July 16th, 2015, 07:41 AM | #1 |
Aftermarket tach
Trying to install aftermarket tach.
http://www.ebay.com/itm/12000-RMP-km...-/151466325787 Wired everything, everything works except of tach itself. It's needle up down on power on, and then does not react. Wired: Brown - power/reference(? Tach has only one + power input) Black/yellow - ground. Black - tach read out. I tried to measure voltage between black and black/yellow -it's always 12v , no matter how I rev up the engine. Seller said something about tach accepting 5v rpm readout - do tachs even have such thing as voltage marking?... |
July 16th, 2015, 07:54 AM | #2 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
get any kinda of a manual with it?
Spoiler for topic:
July 16th, 2015, 12:56 PM | #3 |
dirty boy
MOTM - Apr '14
the Chinese digital tachs are known to come with incorrect wire diagram/labeling. You will probably have to figure out what is what for yourself. It can also be expected that it will not work 100% as it was no designed with one particular model in mind.
July 16th, 2015, 01:25 PM | #4 | |
EX500 full of EX250 parts
Depending on what you're using to look at the black wire, the pulses may be too quick for your meter to see them.
Delayed Tach | 07_25_stl | 1986 - 2007 Ninja 250R Tech Talk | 8 | January 13th, 2015 07:21 PM |
Digital Tach | wanarace94 | 2008 - 2012 Ninja 250R Farkles | 11 | May 7th, 2014 07:23 AM |
Tach does not exceed 4k | bryzenga | 1986 - 2007 Ninja 250R Tech Talk | 4 | October 18th, 2013 06:59 PM |
Another tach issue | Cosmos | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 19th, 2013 06:04 AM |
tach replacement | Broom | 2008 - 2012 Ninja 250R Tech Talk | 9 | June 4th, 2009 05:34 AM |
