Old March 31st, 2012, 07:30 PM   #1
dburgess1231
dburgess1231's Avatar
Motorcycle(s): 2003 Ninja EX250 blue
gas leak. need help
I was riding down the road and my bike started to studder while moving until it eventually dies. I thought it was a bad battery, but today i have discovered gas leaking somewhere from the carbs. Is this a common issue? Should i take it in to have it worked on or should i attempt to take it all apart myself having never worked on the carbs? I need my bike!
http://www.ninjette.org/forums/showthread.php?t=99183
dburgess1231 is offline   Reply With Quote
Old March 31st, 2012, 08:12 PM   #2
Inside the bowl of each carburetor there is a float that forces a valve to close the flow of fuel from the tank once the level of fuel inside that bowl reaches a specific level.
If the float or the valve are jammed, nothing stops the flow from the tank and the carbs don't work as intended.
Sometimes that happens after a fall or something that disturbs those internal parts; sometimes, one or both valves just reached the end of their life and need to be replaced.
Rare but not impossible is a float that sinks due to a puncture or crack that allows fuel to fill it up.
I would gently tap the sides of the leaking bowl and see if that stops the leak.
You will find many threads with step by step descriptions of how to open and clean the Ninja's carbs.
Old April 1st, 2012, 11:04 AM   #3
dburgess1231
When you lift up the seat there is a black tube on the bottom left near the tank bolts. what is that supposed to lead to? mine seems to lead to nothing. the other end is all chewed up
Old April 1st, 2012, 02:31 PM   #4
That hose drains any water that gets collected at the cap of the fuel tank down to free discharge it on the road.
Old April 1st, 2012, 03:15 PM   #5
It also allows air into the tank to take the place of the fuel that leaves it so there's not vacuum inside the tank to starve the engine. If it's chewed up on the end where it dangles out of the bike, that's not a problem. That just means that it's touched the ground once in a while because it's so long.
Mine was like that too. I finally cut 1.5" off of it after a few well intending cagers annoyed the crap out of my by flagging me down at lights, and yelling, "Your bike's broken! There's something hanging off the bottom!" Took me forever to realize they were talking about my breather hose...
Old April 1st, 2012, 04:07 PM   #6
dburgess1231
ok. i really hate that i have to rebuild the carbs though.
Old April 1st, 2012, 04:18 PM   #7
Just try the side tap on the bowls with a heavy piece of wood.
It may work if something is just out of place.
Old April 1st, 2012, 04:44 PM   #8
dburgess1231
I dont think that will stop it from leaking gass tho...
Old April 1st, 2012, 08:25 PM   #9
if it's a jammed float valve, a solid tap might free it.
Old April 2nd, 2012, 04:33 AM   #10
dburgess1231
Yeah but how would that make it leak gas? I would think a seal is bad or a connection is bad somewhere if it is leaking gas right?
Old April 3rd, 2012, 05:03 AM   #11
dburgess1231
takin her apart today. Then cleaning the carbs saturday.
gas leak help please mz_twee 2008 - 2012 Ninja 250R Tech Talk 2 May 22nd, 2012 06:11 PM
Gas leak...?!?! blink 2008 - 2012 Ninja 250R Tech Talk 7 September 8th, 2011 04:11 PM
New Member / Gas Tank Leak Clearlynotstefan 1986 - 2007 Ninja 250R Tech Talk 18 April 17th, 2011 05:38 AM
pretty sure i f'd myself...(gas leak) ians_04_250 1986 - 2007 Ninja 250R Tech Talk 18 April 30th, 2009 08:20 PM
Argh! Gas leak from petcock. Strange 1986 - 2007 Ninja 250R Tech Talk 8 March 17th, 2009 03:07 PM
