October 26th, 2013, 01:37 PM | #1 |
Join Date: May 2013 Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F Posts: 125
Small question regarding oil check
Hiya! Im a bit confused and need some help to clear this up
Yesterday I changed the oil/filter, had someone hold the bike vertically and filled the oil up to the high mark. Thought that's enough oil, went for a small ride and that's that. But few days later when I was about to take it out for another ride, I held the bike vertically to check the oil and saw that there was barely any oil in the glass. I dont see any major leak on the ground except a few drops probably from forgetting to clean the oil filter cap. Where did all the oil go?? Edit: i also see the oil pressure light on during idle |
October 26th, 2013, 01:59 PM | #2 |
After you fill it up the first time, you should start the bike for about a minute then turn it off and fill it up to the line again. You have to purge the dry filter with oil to get the correct amount in
October 26th, 2013, 02:03 PM | #3 |
MOTM - Sep '14
0 out of 1 members found this post helpful. |
October 26th, 2013, 02:08 PM | #4 |
Bass Master General
October 26th, 2013, 02:15 PM | #5 |
MOTM - Sep '14
October 26th, 2013, 02:20 PM | #6 |
I will go re fill the oil thank you guys
Small displacement question | Apex | General Motorcycling Discussion | 80 | December 9th, 2012 10:34 AM |
[visordown.com] - Foreign Office urges holiday scooterists to check insurance small p | Ninjette Newsbot | Motorcycling News | 0 | August 18th, 2010 05:40 AM |
Question re valve check | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 16 | July 7th, 2010 05:53 PM |
Oil Leaking after Valve Clearance Check | nick2049 | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 13th, 2010 09:10 AM |
Check out the Motorcycle Oil Info | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 0 | February 9th, 2009 05:21 AM |
