Old July 4th, 2020, 07:12 AM   #1
Onekallo
Motorcycle(s): 06 ZZR-250 - 05 ZZR-250
Huge Fuel Leak after Warm up
Hey all. Having some trouble with my bikes here in Canada.
Purchased a pair of used Ninja/ZZR 250 in “ran last year” condition. One is an 05 one is an 06. Neither would start but I am working on them one at a time to get them going.
Tried to start when I got it home, nothing, so I got to work.
Carb cleaning; complete disassembly, soaked in pine sol and water, cleaned all jets and parts as they were very gummed up. I reinstalled everything after adjusting the floats to 17mm (as close as possible anyways)
Reinstalled everything and went to start again.
Fuel in ON position (petcock only has ON - PRI - RES)
Hit started and a increased choke.
Fired up with half choke, ran at 2500rpm and slowly came down as bike warmed up.
Put it into gear and took off down the road. One block away bike was running smooth so I completely removed choke. Shifted to 2nd no problem.
Turned around to come back and noticed there was no throttle response.
Just as I pulled in the driveway the bike quit.
I looked down and fuel is pouring out of the bottom of the bike
Ran into the garage and grabbed some pinch off pliers for the fuel line and the leak stopped shortly after.
I removed the carbs, checked everything over again and it all looks ok. I installed the cleaned out carbs from the 05 and figured I would try that.
Once again started up and ran good, then started to leak fuel like crazy
Is my petcock over flowing into the carbs? (Leaning towards this as it does it with both sets of carbs on the same bike) Or is my needle not fully seating to shut off the fuel?
Any help would be great. Thanks
Onekallo is offline   Reply With Quote
Old July 4th, 2020, 07:29 AM   #2
Artruck
Check the seals of your carb float bowls. They would fill when running and leak then stop when the petcock shuts. They get hard over the years and can get splits and flat spots.
I would start the bike up, and let it idle to temp with the bodywork off and watch for where your leak is. That will help you narrow it down.
Old July 4th, 2020, 07:51 AM   #3
Onekallo
All float bowl gaskets are new.
Bodywork is off.
Going to try and fire it up again and pinpoint the leak.
Old July 4th, 2020, 11:35 AM   #4
Need to disassemble carbs further. Split them apart to replace fuel-rail O-rings.
Old July 4th, 2020, 11:37 AM   #5
A petcock can't supply too much fuel, but the float valves can leak and let too much fuel in. The fuel can then spill out the overflow tubes.
Old July 4th, 2020, 01:27 PM   #6
Onekallo
Thanks for all the help. Took carbs back apart again, cleaner the seat and made sure float valves were free of debris and clean. Re-installed and so far so good after a few short rides
Fuel leak Tylerscott86 1986 - 2007 Ninja 250R Tech Talk 9 December 9th, 2019 02:37 PM
Carbs leak while fuel is on Jaytibba 1986 - 2007 Ninja 250R Tech Talk 29 July 21st, 2016 02:22 PM
mysterious fuel leak 10inja 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2013 05:04 AM
Help, fuel leak. Stangrider 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2013 09:34 PM
Weather=fuel leak? 48newrider 1986 - 2007 Ninja 250R Tech Talk 5 March 13th, 2013 07:09 PM
