October 11th, 2012, 12:46 AM | #1 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Lubing Cables
Just wanted to ask what the members of this forum have used successfully to lube their cables. Is it fine to use spray-type chain lube?
October 11th, 2012, 02:58 AM | #2 |
Join Date: Oct 2012 Motorcycle(s): GPX250, 2000 R6 Posts: 15
WD40.... you have to re-apply every couple months, but it works a treat.
October 11th, 2012, 06:10 AM | #3 |
Cable lube works better than WD-40 so lubing can be done less often. Get a cable luber, a little block that clamps to the end of the cable and has a port for injecting the lube using the straw that comes with the lube.
October 11th, 2012, 01:22 PM | #4 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
I use WD-40 to clean the cables then put silicone spray. It repels water so that's always a plus.
October 11th, 2012, 02:02 PM | #5 |
I use WD40 until the crap comes out the other end of the cable clean, then I spray in bicycle lube. That stuff is perfect for everything.
October 11th, 2012, 02:07 PM | #6 |
Ninjette Fanboy
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja250 Posts: 307
I wish there was a Ninjette specific DIY cable lube video… I'm a noob and would be confident if there was a video/instructions to follow
October 11th, 2012, 02:15 PM | #7 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
I've used the Dupont Teflon Lubricant. I've only used the "Dry" stuff though as I haven't bought anymore since they've changed it.
October 11th, 2012, 04:13 PM | #8 |
i use the blood of a small goat. it has a great effect on other people at the track :P
Chain Lubing | icbm | General Motorcycling Discussion | 2 | February 14th, 2012 02:36 PM |
Technique for lubing cables | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 18 | December 17th, 2011 07:15 PM |
First time lubing my chain | RaZeDaHeLL | General Motorcycling Discussion | 31 | December 7th, 2011 03:47 PM |
Lubing the throttle cables | Boom King | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 26th, 2011 06:30 PM |
Chain cleaning / lubing..Help! | Stillblunted | 2008 - 2012 Ninja 250R Tech Talk | 26 | October 15th, 2010 01:15 PM |
