July 5th, 2022, 08:01 AM | #1 |
[webbikeworld.com] - 2022 Kawasaki Z900RS [Specs, Features, Photos]
Click here for full story...
The 2022 Kawasaki Z900RS: Welcome to the Retro Revolution Contents The only thing better than a retro Kawasaki bike is a brand new Kawasaki bike—and the 2022 Kawasaki Z900RS gives you the best of both worlds. This year’s model draws enough from the glory days of naked motorcycles to satisfy your nostalgia for the good ol’ days of classic cafe racing, but the features and engineering are all modern enough to make sure your ride stays comfortable and safe. Naked motorcycles from Japan have been big business for a number of years now, and Kawasaki has kept themselves firmly at the front of the pack with offerings like this. The 948cc in-line four-cylinder engine in the Z900RS puts out 111 hp @ 8,500 rpm and 72.3 lb-ft of torque @ 6,500 rpm, giving riders tons of braap for their buck. You won’t find many changes from last year’s model here, but the 2022 Z900RS does come in eye-catching Candy Tone Blue, which gives it a distinctive appearance. There’s also a 50th Anniversary Edition, which comes in an utterly gorgeous (and very retro) Candy Diamond Brown. What’s not retro here is the list of features: Kawasaki Traction Control (KTC), dual throttle valves, an assist & slipper clutch, horizontal back-link rear suspension, and ABS all come standard on the new Z900RS. That means you get to enjoy the classic cafe racing experience with none of the danger faced by riders of yore. Score one more win for Team Green! The Z900RS makes an adventurous and attractive addition to Kawasaki’s motorcycle models for 2022. Bikes like the Triumph Bonneville T120 and Ducati Scrambler Nightshift might want to make some room. The 2022 Kawasaki Z900RS starts at $11,749 USD / $13,899 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Z900RS in one place. Model Overview </p>General Info
Main Specs
Competitors 2022 Kawasaki Z900RS Specifications ENGINE Engine948cc, 4-stroke, 4-cylinder, DOHC, 16-valve, liquid-cooledPower111 HpBore x Stroke73.4 x 56.0mmCompression Ratio10.8:1 Fuel SystemDFI® with Keihin 36mm throttle bodiesStarterElectricLubricationDRIVETRAIN ClutchTransmission6-speed, Manual, Return ShiftFinal DriveSealed chainCHASSIS Suspension FrontInverted telescopic fork with (13-way) adjustable compression and rebound (11-way) damping, spring preload (15-turn)/4.7Suspension RearHorizontal back-link swingarm with stepless adjustable rebound damping and spring preload/5.5 inBrakes FrontDual 300mm disc, ABSBrakes RearSingle 250mm disc, ABS Tires Front120/70 ZR17Tires Rear180/55 ZR17Fuel Tank Capacity4.5 galColorCandy Tone Blue ELECTRICAL IgnitionTCBI with electronic advanceSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS Overall Length83.1 inOverall Width34.1 inOverall Height46.5 inWheelbase57.9 inGround Clearance5.1 inSeat Height32.9 inCurb Weight474.1 lb (50-State Model)*WARRANTY Warranty12 MonthsKawasaki Protection Plus12, 24, or 36 months 2022 Kawasaki Z900RS Features Assist & Slipper Clutch Based on feedback from racing activities, the Assist & Slipper Clutch uses two types of cams (an assist cam and a slipper cam) to either drive the clutch hub and operating plate together or apart. Under normal operation, the assist cam functions as a self-servo mechanism, pulling the clutch hub and operating plate together to compress the clutch plates. This allows the total clutch spring load to be reduced, resulting in a lighter clutch lever feel when operating the clutch. When excessive engine braking occurs – as a result of quick downshifts (or an accidental downshift) – the slipper cam comes into play, forcing the clutch hub and operating plate apart. This relieves pressure on the clutch plates to reduce back-torque and helps prevent the rear tire from hopping and skidding. This race-style function is particularly useful when sport or track riding. Dual Throttle Valves Late-model sport bikes often use large-bore throttle bodies to generate high levels of power. However, with large diameter throttles, when a rider suddenly opens the throttle, the unrestricted torque response can be strong. Dual throttle valve technology was designed to tame engine response while contributing to performance. On models with dual throttle valves, there are two throttle valves per cylinder: in addition to the main valves, which are physically linked to the throttle grip and controlled by the rider, a second set of valves, opened and closed by the ECU, precisely regulates intake airflow to ensure a natural, linear response. With the air passing through the throttle bodies becoming smoother, combustion efficiency is improved and power is increased. Economical Riding Indicator Using high-precision electronic control for engine management, Kawasaki models can achieve a high level of fuel efficiency. However, fuel consumption is greatly affected by throttle use, gear selection, and other elements under the rider’s control. The Economical Riding Indicator is a function that indicates when current riding conditions are consuming a low amount of fuel. The system continuously monitors fuel consumption, regardless of vehicle speed, engine speed, throttle position and other riding conditions. When fuel consumption is low for a given speed (i.e. fuel efficiency is high), an “ECO” mark appears on the instrument panel’s LCD screen. By riding so that the “ECO” mark remains on, fuel consumption can be reduced. While effective vehicle speed and engine speed may vary by model, paying attention to conditions that cause the “ECO” mark to appear can help riders improve their fuel efficiency – a handy way to increase cruising range. Further, keeping fuel consumption low also helps minimize negative impact on the environment. KTRC (Kawasaki Traction Control) KTRC, Kawasaki’s advanced traction control system provides both enhanced sport riding performance and the peace of mind to negotiate slippery surfaces with confidence. Multiple rider-selectable modes (the number of modes varies by model) offer progressively greater levels of intrusion to suit the riding situation and rider preference. Less intrusive modes maintain optimum traction during cornering. Designed with sport riding in mind, they facilitate acceleration out of corners by maximizing forward drive from the rear wheel. And because Kawasaki’s sophisticated software bases its dynamic analysis on the chassis’ orientation relative to the track surface (rather than relative to a horizontal plane), it is able to take into account corner camber, gradient, etc., and adapt accordingly. In the more intrusive modes (and for some models, in any mode), when excessive wheel spin is detected, engine output is reduced to allow grip to be regained, effectively enabling riders to negotiate both short, slippery patches (train tracks or manhole covers) and extended stretches of bad roads (wet pavement, cobblestone, gravel) with confidence. Sound Tuning Kawasaki has long had a reputation for building great-sounding bikes – a characteristic inherent in the Kawasaki engine architecture – but it is only recently that effort has been put into crafting a specific auditory experience through careful sound tuning of either the intake or exhaust system. Designed specifically to allow riders to enjoy their motorcycles aurally as well as physically, the carefully crafted auditory notes can be the key components of the street riding exhilaration offered by models that have benefitted from sound tuning. Sound tuning can include conducting sound research, designing intake and exhaust system components based on an acoustic test carried out in a sound room, and careful consideration of every detail of a system’s components to ensure a balance of performance and the desired sound. ABS (Anti-lock Brake System) Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment. ERGO-FIT Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style. ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride. *Adjustable parts and their range of adjustability vary by model. Horizontal Back-link Rear Suspension Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling. 2022 Kawasaki Z900RS Photos 2022 Kawasaki Z900RS Videos 2022 Kawasaki Z900RS Review & Walkaround 2022 Kawasaki Z900RS Review and Test Ride 4K Links Kawasaki Official Websites Social Media Links The post 2022 Kawasaki Z900RS [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Kawasaki Z650RS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 5th, 2022 04:44 AM |
[webbikeworld.com] - 2022 Kawasaki Ninja ZX-14R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2022 10:14 AM |
[webbikeworld.com] - 2022 Kawasaki Ninja ZX-6R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2022 10:03 AM |
[webbikeworld.com] - 2022 Kawasaki Ninja H2 SX SE [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 04:53 PM |
[webbikeworld.com] - 2022 Kawasaki Ninja H2 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 04:41 PM |
