Old April 24th, 2015, 05:08 PM   #1
Motorcycle(s): '95 DUCATI 900SS/SP '98 HONDA VFR800 '07 DUCATI SS800
me Duc
a-lo
Old April 24th, 2015, 06:39 PM   #2
Old April 25th, 2015, 02:43 PM   #3
kdogg2077
kdogg2077's Avatar
Moar picssss.
I find myself very drawn to Ducs. Want a 696/796.
Old April 25th, 2015, 04:07 PM   #4
^ ty but naa, don't want to bore the masses.
the 2V Ducs are, contrary to "legend", quite reliable. Mine is self-serviced, never been in a shop, original owner bought new Sept 94. One must, however, learn to check and adjust the Desmodromic valve system. Different, tricky, but doable. Mine has dual downdraft 38MM Mikuni carbs...I'm pretty good with them too
Old April 25th, 2015, 05:04 PM   #5
Finesse
ran when parked
Finesse's Avatar
MOTM - Sep '17, Dec '14
that looks super fun to ride! congrats! how long did it take you to find it?
Instagram: @katie.baden
Old April 25th, 2015, 05:37 PM   #6
I *am* that original owner from new. Yes, fun factor 11, light, sticks like glue, awesome handler, great torque. Draws stares, waves, thumbs up, whoops and hollers wherever i go.
Ok, kdogg, here's a more close up pic, though from a few years ago. As I posted, never been in a shop, 25K miles....always self serviced. A fantastic streetbike. Absolutely a keeper, its willed to my younger brother in Florida (an EX500 owner) when....well, when.
Visually stock, but got some tasty mods for reliability and performance sake. A Mosfet regulator/rectifier (from a ZX10), an LED voltage indicator, special valve keepers, Barnett clutch (dry), Michelin Pilots, Factory Pro carb innards.....blah blah blah. I've refined it over 20 years of ownership.
Old April 25th, 2015, 06:05 PM   #7
the Duc's stablemate
Old April 26th, 2015, 05:35 AM   #8
kdogg2077
kdogg2077's Avatar
Looks like it just rolled out of the dealership! Seems like the perfect sportbike to ride around on. I know it's cliche to say, but in this case it is literally true, "they don't make em like this anymore".
I'm hoping to get a Monster 696 soon. I'll probably have to go to a dealer for maintenance at first but hope to eventually do most maintenance myself.
Old April 26th, 2015, 06:01 AM   #9
an oldie but a goodie.
Air cooled 2V Ducs (your 696 included) are dead reliable when correctly maintained. Some info for you if contemplating:
BELTS (timing belts, no cam chain (s) *must* be replaced every 3 years...its an interference engine..valves meet pistons if belt breaks. There are 2, about $90 ...and 2 hours DIY labor.
VALVES checks are easy, the desmo system opens AND shuts valves mechanically (no valve springs) there is both an opening AND closing clearance, adjusted via shims. 6000 mile inspection required, as they break in.. the valves stabilize to some degree. Def different, a bit tricky to perform shim changes when needed. But not impossible at all, just requires a unique method. Besides...there's only 4 to do! (see pic)
Thats about all that requires unique treatment, running gear all common, simple stuff. Dry clutch...same basic design as wet, though your 696 is wet...
nothing unique there.
Good hunting for your future purchase!
Old April 26th, 2015, 08:03 AM   #10
kdogg2077
kdogg2077's Avatar
Thanks! Doing those two things on my own eventually is in the plans.
I'll post here if I pick anything up!
Old April 28th, 2015, 11:56 PM   #11
KawiKid860
KawiKid860's Avatar
Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED
Interesting, possibly the first time I've heard a Duc owner say it's fairly reasonable to own and maintain your own. I'm curious, would you consider the 2v desmodromic valve adjustments easier or more difficult than a standard shim under bucket adjustment on an inline 4 sportbike?
KawiKid860 is offline   Reply With Quote
Old April 29th, 2015, 05:01 AM   #12
2V Desmo system not at all the voodoo legendary in moto folklore, and not "dealer only" by a longshot
admittedly different, def requiring some mechanical aptitude and experience...
but I'd submit its easier than pulling I4 cams for a shim swap.
Old April 29th, 2015, 09:20 AM   #13
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Isn't this the bike that Hunter S. Thompson wrote The Sausage Creature about?
I wish the 916 and it's evolution came in a 500cc power plant or something like that... Personally would love an old bevel drive 750 - The original Tron bike, no? Or, in those veins, the Sport GT, but I will never be able to afford that... Always wanted to futz with desmodromic... I think it's a genius solution to the problem they had, and is kinda of required for a Duc to be a Duc these days, if maybe it's a bit out dated...
Old April 29th, 2015, 09:38 AM   #14
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Ducati need to do this again ....... stuff of dreams right here
Old April 30th, 2015, 09:13 PM   #15
PsychoNinja
Ninja Dog
PsychoNinja's Avatar
Motorcycle(s): 2011 Kawasaki Ninja ZX-14
Nice Ducati!
I once had the chance to own a 1987 Ducati Paso 750, but I couldn't justify owning a bike that I couldn't get repaired if anything happened to it.
ALL YOUR NINJA ARE BELONG TO US!
PsychoNinja is offline   Reply With Quote
Old April 30th, 2015, 09:30 PM   #16
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
If I get a nickel everytime you use that smilie, I could quit my day job!!!
Achievement unlocked: Forum Stalker
Riding it like I financed it.
Old January 12th, 2019, 01:57 PM   #17
Bumpin' this ancient thread to show off my latest Ducati acquisition...an '07 SS800 , with just under 5000 miles.
I've modded and tweaked to my satisfaction. Lost the entire '18 riding season due to medical reasons....spring of '19 can't get here soon enough!
Gordon
Old January 13th, 2019, 07:55 AM   #18
Motorcycle(s): '06 SV650n, '00 SV650n project, '00 Derbi GPR, '64 CA77 Dream 305, '70 CL450 Scrambler, numerous dirt bikes
Congrats Gordon!
Can't have too many red bikes ya know!
You deserve a treat after a rough 2018. Here's to a great 2019!
Old January 13th, 2019, 08:54 AM   #19
Thanks, Jay. You know my situation.
Dunno....somehow the only bikes to find me are red. Can't explain it. No major complaints though.
Gordon
Old January 13th, 2019, 09:29 AM   #20
Motorcycle(s): CB125T, Ninja250R racer, Ninja250R street bike, EX250F#1, EX250F#2, VF500F, CBR600RR
MOTM - Nov '17
Very nice... Very nice....
Old January 13th, 2019, 10:21 AM   #21
thank boyz.
I know I'm kind of antiquated in my thinking...but the older, air cooled Ducs are nowhere near as complicated as the newer generations...therefore my attraction to them.
Anti wheelie, anti skid, electronic this and that...the computerized controls are well and fine while warranty applies...but going forward will inevitably add to owner expense. I shudder to think the obscene $$$ service charges involved with repair of failures. The '07 pictured is FI...a bit more complicated with a Magneti Marelli ECU... my older carbed SS is laughably simple in comparo.
These older gen SS's will attain 130 mph....more than needed as streetbikes, meanwhile are fully serviceable in their relative simplicity by competent owners. I'm not convinced at all that I need, nor do I desire a $15, 20 grand
new gen Supersport....Ducati or other. My current oldies fully scratch my itch.
I'll submit (fully my opinion) there are realistic, positive benefits in long term cost of ownership with these oldies as opposed to the new breed. I guess time will tell....and of course...YMMV.
Gordon
Old January 13th, 2019, 04:48 PM   #22
greg737
Motorcycle(s): -
https://www.youtube.com/watch?v=uhYnAeKiTq4
(sorry Gordon, couldn't resist)
Old January 13th, 2019, 05:37 PM   #23
quite alright, though they speaking some weird language in the vid
Gordon
Old January 13th, 2019, 07:55 PM   #24
Motorcycle(s): Ninja250
Very nice! The bikes that find you are red, vehicles that find us are yellow.
Old January 14th, 2019, 07:48 AM   #25
only red, in your case yeller....weird, innit?
(mind you, i'm not complaining one bit)
Gordon
Old January 14th, 2019, 08:05 AM   #26
sharky nrk
sharky nrk's Avatar
nice, I have been eyeing the air cooled 1100 Multi S for some time as maybe my next do it all bike
Old January 14th, 2019, 09:46 AM   #27
^ I'd urge you to mosey over to ducati.ms forum and do research on service requirements, costs, procedures, difficulties and problems before diving straight in. Not limited to calling a dealer service dept for labor rates and planned maintenance services for your particular model (especially belt and valve service)
That way no "surprises" involved, you'll know going in whether a Yamaha, Zuk or Kawasaki would be a better choice for you.
There are those that bitch about extreme Ducati dealer service fees.....but made no effort in finding that info out BEFORE buying the bike.
Gordon
Old January 14th, 2019, 01:11 PM   #28
MOTM - Nov '17
Heh, heh.... I almost bought an '88 Ferrari Testarossa while back. Checked with dealer on regular maintenance items like timing-belt. Due tight packaging, engine has to be removed in order to replace timing-belt, $5-8K each time. Yikers, no thanks!!!
Old January 14th, 2019, 01:43 PM   #29
^ wow, enough to scare any but the most fortunate away
good thing you checked that, eh Danno?
Some of the latest gen Duc Multistradas $1500-1800 not unusual for major services ....best to know going in.
Precisely why I like the DIY oldies.
Gordon
Old January 14th, 2019, 02:44 PM   #30
sharky nrk
sharky nrk's Avatar
lol well its a much a pipe dream at the moment as it is a plan but I will heed that advice and research before hand for sure. I don't pay anyone to do my service, on any of my vehicles, unless I absolutely have to. There has been very very few things I have not done myself successfully - mostly due to specialty equipment (air conditioning, alignment, etc). But you make a valid point .
Old January 14th, 2019, 03:47 PM   #31
I'd never be able to afford upkeep on 2 Ducatis and a Honda VFR V4 if I didn't DIY.
Owning multiple bikes...doing all scheduled maintenance from oil changes to valve adjustments and (especially) tire changes can get pricey.
I'm currently learning how to "tune by computer" on the newer Duc, completely new to me (see pic) .
Thankfully, all 3 are quite reliable machines.
Gordon
Old January 14th, 2019, 06:02 PM   #32
MOTM - Nov '17
Yeah, all modern hot-rodding is done in software!
Old January 14th, 2019, 08:02 PM   #33
This stuff all new to me...I'm nowhere near competent to approach the hot rodding stage.....nothing wrong with the bike...at this time just doing "look don't touch" checks, dumbing my way around the software and acclimating to its basic functions, trying my best not to wreck anything.....wiping the factory ECM .bin file my biggest fear!
Educating myself...my motive is to get a leg up on being able to read, interpret, reset flipped codes, diagnose and perform corrective repairs ...OBD stuff....just like the family auto.
Required some special cabling between laptop and bike diagnostic output plug. The laptop required a specific diagnostic program to read the Magnetti Marelli ECM. Aprilia, Moto Guzzi and Ducati use same brand ECM's and a few common software programs.
Gotta admit, sometimes I miss the simple pilot, main jets and needles though, but I'll get there in time.
Gordon
Old Yesterday, 10:14 AM   #34
sharky nrk
sharky nrk's Avatar
^^ I feel you completely on that. I had no issues tuning a piggyback type module on my Subarus and did so frequently with a wideband and datalogging setup. I also had the ECU flashing software setup but I only used them to monitor the OEM tables and similar. Was always afraid of screwing up the OEM tables lol. Hondata flashing really was where I got my toes wet on OEM ECU flashing but it was MUCH simpler on the OBD1 Honda ECUs. My HF/NoMar/Mojo conglomeration has also served me well in that capacity - but I do like when the trackside tire vendor does it for me lol.
Old Yesterday, 07:33 PM   #35
a perpetual learning curve
Gordon
Crazy Cool Duc THE BIG SITT General Motorcycling Discussion 2 June 23rd, 2013 12:25 PM
[superbikeplanet.com] - Duc, Duc, Scoot: Ducati Planning To Produce Bigger Lineup, In Ninjette Newsbot Motorcycling News 0 March 1st, 2011 03:00 PM
Your 2c on duc monster Cab305 General Motorcycling Discussion 33 January 20th, 2011 12:31 PM
Bike back together with Duc tail divingtigger Pictures 29 May 7th, 2010 11:41 PM
[twistingasphalt.com] - Smokeless Duc Ninjette Newsbot Motorcycling News 0 November 15th, 2009 01:10 AM
remote server monitor
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Except where otherwise noted, all site contents are Copyright 2016 ninjette.org, All rights reserved.
