Old March 14th, 2014, 02:29 PM   #41
chris 25Or
Motorcycle(s): 2008 CBR1000rr, 2012 BMW S1000rr, 2011 Ninja 250r, 2015 KTM RC 390, 2013 Triumph 675R
I just ordered a set.
chris 25Or is offline   Reply With Quote
Old March 14th, 2014, 07:11 PM   #42
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Don't worry if you don't hear from them. Both of us never heard from them after ordering but they came about a week to a week and a half later.
Old March 24th, 2014, 07:23 AM   #43
DaveTheCanuck
Moo
DaveTheCanuck's Avatar
Motorcycle(s): 2013 Ninja 300
Possibly silly question but... do the 250 and 300 share the same stock shock?
Or in other words, do these measurements apply to both bikes? I just installed my gsxr shock this weekend and want to raise the rear back to stock, since it looks like it's sagging a bit lower now. Wondering if the 1.25" raise link will do the job on the 300 as well.
DaveTheCanuck is offline   Reply With Quote
Old March 24th, 2014, 11:53 AM   #44
ChrisJuliano
Motorcycle(s): Ninja 250R
The one he sells now I think is 1.25 and 1.5, so if they share the same dimmensions then that would be awesome to know! Ill be interested in the answer
ChrisJuliano is offline   Reply With Quote
Old April 14th, 2014, 09:34 PM   #45
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Originally Posted by ForceofWill View Post
So the +1.25 look right at 156mm middle of eye to eye and the +1 look like 158.5mm to me.
Originally Posted by subxero View Post
I'm gonna cut and drill some 1.25" riser dogbones probably this weekend for my gsxr swap mod. After I do some measurements I might make mine a little shorter eye to eye ~2.5mm = ~1/4" in height change so I might drill 157mm eye to eye time will tell
FYI, the 39111-1133 dogbones used on the Gen2 EX500 are 157.5mm eye to eye. A lot of EX500 owners buy shorter dogbones from FOG to raise the rear end for quicker steering (similar to the topic of this thread), so you might be able to find some for cheap/free (though $17 still isn't bad). Both the 250 and 500 use the same sleeves through the knuckle and swingarm, but the 500 uses 100mm long bolts (92002-1886) while the 250's are 98mm (92153-1831), so the 500 dogbones might possibly be a bit thicker or something.
Old April 15th, 2014, 04:31 AM   #46
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
@InvisiBill good info
Thickness of dog bones should not matter to much for the gsxr shock swap as you need spacers to get the bones to clear the new spring. So you have to buy longer bolts anyway.
Old April 18th, 2014, 08:58 PM   #47
chris 25Or
I e-mail them and got no response, but I got them about 2 weeks later.
Thanks
Old April 18th, 2014, 09:50 PM   #48
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
Burkhart Cycle has the 08-12 250 listed on his site but does anyone know if it would fit a Pre-Gen? I just did a Zx-6 Air Shock swap and it lowered it quite a bit.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old April 19th, 2014, 06:58 AM   #49
InvisiBill
InvisiBill's Avatar
Does anyone happen to know how much clearance you need to add to the dogbones to clear the larger spring? As you can see in the pic below of the EX500 Gen2 FOGbones, he bumped out the center section instead of leaving them perfectly straight. That little bit is enough for us to clear the larger springs that we commonly use. FOG charges a bit more (~$45 a set last I knew), but I'm sure he could whip some up if you gave him an eye-to-eye length (he has standard "raise your EX500 to the best height" bones but also does custom lengths). Some people might prefer to pay a bit more for PnP bones rather than deal with longer bolts and spacers and such, if a bowed dogbone like this could work for the GSXR shock too.
And on that note, is there a difference between these two?
2008-2012 Kawasaki Ninja 250R Raising links, Dogbones 27205
2008-2012 Kawasaki Ninja 250R-GSXR shock swap Raising links 27205B
I thought maybe the GSXR ones might have a bow in them to provide some extra room or something, but the description doesn't mention anything about the construction being different. The GSXR model just has a couple longer length options than the regular one.
NewGen and PreGen are totally different.
Originally Posted by InvisiBill View Post
Looking at the parts fiche, the PreGen appears to use a more complex dogbone than the NewGen. The Gen1 and Gen2 EX500s use different bones too, and the PreGen's look similar to the Gen1's (though it's not the exact same part number).
Gen1
Gen2
Old April 19th, 2014, 09:02 AM   #50
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Its a good bit, People were using 1/2" nuts as spacers or something similar and you figure they have to be close to 3/8th wide give or take. One on each side
edit: There is tons of info buried in this thread, but here is a particular post that you might find helpful from it
https://www.ninjette.org/forums/show...&postcount=166
Old May 7th, 2014, 11:07 AM   #51
warning
warning's Avatar
Motorcycle(s): A lot
Does anyone know if the rear linkage on the 250r and the ninja 300 are the same?
warning is offline   Reply With Quote
Old January 24th, 2015, 11:07 PM   #52
Tiller
Motorcycle(s): RC51, TL1000R, GS1100E, RM125,
Could someone confirm the oem link center to center on the 250. The the ones I have, have been drilled. I come up with 164.5mm 6.476''.
I made some at 155mm for a race bike and it seamed to work. I'm trying to figure out from the oem piece and the info in the earlier post the amount of change per 1mm. 158.5 for 1'' and 156mm for 1 1/4' . That would be 6mm per 1'' or .1666 per 1mm. If I figure 8.5mm shorter for the 1 1/4'' rise links it comes to 1.416'' rise. So to me the numbers don't work unless it has something to do with an angle change as the link become shorter so the relationship between link length and swing arm at the axle would not be linear.
Tiller is offline   Reply With Quote
Old January 24th, 2015, 11:29 PM   #53
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Hi Bruce, if you talk about the new-gen (2008-2012) then your right, the center to center measurement is 165 mm.
Old January 24th, 2015, 11:42 PM   #54
Tiller
No, that would mean I'm a half mm short. So 165, let me play with the calculator.
Old July 13th, 2015, 06:11 PM   #55
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Hate to dig up an old thread, but correct me if I'm wrong, the change of dog bone length and how that relates to overall rear height of the bike is not constant, right? Because this relates to the rear, and it pivots. I'm trying to map this in my head. Thanks.
GSXR rear shock upgrade psych0hans Ninjettes At Speed 17 June 17th, 2014 11:47 PM
I'm new, already installed gsxr shock. Zombarian 1986 - 2007 Ninja 250R Tech Talk 14 June 17th, 2014 01:06 PM
2006 gsxr shock sidekick10121 1986 - 2007 Ninja 250R Tech Talk 2 March 26th, 2014 04:13 PM
GSXR shock swap questions subxero 2008 - 2012 Ninja 250R Tech Talk 75 March 13th, 2014 12:09 PM
gsxr shock alex.s Ninjettes At Speed 1 October 17th, 2013 12:03 PM
