July 18th, 2015, 04:33 PM | #1 |
won't start - no green light (2012 250r)
Hi All
Complete noob - just done my one day learners course - just bought the bike. It was sitting around for long time at last owners but it had full service just before I bought it. Bike's sitting outside on deck - roof and under bike cover. Its been cold here. Yesterday took it for my first spin on the backroads. I had to give it full choke to start but it started OK. Yesterday if I started and then engaged to neutral light would go from red to green and it would start. Today only red light - won't go green whatever I do. I've got clutch lever in and kill switch is in the correct position and I can see and hear gas in the tank. |
July 18th, 2015, 04:58 PM | #2 |
Join Date: May 2013 Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol Posts: 222
If you are sure it's in neutral it could be the clutch switch. If it's in gear the kickstand need to up if it is check the kickstand switch.
July 18th, 2015, 05:10 PM | #3 |
Join Date: Apr 2015 Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke" Posts: 129
I didn't know the light ever turned red. For my '10 it's either green or off.
Agreed, though, check the switches for the clutch lever and kickstand first. As long as it's actually in neutral, which you can check by trying to rock the bike back and forth with the clutch out, it'll start whether the stand is down or up or whether the clutch is pulled in or let out. It won't matter, it'll just start. Also, try pulling in the clutch and shifting ALL the way down until the shifter won't move anymore. You may be sitting in a false neutral. |
July 18th, 2015, 05:42 PM | #4 |
Thanks guys - bit frustrating on yr 2nd ride ever.
I was trying with the kickstand up. John - do you mean if its in neutral you should be able to walk it and the wheels will turn freely? |
July 18th, 2015, 06:13 PM | #5 |
Uhhh... unless you've got either a) some weird idea of what the dummy lights should be doing or b) some weird wiring that makes your dummy lights function differently, then idk how to figure out what you're even talking about.
Green: neutral light. Only comes on when it's in neutral. Off when not in neutral. red: low oil pressure light. Comes on when oil pressure is low. Off when oil pressure is deemed "okay" for running. yelllow: turn signal indicator. Self explainatory. blue: high beam indicator. Self explainatory. SO! What's up with yours? Notes: choke is fine. It's carbureted, that's how it starts. With choke. Don't use choke as the judge of what condition your bike is in, that's just silly. Permissive conditions (all conditions need the kill switch and ignition to be "on") for the bike to start:
July 18th, 2015, 06:36 PM | #6 |
Double check that it's in neutral.
Rock the bike forward and backward (engine off) while tapping down on the shifter until you no longer feel any movement, then a light tap up to neutral - that should give you a green light unless there are other issues. The red light should be the oil pressure sensor. It should be on when you turn on the ignition, but go off immediately when the engine starts. |
July 18th, 2015, 08:49 PM | #7 | |
I wonder if the Australian models have different indicator lights. If you cannot walk it, put the bike on the center stand, and manipulate the gear shifter with your left hand while you turn the rear wheel with your right hand (be careful with your fingers next to the lower point of engagement between chain and sprocket). Be aware of the Kawasaki positive neutral finder: http://faq.ninja250.org/wiki/Acceler...changing_gears Please, read these also: http://faq.ninja250.org/wiki/How_do_...the_shifter%3F http://faq.ninja250.org/wiki/My_bike...this_normal%3F http://faq.ninja250.org/wiki/E-Z_shifting_for_beginners Welcome, Kevin!!!
July 18th, 2015, 09:31 PM | #8 |
Certified looney toon
MOTM Jul '13, Jul '14
Just to help clear up the light confusion, @ubercat, does your gauge look like this?
July 19th, 2015, 06:48 AM | #9 |
EX500 full of EX250 parts
Yeah, the stock (US) dash uses clear bulbs with colored lenses over them. It's physically impossible for the lights to change color.
The way that chone described the safety switches is correct. Basically as long as it's turned on and in neutral, it should always attempt to start. The neutral sensor provides the continuity for both the dash indicator and the starting circuit. So if the dash light is on, then the starter stuff should see it as being in neutral. If it's not in neutral, the clutch switch will override the neutral sensor. If you're in gear and pull the clutch, it will also be allowed to start. Once it's started, having it in gear and releasing the clutch will kill the engine if the sidestand is down.
July 21st, 2015, 02:39 PM | #10 |
Join Date: Oct 2011 Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT Posts: 434
switches and other things
First like everyone says check that the bike is in neutral by pushing bike forward if it's in gear you'll know it. Second if in neutral make sure side stand is up. Third if above is ok then disconnect the wires to the side stand switch and jump between them, that should allow the bike to start. Someone else chime in if there's a handlebar clutch lever switch? I think their is but haven't had any trouble so I can't say for sure...
wardie |
Ninja 250r Won't Start | Sylenthunter96 | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 19th, 2015 08:11 PM |
2009 ninja 250r won't start | jpiz224 | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 23rd, 2015 06:35 AM |
2012 Genuine Buddy 170i won't start (scooter) | GreatScott | The Ex-Ninjetters Lair | 1 | October 22nd, 2014 05:01 AM |
Ninja 250r won't start | Richardcheung | 2008 - 2012 Ninja 250R Tech Talk | 4 | July 15th, 2013 10:04 AM |
[topix.net] - Why motorcycles won't have to wait till the light tuns green | Ninjette Newsbot | Motorcycling News | 0 | May 26th, 2011 01:40 AM |
