
82 / 3.4 = 24 mpg
Cried when I saw this #.
Old April 27th, 2016, 01:34 PM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
My 2003 Civic regularly gets 36+ MPG.
You should be doing much better!
Time for a tune up I think.
Also, confirm your Trip Meter coincides with odometer....and that your odometer coincides with true distance.
Old April 27th, 2016, 02:07 PM   #14
Originally Posted by Omarel View Post
I did it this way:
82 / 3.4 = 24 mpg
Nothing wrong with that method. If you've confirmed your odo is providing reasonable numbers, that is terrifically bad fuel economy. Something is wrong.
Old April 27th, 2016, 03:08 PM   #15
VaFish
VaFish's Avatar
MOTM - Jan '16
Are you sure it isn't leaking gas?
Old April 27th, 2016, 03:27 PM   #16
xorbe
xorbe's Avatar
Spraying fuel into exhaust for afterburner effect? At worst I saw 46-48 mpg for typical riding. Sure the odo / trip meter is counting correctly?
Old April 27th, 2016, 03:34 PM   #17
Omarel
Omarel's Avatar
Dang that's actually a possibility. Because I do smell a lot of gas on my clothes after riding.
Old April 27th, 2016, 04:43 PM   #18
Very common problem on pregens where people screw the top fairing bolts all the way into the side of the tank, providing a wholly unnecessary vent hole on one or both sides of the tank.
Old April 27th, 2016, 09:03 PM   #19
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Just for reference, the odometer is hard-geared to the rotation of the front tire. On the pregens the odometer is remarkably accurate with the stock tire size (reads slightly more than actual miles by a percent or two) and pretty much dead on with the common replacement sizes. Because of the way the gearing works at the hub and in the speedometer it's pretty much impossible for it to read anything else than actual. Either it reads and it's accurate, or it doesn't read at all.
The speedometer uses magnetic eddy currents so it can be off, and usually is. The odometer and speedometer systems are completely unrelated other than the fact that the speedometer cable inputs to both mechanisms.
Old April 28th, 2016, 04:36 AM   #20
VaFish
VaFish's Avatar
MOTM - Jan '16
Or a leaking/malfunctioning petcock which was a problem on my daughter's bike.
Old April 28th, 2016, 04:37 AM   #21
VaFish
VaFish's Avatar
MOTM - Jan '16
You should not smell any gas on your clothes after riding. Gas should be staying in the fuel tank and fuel delivery system until it is burned in the engine.
How to reset the odometer? caineroad 2008 - 2012 Ninja 250R Tech Talk 32 May 6th, 2014 09:13 AM
Speedometer/Odometer Cable kennetht 2008 - 2012 Ninja 250R Tech Talk 19 May 5th, 2014 09:55 AM
2008 Odometer Cable Bhb Items Wanted 3 May 15th, 2013 02:44 PM
How much would you pay to take miles off your odometer? Severedbeliefs General Motorcycling Discussion 29 April 3rd, 2013 02:23 PM
speedometer / odometer disconnected IlBLisSlI 1986 - 2007 Ninja 250R Tech Talk 8 June 16th, 2009 08:46 AM
