Old January 16th, 2015, 05:24 PM   #1
dragono
Clutch Issues
Hey guys i'm new here! I just got a 2005 Ninja 250. It starts and runs fine however the clutch will not disengage. It was working, but was really loose so I wont to adjust it and I acidentally pulled the bolt that goes down into the clutch out. (the thing the the cable actually actuates) So i did some research and decided to pull the clutch cover (shoulda had a new gasket ready) and the push rod seems like its not working correctly. I can remove it back and forth about 1/8 to 1/4 of an inch and there is no movement on the pressure plate. Even before I went to take the clutch cover off, I reinserted the clutch rod (not the push rod, never took it off) and tried to use it manually and the clutch still does not engage.
What am I doing wrong guys? Cable isnt broken, frayed, or anything like that.
dragono is offline   Reply With Quote
Old January 16th, 2015, 05:27 PM   #2
put the cover back on with a new gasket, slide the actuator arm back in pointing away from the bike. turn it counter-clockwise and it will thread up with the clutch plate puller bearing holder. you wont be strong enough to actuate it by hand so just put the cable back on, adjust the cable to get rid of the slack and it should be fine
Old January 16th, 2015, 08:07 PM   #3
Ghostt
Ghostt's Avatar
Stupid question time, was the bike running? And how long did it sit? And don't forget to lube the clutch cable, and while your at it lubricated the throttle and choke cables too.
violente et ignorantia
ZX-2R BLOG
Old January 16th, 2015, 10:58 PM   #4
i wrote counter clockwise but i think its actually clockwise
Old January 16th, 2015, 11:14 PM   #5
dragono
Yep im a total dweeb. It pulls now. I need to get a gasket. (or atleast high temp sealer) and put her back together. Thanks you guys.
Old January 17th, 2015, 08:00 AM   #6
dragono
So put everything back together and the clutch cable seems to engaged but theres no sign of it actually working. I left it on the center stand in first while the engine was off after a little warm up in neutral. Like I said Im a total newb to anything above a 150cc (scooter) so any ideas? (link below)
http://youtu.be/J007N3LNFQM (thats a small vid I made of the issue)
Old January 17th, 2015, 08:17 AM   #7
Welcome, Bril !!!
The video shows that the clutch actuator is properly working.
Did you put the oil back in?
The engine uses that oil, so the oil must be at the proper level before you start the engine.
As mentioned above, if the bike has seated for a while, the discs may remain together even when the pressing plate is liberated by the handle-cable-lever.
If so, you can pry them loose with a screwdriver through the fill up port.
You can print a gasket from here:
http://n4mwd.blogspot.com/2013_08_01_archive.html
You can find more information about your clutch and engine here:
http://faq.ninja250.org/wiki/Clutch_%26_Transmission
http://faq.ninja250.org/wiki/Engine
Old January 17th, 2015, 05:27 PM   #8
dragono
FIXED! I let it warm up a bit more put it on a slight hill then let her roll down the pulled the clutch popped it in 1st and that seemed to do the trick!
Old January 17th, 2015, 05:42 PM   #9
Clutch and Engine Idle Issues daphnelcc 1986 - 2007 Ninja 250R Tech Talk 11 August 23rd, 2013 12:48 PM
Help help! :( (clutch cable issues) Stillblunted 2008 - 2012 Ninja 250R Tech Talk 9 January 24th, 2012 09:20 PM
Clutch Issues n4mwd 1986 - 2007 Ninja 250R Tech Talk 25 October 20th, 2010 08:25 AM
Clutch Engagement Issues HELP! peter330 2008 - 2012 Ninja 250R Tech Talk 30 June 2nd, 2010 09:19 AM
250 clutch issues 01jackedZ 1986 - 2007 Ninja 250R Tech Talk 27 September 13th, 2009 08:51 PM
