Old January 29th, 2021, 04:39 PM   #1
[motorcycle.com] - Monster Fairings: Not All Fairings Are Created Equal
Customization is a staple of motorcycle ownership, and when it comes to sprucing up the looks of modern sportbikes, there’s no better way to get dramatic and eye-catching results than to turn to aftermarket fairings. Then again, maybe you’ve had the unfortunate fate of crashing your sportbike and damaging the stock bodywork. Aftermarket fairings are a great way to replace your damaged bodywork at a fraction of the cost of new, while also injecting some personalization at the same time. Whatever your reason, you should look to Monster Fairings for your aftermarket bodywork needs.
Aftermarket fairings, like sportbike riders, come in many different shapes and sizes, but often the thinking goes: if you want high-quality stuff it’s going to come at a premium price. Monster Fairings is out to change that perception.*
Founded in 2013 and based in London, England, Monster Fairings specializes in custom aftermarket motorcycle fairings that are guaranteed to fit and not break the bank. How do they do it? By manufacturing in China.*
That’s right, we’re going to put the elephant in the room out there in the open. Why? Because not all Chinese products are equal and we’re here to break the stigma that all Chinese-made products are bad.*
Look. We know breaking the stigma is going to be hard. Like you, we’ve personally seen a lot of the garbage floating around on places like eBay. These other companies have flashy graphics and take nice photos to promote their products, but underneath the facade the fairings themselves are cheap, flimsy, compression molded plastic pieces with even cheaper mounting tabs held in place by a giant blob of glue.*
To make it worse, half the time (probably more) those tabs don’t line up with the mounting points on the bike anyway. Then you’re left trying to modify the bodywork with files, drills, zip ties, and who knows what else in an attempt to fix a problem somebody else created. In the end, the fairings don’t end up fitting quite right and you’re left feeling pissed off because you just got bamboozled.*
Here’s the Monster Fairing difference. First off, every one of their fairing kits is made to order, and they have kits for many of the popular Japanese sportbikes, as well as kits for Aprilia, BMW, Ducati, and Triumph. Unlike some of their competitors who use compression molding to cut costs, they make fairings using ABS injection molding – the same process used by the OEMs. The end result is a nice and sturdy piece that’s as good as the original. The mounting tabs themselves are included as part of the injection molding process and are placed in the exact same spot as the factory bodywork to ensure precise and accurate fitment. In fact, they’re so sure the bodywork will fit right the first time and you will be satisfied, they guarantee it.*
But let’s get back to customization for a minute. Having a set of fairings that line up right is great, but what about looks? Again, Monster Fairings’ goal is to change perceptions. Their fairings kits come in all kinds of graphic designs from mild to wild, including OEM replica graphics. But here’s the best part: you can customize an existing design OR submit a design of your own. Their design team will work with you to finalize the artwork and will even send you pictures to sign off on, ensuring the job will be done right the first time.
Monster’s painting process is second to none and involves seven stages. First comes the under coat, followed by the base colors. Once the base colors are set the main colors are applied next, which is then followed by additional detailed work. Once the colors are all on, the clear coat process starts. At least three layers of clear coat are used, followed by an extra coat of UV protective clear. This ensures the colors stay strong and vibrant, and protects against the sun’s harmful UV rays.*
As a finishing touch, all of Monster’s fairings include liberal amounts of heat shielding already installed to protect against the massive amounts of heat coming from the engine and exhaust. This is a critical step those cheap, flimsy fairings often skimp out on, resulting in fairings that warp, deform, or burn through in short order.*
And for the racers or trackday enthusiasts out there – Monster Fairings can be ordered in track-ready trim, with no openings for front or rear lights. *
Monster Fairings are loved by customers, editors, bloggers, enthusiasts, and social media influencers all over the world, but the company realizes that there’s no better way to change opinions than to put the product in the people’s hands. That’s why they’re offering Motorcycle.com readers a free bolt kit worth $65 with each fairing kit purchase, just use code MOTO21 at checkout.*
So, if you’re a sportbike rider in search of some new bodywork, come experience the Monster Fairing difference at monsterfairings.com. We know you’ll be pleasantly surprised that you did.
The post Monster Fairings: Not All Fairings Are Created Equal appeared first on Motorcycle.com.
Click here for full story...
[roadracingworld.com] - AMA: Bipartisan Motorcycle Caucus Created In The U.S. Senate Ninjette Newsbot Motorcycling News 0 April 6th, 2017 09:10 AM
Not all helmets are created equal. Shark helmets commercial spooph Motorcycle Gear 9 April 7th, 2015 06:34 AM
All powder coating is not created equal... massacremasses Off-Topic 5 May 25th, 2013 09:22 PM
