September 9th, 2012, 11:44 AM | #1 |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
Greek rider of a modified Fuel Injected 250
hello everyone... it's been ages since I left the States permanently and still regret it...however I stay in touch with friends and relatives in California...
I own a ZX-12R whih had been heavily modified for drag racing which now has come to a "lighter" version of the original beast I had created and use it for touring with my wife (don't say I'm getting old, still doing over 200mph on the gps from time to time) I am not a mechanic but most of the mods are being made by myself since I've gained a lot of experience from racing and participating in 'engine surgeries"...I design most of the parts I order (pistons, cam profiles etc) and I like using parts not "off the shelf" but custom-made or even matching from other bikes... as far as my 250 is concerned, I own the fastest one in Europe with some engine modifications and Ecu flashing but I haven't oversized the engine yet (which I am about to do) and I would like to share my knowledge with you on that field... I am aware of the tech specs of the new 300 and I am disappointed (same head, lower compression by flatter pistons, overstroked for torque but lower rev limit...) I will give you an idea of what I have in mind and want all of your opinions on my project... forgive me if I make mstakes on technical terms (please corrct me every time) or misuse the language but I haven't practiced my english in ages... now here is a video of my little R...
Link to original page on YouTube. |
September 9th, 2012, 12:16 PM | #2 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
micoulisninja! Glad to have you aboard...
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
September 9th, 2012, 03:52 PM | #4 |
Jigglin' your Jiglets
MOTM - Apr '13
o0o I want to get rid of my rev limiter now. What is your 0-60mph or 0-100kph?
September 9th, 2012, 04:02 PM | #5 |
Hello and welcome
September 9th, 2012, 04:12 PM | #7 |
I go 0-60 in 6.9 seconds. HA I WIN.
I UPGRADED to a YZF-R6 Mods: Shermoto LF7 Levers / Proton Flushmounts / Puig Smoked DB / Woodcraft Sliders / Tech Spec C3 Tank Grips / Rizoma Grips / Jardine |
September 9th, 2012, 04:14 PM | #8 |
MOTM - Apr '13
13/43 is essentially the same as 14/45 isn't it?
Did you do any exhaust/intake mods or just dick around with the ECU. My ninjette at stock was doing 0-60 in 7.9 seconds, I'm also 200 lbs. I just stuck on a new race exhaust, intake and rejet the carbs, my 0-60 should be in the low 6's now
September 9th, 2012, 04:15 PM | #9 |
MOTM - Apr '13
with what mods? Or are you one of those 60lb asian dudes
September 9th, 2012, 04:17 PM | #10 |
47/13 is 3.615
47/14 is 3.357 43/13 is 3.307 45/14 is 3.214 interesting gearing choice. I was running 14/47 for a while. It was fun, but it kept me pretty busy in turns, so I switched to 15/45. How is 13/43 working out for you? |
September 9th, 2012, 04:20 PM | #12 |
Join Date: Mar 2012 Motorcycle(s): 08 Ninja 250R (FI) Posts: 169
i am 200 lbs too
uum.. but not exactly sure about mine 0-60... but damn... your bike flies |
September 9th, 2012, 04:30 PM | #13 | |
modaholic junkie
exhaust is american yoshi version for header pipes and hand made muffler, airbox modified, ramair I made myself, removed second butterflies, different intake cam profile and timing, intake porting, cr 12,8:1 etc... preparing overbore version with 2000 ZX-6r oem pistons (66mm) for now and the final step will be a "transfusion" of the new 300 crank with the 49mm stroke whih will give a 335cc engine (282cc on a stock crank...)and the new, bigger 32mm throttle bodies... oh, I forgot... pc V and autotune with onboard real time settings for fuel and many mods on suspension and brakes...advance curve is different (about +3, +4 degrees) set from the flashed ecu and set on the dyno... |
September 9th, 2012, 04:32 PM | #14 |
this thread has some more 6-60 runs:
http://www.ninjette.org/forums/showthread.php?t=99216 |
September 9th, 2012, 04:37 PM | #15 |
I'm just joking. I have no idea what my time is.
And yes, I'm one of those 5'11'' 135 lbs asian dudes.
September 9th, 2012, 04:40 PM | #16 | |
modaholic junkie
and time is for 0-100kph (0-62mph...) numbers have little importance... the feel is totally different on the road and most importantly for me, on track...besides I am too heavy for that bike... a 150lbs rider on a stock bike is just a wheel behind up to 60mph... |
September 9th, 2012, 04:47 PM | #18 |
September 9th, 2012, 11:12 PM | #19 | |
Join Date: Sep 2012 Motorcycle(s): 01 Ninja 250, 98 Honda CR80, 79 Harley Sportster Posts: 162
September 10th, 2012, 09:54 AM | #20 |
modaholic junkie
check them out at my 250 presentation...
If noone has tried it before, I will !!! |
September 10th, 2012, 11:34 AM | #21 |
Join Date: Apr 2012 Motorcycle(s): 2003 Kawasaki Ninja 250R Posts: A lot.
Welcome!
http://www.facebook.com/groups/DeMdNjPagrouprides/ I live my life a quarter mile at a time! Who is affraid of the big bad jiggles???? LOL |
September 15th, 2012, 01:49 PM | #22 |
Join Date: Jul 2012 Motorcycle(s): Ninja 250R Posts: 484
Hi Nick and welcome
September 27th, 2012, 08:46 PM | #23 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
Fuel Injected Ninja 250... | FastrnU | General Motorcycling Discussion | 7 | March 14th, 2013 04:37 PM |
What performance mods can I do on a Fuel Injected 2010? | Shaol1n Monk | 2008 - 2012 Ninja 250R Tech Talk | 26 | September 10th, 2012 08:57 AM |
Slip on exhaust on Fuel injected model | loz944 | 2008 - 2012 Ninja 250R Tech Talk | 6 | January 24th, 2012 03:36 PM |
4 minutes of sound, my Fuel Injected 2005 | greg737 | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 23rd, 2011 07:44 PM |
UPDATE: Fuel Injected 2005 EX-250, riding and tuning.... | greg737 | 1986 - 2007 Ninja 250R Tech Talk | 21 | May 1st, 2011 12:25 PM |
