Old December 3rd, 2014, 08:40 AM   #1
TBC
TBC's Avatar
Motorcycle(s): 2004 Ninja 250F
Removing Rear Shock Spring?
Hi guys! This might be a dumb question, but is it possible to separate the spring from the damper on the rear shock? I'd like to pull out the spring to paint, but I don't want to disassemble my rear suspension if it's not possible.
TBC is offline   Reply With Quote
Old December 3rd, 2014, 04:58 PM   #2
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
You bet, but you'll need a spring compressor. Take the shock off the bike, compress the spring with the compressor, loosen the lock nut that locks the clevis to the shock rod then take the clevis off, loosen the spring compressor and whal-a it's off.
Old December 3rd, 2014, 06:48 PM   #3
That is not possible for the pre-gen Ninjas. (Incorrect information. Please, see post #18 below)
Please see:
http://faq.ninja250.org/wiki/Rear_suspension_upgrades
Last futzed with by Motofool; December 6th, 2014 at 02:56 PM.
Old December 3rd, 2014, 07:56 PM   #4
Ghostt
Ghostt's Avatar
Hell do the ZX600 modification,
http://faq.ninja250.org/wiki/Installing_a_ZX600_shock
violente et ignorantia
ZX-2R BLOG
Old December 3rd, 2014, 09:11 PM   #5
The Ninja 300 shock works great on our old bikes.
Old December 3rd, 2014, 09:17 PM   #6
Ghostt
Ghostt's Avatar
Very true, I just preferred the options of changing the shock oil, and adjustable air suspension so to speak that the ZX600 shock offered.
I put 15wt synthetic and adjustable air is a nice touch when riding 2 up sometimes.
On my EX500 I resprung the OEM shock with one from PRO SPRING, 500lbs spring very nice, easy and inexpensive modification.
ZX-2R BLOG
Old December 4th, 2014, 05:58 AM   #7
Z1R rider
Z1R rider's Avatar
Please see:
I've done it to three of my pre-gens, a 1999, 2000, and an 2002
Old December 4th, 2014, 07:09 AM   #8
Ghostt
Ghostt's Avatar
Anything can be done, the question is, is it worth it?
Personally if you want to paint the spring, I would work some cloth inside the spring, and paint away.
ZX-2R BLOG
Old December 4th, 2014, 06:05 PM   #9
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
I don't think I've ever looked ay my pre-gen rear shock spring...
Old December 4th, 2014, 06:20 PM   #10
Z1R rider
Z1R rider's Avatar
I took mine off to put some spacers on to preload the spring.
Old December 4th, 2014, 09:19 PM   #11
How did you do it?
Old December 5th, 2014, 05:25 AM   #12
Z1R rider
Z1R rider's Avatar
How did you do it?
see post #2
Old December 5th, 2014, 07:58 PM   #13
see post #2
...........loosen the lock nut that locks the clevis to the shock rod then take the clevis off, ..........
Sorry, I got lost there.
Old December 6th, 2014, 08:40 AM   #14
Z1R rider
Z1R rider's Avatar
No problem, my typing fingers have been faster than my brain before too.
Old December 6th, 2014, 08:50 AM   #15
No, no; I meant that I could understand your previous post.
I don't know what "the lock nut that locks the clevis to the shock rod" is.
Could you post some pictures of those?
Old December 6th, 2014, 10:37 AM   #16
Z1R rider
Z1R rider's Avatar
I'll try and get some pics later today
Old December 6th, 2014, 11:50 AM   #17
Thanks!
I believe that my whole shock absorber was welded; but I have been wrong many times before.
It is great that it can be disassembled, so a dust boot can be added to protect the shaft.
Old December 6th, 2014, 02:26 PM   #18
Z1R rider
Z1R rider's Avatar
pics of removing clevis, jam nut is under the rubber bottoming cushion. Jam nut is 17mm. My "spring compressor" is a big bearing puller.
Old December 6th, 2014, 02:54 PM   #19
Excellent !!!
Thank you very much, Roger; I stand corrected.
Have you done it just for painting the spring, or for servicing the hydraulic absorber as well?
Old December 6th, 2014, 03:15 PM   #20
Z1R rider
Z1R rider's Avatar
Excellent !!! have you done it just for painting the spring, or for servicing the hydraulic absorber as well?
I did it so I could put a 1/2" to 3/4 inch spacer under the spring to preload it and get the sag with rider closer to where I wanted it, which raised the rear, the shock it's self is a sealed unit I believe. (but I didn't really look)
Old December 6th, 2014, 04:08 PM   #21
Again, thanks.
Old December 8th, 2014, 01:44 AM   #22
TBC
TBC's Avatar
Thank you! That's really helpful. I ordered a spare shock from eBay to play with - hopefully it'll be here later this week and I can give this a shot. I'll report back with results!
Old December 29th, 2014, 03:11 PM   #23
InvisiBill
InvisiBill's Avatar
I just wanted to confirm what Ghostt said. The PreGen's spring is heavier than the one that comes on the 500, so I swapped it. I used a homemade spring compressor consisting of a couple ratchet straps (Redneck Engineering - Do Not Try This At Home!). Once you compress the spring, you just loosen the locknut and clevis from the shaft, then the spring will fall right off.
The 500's preload adjuster lets you release all tension from the spring, so you don't need a spring compressor. Here is the process for swapping the spring on the 500's shock, which should be about the same other than needing a spring compressor rather than just loosening the preload adjuster.
Also note that the PreGen's top spring perch is held on the shock body with a circlip. I haven't tried it with the spring still installed, but you may be able to simply pop the circlip off once the spring is compressed. That would allow the perch to move up and relieve the spring pressure, which would then give you easy access to the nut at the bottom.
The NewGen/300 shock has a notched lower plate that just slides in and out once you relieve the spring pressure.
Pregen rear spring shock alternatives greenaero 1986 - 2007 Ninja 250R Tech Talk 41 March 4th, 2016 08:53 AM
Removing the vacuum spring from the petcock. berserk81 General Motorcycling Discussion 5 November 5th, 2013 08:07 PM
What Rear Shock/Spring will work - EX300? accident-prone 2013 - 2017 Ninja 300 General Discussion 90 March 26th, 2013 06:38 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
