July 17th, 2015, 12:23 PM | #1 |
Join Date: Jul 2015 Motorcycle(s): 2011 ninja 250r Posts: 19
Any way to adjust throttle cable?
So 2 weeks ago I got a 2011 250r. It was an R-title completely repaired. Most small little annoying things I have gotten sorted out due to this site. So thanks for that.
One issue I am having, which is not a super big deal, but would like to adjust if possible. The throttle seems slightly sloppy as if the first .75 inch to inch of movement does nothing. It is only a little annoying because I have to start my wrist up a little higher than normal to start twisting the throttle. How can I adjust that cable to get rid of a little slack? |
July 17th, 2015, 02:27 PM | #2 | |
July 17th, 2015, 04:09 PM | #3 |
Thank you. Sorry for posting. I must have typed something in wrong when I searched.
July 17th, 2015, 04:24 PM | #4 |
no biggie. Just make sure that you are still able to turn the bars lock to lock without messing with the throttle. while you're at it, lube your throttle cables. everyone should do that at least once a season to prevent corrosion and keep the cables moving smoothly.
July 17th, 2015, 05:09 PM | #5 |
Don't forget to lube the clutch and choke cable as well.
This is what I use
July 17th, 2015, 05:12 PM | #6 |
werd. Just did all my cables. Made a mess because I was lazy and didn't put a towel down, but my cables are smoother now.
it's been sitting out in the hella rain that W Ohio has been getting lately, so I figured a little cable lube could only help. |
July 17th, 2015, 05:38 PM | #7 |
I generally do mine about every few months, as my Ninjette lives outside, and I ride in the elements.
July 19th, 2015, 01:45 AM | #8 |
MOTM - July '15
This guy right here recommended this to me and I'm never going back. It's awesome stuff, much less messy, lasts longer, and costs about the same. I even used it on my car's throttle cable because I figured I might as well while I was in there.
July 19th, 2015, 01:48 AM | #9 |
Glad you liked it, I too have tried a bunch of lube over my many, many years, and this is by far the easiest way to go.
July 19th, 2015, 05:46 AM | #10 |
Does it come in aerosol to work with my cable lubing took from motion pro?
July 19th, 2015, 06:03 AM | #11 | |||
Have some paper towels ready to catch the excess, it goes on as a liquid, but then dries leaving a film of molybdenum. Quote:
http://www.drislide.com/collections/...cle-lubricants Bike Aid Dri-Slide 4oz. Lube with Needle Nozzle https://www.amazon.com/dp/B001F2Y25G..._5b6Qvb9FMG62G Genuine GM Fluid 1052948 Dri-Slide Lubricant - 5.25 oz. Aerosol https://www.amazon.com/dp/B000QIIT68..._nn6Qvb1VB1XEB
July 19th, 2015, 07:19 PM | #12 |
MOTM - July '15
July 19th, 2015, 07:22 PM | #13 |
huh, I've never used the needle method I just use the motion pro tool. Makes a mess but works. Only made a mess last time because I didn't use a paper towel. lazy and in a rush to beat the rain I work in a parking lot now. Ninja stays outside
DIY How to Lube and Adjust the 250R Clutch Cable and How to Add 10 HP w/ one Mod!!! | kkim | 2008 - 2012 Ninja 250R Tech Talk | 51 | October 11th, 2014 06:42 PM |
Throttle went while riding -> need new throttle cable? | AndrewMack | 2008 - 2012 Ninja 250R Tech Talk | 13 | September 8th, 2013 06:17 PM |
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out | theob | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 19th, 2012 05:01 PM |
How do I adjust the throttle push-pull cables? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 10th, 2011 05:45 AM |
Throttle & Throttle Cable Smoothness | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 1st, 2009 01:50 PM |
