Old May 15th, 2012, 06:26 PM   #1
seamuswh
Motorcycle(s): ninja 250, fz6
Bike dies with choke after not storing properly...
Hi guys, hopefully someone can help me with this.
I didn't winterize my ninja properly last fall (classic), hoping that my dad would run it from time to time to charge the battery and keep the fluids flowing. The battery died, however, so the bike ended up sitting for about 8 months. I can start it now, and it will run, but only with no choke. It idles quite high (around 3500 rpm) and the rpm will drop with only a very small amount of choke, and the bike dies with any substantial amount of choke. I've tried adjusting the idle screw, but I can't seem to get the idle rpm to less than about 3500. I've been running some seafoam through it and it seems to have helped a little bit, but not much.
I put in new fuel, etc, so I don't think the problem is rotten fuel. I'm not sure if it's the carbs either, because it runs fine with no choke and doesn't die when I give it throttle.
Sorry about the long post, but any help would be appreciated!!
thanks
seamuswh is offline   Reply With Quote
Old May 15th, 2012, 09:12 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Clean the carbs
/thread
AFM #676
Supersports are for n00bs
Old May 15th, 2012, 10:47 PM   #3
Domagoj
How long was it running before you started to fiddle with it? Give it time, and perhaps the dirt will be flushed by the new clean fuel.
New tyres but storing bike over winter? Jason5885 General Motorcycling Discussion 20 November 14th, 2014 01:02 AM
Bike dies w/o choke rasta General Motorcycling Discussion 11 June 13th, 2014 03:43 AM
Properly sorted Race bike for sale: r6boater Motorcycle-related 3 May 22nd, 2013 07:16 PM
How to properly start a ninja? Dies on me Black knight 2008 - 2012 Ninja 250R Tech Talk 14 April 7th, 2013 08:18 AM
storing my bike? ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 11 September 2nd, 2010 06:29 AM
